Question about Jl Audio 500/1 Car Audio Amplifier
Rca Connection yeah on my 500/1 i think there is a problem with the Rca connections the green light turns on and it plays some songs normal and other songs it wont pick up the deep bass notes its like it just shuts off i can here music coming from my sub but no bass,Do you think you could help me with this. Thanks,Tim
  • 2 more comments
  • AudioFreak Jun 07, 2008
    i think the sub is fine its a 4ohm DVC and it wired down to 2ohms is there anything else it could be?
    i have a wierd problem with my 500/1 when i put just 1 of the rca cables in to the +positive connection it plays the song great but when i put both in there isnt any bass and also sometimes it play a song and sometimes it doesnt.I really dont know what is going on i have owned several amps and never had this problem.But this is my first JL Audio amp tell me its just me and not the amp.
    Thanks
    Yeah the songs are louder thats probably whats wrong how do i fix this problem.Also
    it only plays songs with one rca connected
    and thats on the positve side.
    KnuKocepts Kollosus Flex 8awg with 1 midi anl fuse holder 50amp fuse about 6 inches from the amp and another anl midi 50 amp fuse
    near the battery.
    Genius:
  • 2,035 Answers
When it comes to installation considerations, it’s damn hard to find anything about the 500/1 to not like. For a start, there are the chassis-mounted RCA connections. By comparison, the input connectors on most amps are unimaginably flimsy. The preamp section of the 500/1 is also quite impressive. Much like the 300/4 that we reviewed a few issues back, its flexibility and degree of control are head and shoulders above anything else that I’ve seen in an automotive amplifier. Among my favorite features are the detented frequency controls found on the crossovers, bass boost, and infrasonic filter. Rather than continuously variable pots, these controls utilize stepped adjustments and the owner’s manual lists the exact frequency at each click. The parametric bass boost is another very cool gadget. The center frequency adjustment covers a wide and sensible range of 20 Hz to 80 Hz, the bandwidth adjustment (Q) ranges from very narrow to ridiculously wide and the circuit can be completely bypassed if you so desire. Equally impressive (in a test-bench-geek kinda way), is that the circuit doesn’t effect the amp’s response at all if the boost knob is dialed to 0 dB. All of the amp’s filters are similarly well behaved. The infrasonic filter covers a far wider range than typical, so wide in fact, that it overlaps the lower half of the crossover’s range. It’s possible to nearly eliminate all output from the amp by misusing these controls. How’s that for flexibility?
On top of all that, you get a pair of buffered RCA outputs with an independent crossover with the same cool controls, a heat sink that’s more than just a heat storage device, and an amp that won’t quit no matter how heartlessly you drive it. The amp’s protection circuits cause it to reduce output rather than shut down completely.
Posted on Jun 07, 2008
  • 3,037 Answers
With this amp, the amp’s protection circuits cause it to reduce output rather than shut down completely if it is about to overload. The songs it turns off on, are they much louder or would they draw more power? I think this may be your problem. Does this sound right to you?
  • 3 more comments
  • Benjamin Patri
    Benjamin Patri Jun 07, 2008
    well, the protection circuits are protecting the unit from frying itself, so the only thing to really do to change this is to put a different set of protection circuits in or just bypass them completely but then this will void any warranty and could cause the device to fry. You may just not have enough power to run both cables, do both cables provide the right amount of sound when connected separately? If so, I think it may not be able to handle more than one or it needs more power.
  • Benjamin Patri
    Perhaps the gauge of your wires needs to be changed otherwise, what are you using?
  • Benjamin Patri
    Everything sounds fine with the system. How loud are you playing it? If anything, I would just give the manufacturer a call and see if they would suggest anything else but as far as I can see it is working like it should and you have everything hooked up fine. The gauge is a little more than what I would use but should be fine
  • Benjamin Patri
    Benjamin Patri Jun 10, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • Benjamin Patri
    Benjamin Patri Jun 28, 2008
    free to provide me with some feedback by rating my solution. If you need any
    more help, I would be glad to assist you, just ask.
  • 19,396 Answers
More then rca connection seems to be a problem with speakers
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
Songs allow
Hi Richard
To answer your question of what you need to download and make the songs play:
This player is meant to play mp3 and Windows Media files
To do so, you need the use of a Windows computer with USB port , connection cable (included) and a music management software (MusicMatch Jukebox." Go to the following webpage and download a user manual for your player...it will give you all the information you need.
Note: the 1022 is the same as the RD1076
http://data.manualslib.com/pdf/14/1393/139210-rca/rd1022.pdf?e5480748d51c8c05ea554d37fbbde9b6
Bud
Apr 26, 2013 | RCA RD1076 MP3 Player
I have a jl 500.1 and a 8w7. The sub is playing but not really it will play sometimes but most of the time i am getting almost nothing. Am i using the wrong settings or a bad connection or blown sub?
Sounds like a bad rca connection. You need both rca jacks to be plugged in from your head unit, both left and right or you will not have full power you'll have half power to your sub/subs. Check your sub with a volt meter and see what it reads. Make sure if your head unit has a sub volume make sure it's turned up. Alot of people don't realize they have a seperate subwoofer volume on there deck and it's set to low, so check that. You could have bad rca cables. If all that is ruled out(best way by trying a different amp) the amp itself might be having problems. Don't think it would be in protect mode either.
Let me know if you have'nt allready.
Nov 14, 2010 | Jl Audio 500/1 Car Audio Amplifier
I can hear fuzzy noises in my speakers when i turn them all the way up but when i play a song the song does not play but the green light on the front of the speaker is on
Connect the speakers to some other device and check. if they are playing. then check the Computer connection and connect them in the front.
Nov 03, 2010 | Gateway (G-MAX2000) Computer Speakers
How can i connect a gemini turn table with a ground cable to a input that dont have the ground connection gchristinam@yahoo.com
See if you can attach the ground wire to a point on the chassis of the device you are connecting it to.
Sep 06, 2010 | Gemini XL-500 Turntable
I erased all the songs from this mp3 play to put new ones on after erasing the songs the play won't be picked up by pc and am unable to put new songs onto mp3 plaey the players just displays please wait...
yes...unplug from pc shut mp3 off for a minute...plug it to pc (did it come on turn it on)...please get into the habit of disconnecting any usb connection with the safety disconnect...(green icon in task bar when usb is connected)...since you already deleted all files (format it now) start fresh...now you are able to put your songs on it...but to disconnect do not....do not just unplug the usb
Jun 20, 2010 | RCA M2000 MP3 Player
Player frozen, green light on
i had my GFs mp3 player and it was flashing green light, not solid, but still was frozen and couldnt even bring it up on my computer after plugging in the USB cable. but i just tapped the reset button on top right side, and it stopped flashing and turned off. i turned it back on and started to play normally. not sure if it will be the same since the light situation is different, but the reset button worked for me. good luck
Jan 28, 2009 | Creative Labs ZEN Stone MP3 Player
Rca Connection
You need to check the shield ground on the head unit. The following link will guide you through the test procedure.
Shield Ground Testing
Jun 07, 2008 | Jl Audio 500/1 Car Audio Amplifier
Problem with SD card recognition
Try updating the firmware, you can download it from the RCA Website (http://support.rcaaudiovideo.com/).
If your computer doesn't recognize the player, you'll have to turn it off, remove the battery and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Jun 26, 2007 | RCA Lyra RD1021 MP3 Player
Jl Audio 500/1 Car Audio Amplifier Logo
97 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
