Question about GE Quiet-Aire Ductless Mini Split System Air Conditioner
Compressor pulling into a deep vacuum and not cooling. Acts like major restriction, but don't see any frosting. We have very little data available on system and when pushing test button in outdoor unit pressures go up very , very high and trips out compressor. Unit is a heat pump, any help is much appreciated, Ben.
  • mike tachovaka May 15, 2009
    my ductless system is 24,000 btu and made by an unknown company "AirCon"  I cant find any details it was working fine when installed and now 4 weeks later it goes into bypass mode and shuts off. the hp line is frozen over. It is like it is trying to heat all the time the ambient is 95 degress and about 5% humidity, there is good statitic pressure with no signs of leakage, loose wires etc.
    any ideas?
    President:
  • 1,304 Answers
Without the frosting i would tend to believe it may be under charged, or non combustables like water in your system
Posted on Oct 05, 2009
Replaced a leaking condenser coil and compressor on the model 795.72063.112 .however the unit is not cooling nor freezing .
I suspect that the humming noise is from a compressor motor that has liquid on top of the pistons and is in hydraulic lock
Why -- possibly adding liquid refrigerant and not gas
adding gas into the wrong side of the compressor
blocked high pressure line from the repair
time to call a technician in to help diagnose the problem
Nov 07, 2016 | Frost Refrigerators
My aw0893l air conditioner does not get cold. do i need freon?
Well first off is the compressor running? When you turn on the unit the fan will start. Turn the unit on to fan only. Then turn it into the cooling mode do you hear something else start? That would be the compressor. Remove the front panel so you can see the cooling coil (evaporator ) if it is freezing and has frost on just part of the coil top or bottom you have lost Freon or a system restriction.. One of the major problems with air cons is a very dirty or plugged condenser coil, which is the outside coil. If you have cotton wood trees in your area this is probably the problem.
Hope this helps Lynn
May 29, 2014 | Samsung AW0893L Air Conditioner
Compressor runs constant. whirl etomsrxtloo
Maybe low in Freon, inefficient compressor or partially restricted.
1.) Check the Freon level and add Freon if needed.,
2.) Check for leak and repair if any
3.) Change the dryer filter, pull a deep vacuum then charge the unit according to the manufacturer's recommendation. See the name plate for more info.
Note: skip all the above if compressor found inefficient.
Oct 31, 2013 | Whirlpool Refrigerators
Unit not cooling down,compressor running,condenser fan running. suction line just cool,condenser line barely warm.
Check if evaporator fan is running. Is there any frost buildup on freezers evaporator cover? If so you have a defrost problem (bad heater, defrost thermostat, thermister, defrost timer or circuit board ). If no frost and the freezer is warm then you most likely have a sealed system problem(leak, restriction, bad compressor) which is costly to repair.
Oct 19, 2010 | GE Â 17.9 Cu. Ft. Top-Freezer...
Stops blowing air
remove cover at ceiling so you can see in at fins and see if they are frosting up bad. If they are, I suspect during AC installation, they didn't open up ducts on discharge properly and air flow is restricted, which will cause freeze up, especially if low flow from discharge ducts. I'm assuming it is a ducted system. You may have to remove or drop down entire ceiling assy, to see if the ducts into ceiling have any blockage. Sometimes they don't cut rubber roof material back far enough, or misaligned ducts and cause restricted flow to ceiling vents, which will cause unit to frost up, which kicks out compressor until frost is melted, then compressor kicks back in and cooling happens again.
Apr 06, 2010 | Dometic Rooftop RV Air Conditioner
Model GSC130481AG, S# 0808548576 The common wire to the compressor rubbed through the wire insulation and melted a hole in the discharge line from the compressor. Upon loosing all of the refrigerant the...
You have a restriction in the system. Probably in the TXV or orifice in the A/H.
The burn out sent trash/fragments through the system. I would open the sytem and blow nitrogen through, then pull a deep vacuum.
You may need to install a low side filter/drier. When you open the system change out the high side drier again for sure.
Jun 26, 2009 | Goodman Heating & Cooling
The freezer is cold but not cold enough to make ice
Check the back (interior) lower half of the freezer wall. If you see a frost build up, you either have an issue with your defrost cicuit (timer, heater, thermostat) or the evaporator (freezer) fan is not running. If there is not a frost build up on the back wall you either have a sealed system (weak compressor, leak or restriction) problem....or the condensor fan motor is not working. This would cause the compressor to overheat and shut down until cooled, and prevent the deep freeze.
Jun 05, 2009 | Amana 22.6 cu. ft. Side-By-Side...
I am trying to charge up my a/c on a 95 olds ciera but the a/c compressor will not kick in as the system is completely empty. How can i engage the compressor?
With a vacuum pump, pull a deep vacuum on the system then charge the refrigerant in. It will go in by itself with the system under a vacuum.
You can also remove the wire connector going to the pressure switch on the accumulator and jump it out with a small wire. While the car is running and the switch set for cool the compressor will come on.
Apr 12, 2009 | Heating & Cooling
Air conditioning not cooling properly
It sure sounds like a restriction, but you seem to have covered most all the bases I would (I am a ASE Master technician) see if the fixed orifice is plugged or restricted??, maybe the system is freezing up, is the compressor cycling switch set correctly to approx 28-32 psi??
Jul 29, 2008 | 1992 Honda Accord
Not cool at all!
If the compressor is running you should be cooling unless there is a major loss of refrigerant. What we do for these complaints is to first let the refer run for a few hours then pull the interior rear panel off the freezer section back wall and check the frost pattern on the coils. It should be a nice white frost pattern all the way across the coils (no bare alum. showing and no mass of ice either). If you don't have that pattern then there is a sealed system issue. If you have a massive block of ice all over the coils then you have a defrost cycle issue (not getting proper air circ. due to the block-o-ice thing). Let us know what you find... oh, you can sometimes find the leak by looking for oily residue from the compressor lubricating oil (it leaks out where the gas does also).
Jan 16, 2007 | Kenmore 60721 Refrigerator
GE Quiet-Aire Ductless Mini Split System Air Conditioner Logo
162 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Todd B
Mack Baxter
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
