Question about Dryers
Maytag performa dryer assistance
Hello, my name is Ginger. I need assistance in replacing the felt seal inside and at the back of my maytag performa dryer, pdet910ayw. Thanks!
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Posted on Jun 17, 2008
Maytag Performa pdet920ayw has a horrible squeal. The drum is metal to metal with the blower housing
It seems like defective slider , ,check out each carefully and replace if needed such as roller, front seal or rear seal or loose blower fan blade assembly
Feb 26, 2015 | Maytag Dryers
I have a Performa Maytag dryer it will sometimes turn on run a few seconds and then cut off and it will do this in consistently as I left it plugged in and left it on it was run and then cut off run and...
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Feb 20, 2015 | Maytag Dryers
Is there something else i can use to replace the felt seal without buying a whole new drum on a maytag neptune model MDE9700AYW
On older maytag dryer's the felt seal wasa seperate part and not part of the drum..the problem is i do not know if the drum on the newer and older dryers is the same diameter they look similar in size but if it isn't exactly right may leave a gap where the clothes will get caught in...however the part number for that seperate felt seal is 314820
Gene
Aug 24, 2011 | Maytag Neptune MDE5500AY Electric Dryer
The felt liner in the dryer came off and now it is making a thumping noise and we noticed some small oil spots on the cloths
I have a Maytag dryer, MDE9700AYW, and the felt liner at the front of the inside of the drum has torn away, at least most of it has. It take approximate 2 hours to dry a load of clothing. I cannot find the part number or the name of the part. I spoke with an appliance repair shop and they are unfamiliar with the felt liner. Can someone assist with obtaining a name, part #, and resolution?
Thanks,
Anthony
Jan 11, 2011 | Maytag Dryers
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Clothes getting stuck in front of dryer the model wasn't listed below mode is LDE8404ACE
If your clothes are getting stuck in the front of the dryer, it could mean more than one thing.
Your front felt seal is faulty, broken, or out of position.
After years of use, the front felt seal on the dryers break down,come loose, or become faulty. It is also sometimes caused by wear in the drum rollers, and this causes the felt seal to become worn.
You will need to replace the front felt seal and possibly the drum rollers.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum, felt seal and belt. It is a good time to check and replace the felt seal. You could stop there but I recommend that you do the following:
Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they are worn or have flat spots on them replace them.
If the drum rollers don't have flat spots on them and is not worn, then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 14, 2009 | Maytag PYE2300AY Electric Dryer
Black carbon/soot on the door and lint filter of my dryer
I have the same problem with a Maytag Performa gas dryer. My husband took our dryer apart and found that the burner tube which leads from the burner to the back of the dryer was full of soot (which was getting blown back into the dryer drum with the hot air.) We are cleaning it out now but would like to know how to prevent this from recurring in the future.
Dec 16, 2008 | Kenmore 62602 Electric Dryer
Maytag dryer neptune felt at rear of trum came out
you have to buy a new one if the felt seal is still good use contact cement on the drub and seal to put back on with need any more help let me know
Jan 11, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
643 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
