Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Wireless adapter i have at&t communication manager that gives me internet would taht still work i do i need a router
    Problem Solver:
  • 9 Answers
I believe a router is necessary, however if you have an IP address and your adapter picks up the signal then I suppose it works. Check if you have an IP address at http://whatismyip.com/.
Posted on Jul 09, 2008
I bought a NETGEAR N150 Wireless USB Adapter WNA 1100 last week from Currys, I eventually managed to install it! Unfortunately I cannot get any instructions on-line so I cannot use it!! Can you tell me...
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Aug 31, 2011 | Computers & Internet
During my linksys install, the software validates my connection and fails everytime. I do not have an adapter on the computer I am installing the software on. This PC has direct cable connection to...
You need to have the router connected directly to the computer to do this setup. If you are directly connected to the internet you cannot communicate with the router and most everything will fail. Remember to set wireless security on the router, give a ssytem name and consider setting channels to 11 or so to not compete with wireless home phones.
Oct 03, 2010 | Linksys Computers & Internet
Internet access problem
its all OK if you are getting connected to router, but are you getting any IP Configuration settings automatically or have it manually configured on your adapter verify that, this problem is related to IP configuration problem if you have your connection perfect with router
Jun 27, 2010 | Linksys (WMP54GS) 802.11g/b Wireless...
Need help with Wifi Connection with COMPAQ EVO N610C LAPTOP
First you will need a router which will enable you to create a wireless network for your internet connection. I recommend, if you're purchasing online, to use Tigerdirect. Then you would need a USB wireless adapter for your laptop which will enable it to communicate with the wireless router and establish an internet connection.
Below are some links for the most affordable and best rated products you need.
USB wireless adapter.
Wireless router
Oct 05, 2009 | Compaq Evo N610C Notebook
Can i use Bluetooth USB Adapter to connect PC to wireless router?I purchased a new PC that's connected to a wireless router for internet. I want to connect my old PC to the same wireless router. I don't...
Hi, to connect your computer to the wireless network of the router you need to have a wireless adapter. The bluetooth adapter will not work in this case as the router does not communicate with the bluetooth signals.
Purchase a wireless adapter like NETGEAR WG111
Rate it, if it helps.
Regards
Anand
Aug 03, 2009 | Computers & Internet
Upgrade of router giving connection problems
You need to check the settings on the wireless adaptor to make sure it is the same as the new router. If you had set the old router with a password, then you need to set the new one the same way. If the new router is not set with a password and the connection is open and not secured, then you need to change the settings of the computer wireless adaptor.
Jun 26, 2009 | Dell 1450 (D1450U) Wireless Adapter
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
Can't find internet.
check the ip address on the wireless network connection icon,make sure that the ip address,make sure it is dhcp enable and is within the same range with the router ip.you may also change the channel on your router because the problem is may be with wireless interference,you may be using other wireless devices that are running within the same frequency as your router.(cordless phone,baby monitor talk,microwave ovens,even thick walls and large aquariums)
Sep 11, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Not detecting any wireless networks
You have not mentioned having a wireless router or access point to serve as the hub on an infrastructure network. I you have a router please let me know -- the instructions for the solution changes.
The following is an article to create an ad hoc network between wireless cards without a wireless access point or a router. If you ignore the steps about connecting to the internet with a wired connection and the internet sharing instructions. This will allow your machines with wireless adapters to communicate with each other (assuming the operate on a common band). The article goes on to indicate one machine with a wired connection can act as the "router" for the other two when it is on to allow them share internet access with the wired machine (the wired machine also needs a wireless card for this to work).
Ad-hoc networking access point
Jan 03, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Wpn 824 wireless issues.
if you have set up the wireless connection and enable it in the router, i assume you have disconnected the wired RJ45 cable to the pc, if not do so, as the pc's ip address is still being sent to the wired adapter and needs to be giving the wireless adapter an ip address itself as you cannot have two. Either remove cable or dissable the wired network card and ensure you enabled DHCP in the router settings to automatically give the pc an ip address, ensuring that thw wireless card is also set to obtain an ip address automatically in the TCP/IP properties of the wireless network adapter.
Jun 21, 2007 | NetGear RangeMax WPN824 Router
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
