Question about Copystar CS-1510 Copier
Copystar 1505 service code J98 sinds one blank copy paper jam on second
  • 148 Answers
J98 means there was a misfeed of the paper, you may have to have a tech look at this to figure out why its jamming, could be poor paper quality, worn feed tire and/or rollers. i would look at replacing the feed tire first that seems to be the problem most of the time...
Hope this helps...
Posted on Jun 07, 2008
How do i fix J98 error in Kyocera KM-1505 copier
This is from the users manual:
"Open the drawer and left cover and check for any misfed paper. If the same indication appears, contact your service representative."
http://www.instructionsmanuals.com/u2/pdf/fotocopiadoras/Kyocera-KM1505-en.pdf
Jan 16, 2015 | Kyocera Office Equipment & Supplies
When i on my copier and pres copy, it print in blank and bring J98 after picking one paper
Jan 16, 2015 | Office Equipment & Supplies
Hi there, the code J in the code refers to "JAM / paper jam" and the number "98" refers to the area where the jam is registered, in this case the jam is registered before the page reaches the drum, that is why it comes out blank, clean all paper sensors and try again.
What happen when kyocera KM-1505 is bringing error code J98
There's probably a time piece of paper or something blocking a sensor or pressing down on an actuator or something
try checking this then do a good clean of the unit.
Jan 16, 2015 | Kyocera Mita Km 1810 1510 1505 Copier Drum...
J98 FOR KYOCERA MITA 1505
Feb 18, 2009 | Kyocera KM-1505 Copier
Kyocera KM-1510
BD steady-state problem • BD steady-state problem is detected. (jam code 98)
BD steady-state problem • The VTC detects a BD error for 800 ms after the polygon motor rotation has been stabilizad.
Poor contact of the connector terminals. Defective LSU. Defective main PCB.
Check the connection of connector CN18 on the main PCB and the continuity across the connector terminals. Remedy or replace if necessary. Replace the LSU. Replace the main PCB and check for correct operation.
Dec 30, 2008 | Kyocera KM-1505 Copier
C 610 Error Code on a CS-1505 copier
There is no 610 code ,there is 620&630 which are fuser problems.press and hold down these keys,stop/reset key /start key/copy density key.Press stop/reset keyb again. enter U163,press start."CLE"will display.Press start again to clear.Exit the mode with 001.
Dec 04, 2008 | Copystar CS-1505 Copier
Km-1505
THE MACHINE DISPLAY CODE J98
Oct 26, 2007 | Kyocera KM-1505 Copier
Feed problem
there is some dust in the paper path sensors or a small piece of paper cn be also in your copier
Sep 12, 2007 | Copystar CS-2114 Copier
Copystar CS-1510 Copier Logo
145 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
