Question about Compaq Armada M700 Notebook
LCD Monitor isn't recognized
I had the DC power jack repaired on my Armada M700. After reassembling the system I booted up and started out fine. Compaq Logo came up when Laptop made jump to Bios screen went black. I thought perhaps a bad connection no such luck. Hooked up an external monitor to test. Booted up Compaq logo on the LCD, jumps to bios LCD goes black and external monitor took over. Laptop runs fine other than LCD won't come up. Went into bios change settings no luck. Change Video driver no luck. I can't figure out what it is. It isn't mechanical all connections are solid. Has to be in the bios but I flashed updated bios and it still won't work. Anyone overcome this problem in the past? I am stumped.
    President:
  • 2,712 Answers
One of 3 things..
1. Corrupt BIOS..try to reflash older version.
2. Failing LCD..Check the cable and connections.
3. Failing CMOS chip..may need to be replaced.
Posted on Jun 07, 2008
  • Swilin Sampson
    Swilin Sampson Jun 07, 2008
    Have you tried to remove all power including CMOS battery? Leave for 5 minutes then try it.
  • Swilin Sampson
    You may also want to try to reseat/replace the memory modules and see if that helps..
    Try this as well..Uninstall the display adapter in the Device Manager and reboot the system (if you get that far on the external monitor, that is..)
    You may also likely have a faulty LCD inverter.
    Please see THIS query on a different forum for some added info..
    Genius:
  • 1,665 Answers
Have a look at page 2-24 of link below:
Display was switched to the
external monitor.
Press Fn+F4 to display information
on the computer screen; press
Fn+F4 again to display information
simultaneously on both screens.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c01120667/c01120667.pdf
    Genius:
  • 1,847 Answers
The Armada M700 will output graphics ti an external monitor when you press one of the function keys, F4 or F7,
hope this will help
  • Legin Varghese
    Legin Varghese Jun 07, 2008
    the Fn+F4 combo works during the memory test screen. Once u have loaded windows its disabled and then output to external monitor is via the Video drivers set. Also chekc your BIOS for any setting related to external monitor. To output to the monitor in windows you will need the drivers from HP/Compaq itself and no way arnd that. Generic drivers wont be having that option.
    If done correctly in the display properties yuo will get the option to switch desktops and whne u click on #2 your monitor shud become active. Also for this ur monitor cable needs to be plugged into teh 15 pin MOnitor female plug on the laptop not the TV out etc. Also sometimes you need to do the external monitor switch before windows starts booting up and not after.
    Please take a moment to assign a Fixya rating if you found this solution helpful.
  • 3,037 Answers
Try putting a different version of the bios on the system and let me know how that works out. With the second monitor, can you get all the way to the desktop and everything? Please let me know.
  • Benjamin Patri
    Benjamin Patri Jun 10, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • Benjamin Patri
    Benjamin Patri Jun 28, 2008
    free to provide me with some feedback by rating my solution. If you need any
    more help, I would be glad to assist you, just ask.
  • 6,487 Answers
It is not neccesary to power your system on and off. Removing the battery for the CMOS ( complimentary metal oxide semiconductor ) will reset the BIOS (Basic input/output system) to default settings. There might also be an option within the BIOS to "Load Defaults" if that is all you are looking to do. You can also check your manual to see if you can locate a BIOS reset jumper on your motherboard.
  • 191 Answers
It is an issue with the LCD on your laptop as you get a fine display on external monitor
either get it repaired from a local technician
or get the LCD replaced
When a compaq armada m700 laptop is showing non-system disk or disk error replace and strike any key when ready
this usually happens when the computer is trying to boot from a disk that isn't a valid boot disk.
if you have a floppy drive plugged into the multibay and a floppy in the drive, try removing the floppy.
if there is no floppy involved, try to boot from your system recovery disks, as it's likely that the boot record on the hard drive will need repaired. your system recovery disks should walk you through the process.
