TV Repair do you handle TV repair??? Have a 27" Toshiba that basically does not come on.
  • gdavid7500 Jun 07, 2008
    by the way, I've tried plugging in to different plug, does not come on at all, no sound, no "on"light.
    Novelist:
    Scholar:
  • 100 Answers
Hi there gdavid7500,
BestBuy™ stores are able to send most televisions out for repairs under manufaturer's warranty or a per fee basis. Regrettably most repairs are not able to be done on site and will be sent to a BestBuy™ service center for appropriate repairs.
Hope this helps.
Jon
Go Ahead. Use Us.
Posted on Jun 11, 2008
There are white thin horizontal lines across the top 2" of Toshiba 27DF47 TV. Can this be repaired and how much would this repair cost?
Check and replace all the electrolytic capacitors at its vertical output section circuit. There will be five or 6 of them. Replace all.
Mar 18, 2013 | Toshiba 27DF47 27" TV
Toshiba 27D46 27" TV Problem
it should cost you from $50 for dry solder joints up to about$120 for a rebuild of the vertical stages.
Jul 11, 2008 | Toshiba 27D46 27" TV
I have a Toshiba TV/DVD/VCR combo model # MW27F51-had it for a couple of years. Turned it on, have sound but no picture. I have the cover off the back of it now.
sound like a defective part inside the set. i could tell you what one went bad, this is not user servicable, and could shock you bad. i would take it for service or get a new one. due to the cost of these against the cost of repair.rule of electronics-if the cost of repair is 60% of a new one you should not repair it. good luck! hope this helps!
Feb 27, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Hi
It will not be the picture tube. Your set will have cracked solder joints in and about the vertical output stages. This is not a major repair, and will require re-soldering of that stage, and maybe a few capacitors replaced as a cursory repair as preventative maintenance. should cost between $50-80 depending on who you get to look at it. If you are quoted a price higher than this, I suggest ringing around repair guys in your area and be careful to explain exactly what you have described the fault as here.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
May 29, 2008 | Toshiba 27D46 27" TV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Toshiba 27"
Short answer, nope, very reasonable and quick repair.
To be a bit more specific, chances are that the vertical output IC is dead. It's a relatively easy job and even someone with basic electronics knowhow and a little soldering should be able to do it. In some instances, it just might be a case of cold solder.
If your concern has not been corrected after completion of the above procedures, you may need to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | Toshiba 27A33 27" TV
Black Vertical Lines 2" Thick On Both Sides.....What's Up????
There is a deflection problem that a shop can remedy. Expect to pay about 150 US for this repair...accordianman
Jan 09, 2008 | Toshiba 27A33 27" TV
Tv repair
Hi.
Nice easy repair you have a dry joint on the frame o/p chip.
Just resolder pins on the chip & its repaired.
Oct 21, 2007 | Toshiba CF27H40 27" TV
Tv shuts off
the tv needs a tech to repair your tv it could be anything in the power supply that have burnt good luck.
Apr 07, 2007 | Toshiba 27A34 27" TV
Toshiba 27A45 27"
Lighting ussually does a lot of damage to electronics,if you have homeowners insurance they might cover it and get them totally replace,repairs can be done but can be expensive because of the damaged.Good luck.
Sep 16, 2006 | Toshiba 27A45 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
