Question about Radio Communications
No recieve on virgin cobra 142 gtl,
Hello, i have a new old stock cobra 142 base, i hooked it up and it worked great, i used it for a few mins, checked to see if sideband was on freq, and i lost recieve," i see recieve on meter," i get transmit, and no its not on pa, it also gets no recieve with extrenal speaker,
i also checked the mic, all mics including stock mic work but no audio on recieve, it happend so quick, any ideas for a quick fix, i have a bunch of donar radios i can take patrs from.
any ideas would be appreciated,
yours truly
Nicky, Cleveland Ohio
  • 1 more comment
  • Anonymous May 08, 2009
    i have a cobra 142 gtl it recieves poorly
    any suggestions ?
  • Anonymous May 17, 2009
    Cobra 142 GTL--no recieve. radio seems to key and has output according to the meter. replaced 7222 and had recieve for about 30 seconds and quit. I swa about a voltage spike. which is the voltage regulator. is it next to the 7222 (to the right ) or is it on the small board? any help appreciated.
  • Bud McWilliams
    Bud McWilliams May 17, 2009
    cobra 142 GTL no recieve--replace 7222 and had recieve for about 30 seconds and went out again
Thank you, i appreciate you efforts to help
yours truly
Nick
Posted on Jun 10, 2008
Seems to me that the audio ic of the cobra 148gtl brokedue sudden change of voltage from power suplly or flactuation. ta7222p
I have cobra ca61 desk mic i need it wired to my cobra 142 gtl home base. the base has 5 pins so i need my mic to be wired for 5 pin... any ideas?
cobra 5 pin to 4 pin adapter on ebay around $5.00
http://www.ebay.com/itm/WORKMAN-C4P5C-CB-RADIO-MICROPHONE-ADAPTER-5-Pin-COBRA-TO-4-Pin-COBRA-/121655850211?hash=item1c5340f4e3:g:e0AAAOxy2YtRsJ8n
Apr 10, 2015 | Cobra Radio Communications
Radio is a cobra 142 gtl s/b turned on switch and no power, check fuse is ok.
Hi, my name is John. Welcome to FixYa. Make sure that you are getting power to your unit by running the wire to the battery, hot (+) and ground (-), let me know if you still have no power and I will post solution here. Thanks for choosing FixYa....John
Nov 15, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
I want to power my cobra 148 GTL in my home, want kind of inverter would I need to do this?, (watts)
you would probably want at least a 4watt continuous power supply or better. do not use as switching power supply.
Oct 23, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
I have a new cobra 148 with ssb, about 6 months old, while i was away there was a storm, now the radio doesnt work , recieve or transmit, i also have a cobra 29 ltd that wont transmit but it will recieve....
make sure the mic is good. If for some reason the mic went bad, it will not receive or transmit.
As for the one with no receive, it most likely needs a new final.
If lightning hit your antron, it would be in pieces.
Aug 02, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
I have an old cobra hooked up worked fine the the
Sounds like you could have a bad soilder joint in the radio. If you hit the top or bottom of the radio does it help? If so its soilder. You match your antenna to your truck not the radio. You might want to recheck it.
Jul 18, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Hello, I dusted off my old Cobra 2000 GTL and plugged it into the wall and it will not power on. The clock is on and adjustable. It was last working before I boxed it up a few years back. Is this a known...
Try this, plug it all up and turn it on, let it set over night, then try it, after a radio has been put away for a while, the capacitors lose charge...hope this was helpful....
May 09, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Have a new cobra 148 gtl took out of box no transmit or recieve
make sure that your [swr] hadn't changed or went higher than a 1.5, anything higher will interfere with your tranmitting an recieving. other than that with out being there to see an hear your radio this would be the first place to start.
Apr 25, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Low dead key on my radio
If it is a 142 GTL your A.M. power is VR6 . Good luck and be carefull and DON'T get carried away remember AT YOUR OWN RISK NO LIFE GAURD ON DUTY!!!! You should'nt have any problems though......Dan
Apr 01, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 132 recieves good poor send
i would take it in and get a new diamond thats what it sounds like to me..
Dec 02, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
496 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