Nov 03, 2011 | Compaq Armada M700 Notebook
I have a Compaq Armada M700 and the top part the display screen falls back - it no longer stays upright or at an angle.
on the m700 i think you can tighten the hinge........
if not i could always send you hinges......
cheers
Apr 07, 2011 | Compaq Armada M700 Notebook
The screen is very very dark on the compaq armada m700
its in neither its a seperate circuit board that connects the screen to the motherboard and its called an inverter
http://www.laptoprepair.co.uk/how-to-repair-backlight-inverter.htm
you will need the correct inverter board for your laptop and will need to find the relevant instructions on how to replace / repair it and take care and have lots of patience and persistence as it can be fiddly
Apr 18, 2009 | Compaq Armada M700 Notebook
Power issue with my Armada M700
There is a DC jack on the inside of the motherboard, It needs a solder touch-up. Chances are good the board has been getting too hot and it cause the solder to tarnish to the point that it is not making a good bond between the board and the jack. A common problem that I fix all to often. But on the M700 I would say that a fix like that would be unrealistic as I have the best prices in town and at $150 it would make the system not worth fixing. Of course as the owner of a computer store I would take it on trade for an upgraded system but not all stores do that. Good luck.
Jul 05, 2008 | Compaq Armada M700 Notebook
The screem has broken and it can not power on
well you need to get a new LCD panel for your Armada M700. You could get something like this from eBay:
http://cgi.ebay.com/Compaq-Armada-M700-Laptop-For-Parts-or-Rebuild_W0QQitemZ360053106104QQihZ023QQcategoryZ177QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
(hurry....less than 8 hours left)
You could do this yourself if you are technically inclined.
May 23, 2008 | Compaq Armada M700 Notebook
Battery for Compac Armada M700
Hello Felcen:
It could be just a coincidence...but lets try a few things...
Remove the battery and unplug from the wall. Hold the power button on...and then plug back into power...after 8 seconds release the power button. Once your computer boots to desktop...shut down...and replace the battery.
Changing the harddrive should have anything to do with teh battery...
See if your battery starts charging after this trick.
Let me know and good luck my friend.
Seek PC Repair
Feb 12, 2008 | Compaq Armada M700 Notebook
Power
are you sure your get ac power, im thinking you ac plug in the computer is loose.
Dec 17, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
Wont recognise battery
Those may have 1 or 2 different problems. Cold Solder joint on Mobo. Bad DC Power Jack. 1: if it is the Cold Solder, you can reflow the solder and be done with it. 2: if it is the DC power jack, It should be replaced. For simplicity lets call them DC(A) and DC(B) There are 3 connections to it. Gnd, DC (A), and DC (B). When the powersupply is plugged in, contacts (A) touch to send +DC to the laptop. (B) is open. When the laptop is using battery power, contacts (B) touch to send power from the battery through the system. Over a period of time (inserting and removing the DC Power Cord), the contacts become fatigued, or oxidized and the DC(B) never closes - so it won't work from DC Battery. RATE ME - if it helps
Nov 26, 2006 | Compaq Refurbished Notebooks: Armada M700...
My Compac Armada M700 does not power up.
Had the same problem with My Compaq M700 No Boot Or Post. Battery Light Flashes 8 Times, Have to Wait 24 to 48 hrs sometimes longer to get Laptop to Start. Tryed the DC Converter Board Change No Difference same Problem. Noticed When Laptop Did Start Clock Time Was always a Little Off 2-4 Hours sometimes more. So Figure CMOS Problem With Time Issues. Read About Battery Memory Transitor Voltage spike Detection Issues Corrected With Newer Bios Flash at HP Supports. So I Flashed Bios With Latest 686h. During the First Boot After Reflash Battery LED Did flash No Start, After pushing the power button again it Started. And has Every since.So Far Laptop Now Boots Everytime and CMOS Checksum Seems To Keep Time Correct In Windows. The Bios Flash Corrects a Voltage Spike Detecting Transistor In The Charging Circuit. During First Start after flash Bios will run system test on the charging system and Correct CMOS. Worked for Me Hope this Helps a Few.
Oct 30, 2006 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
137 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
