Question about Toshiba 55H70 55" Rear Projection Television
Convergence ICs Hey thanks for responding so fast. I have all ready replaced both last week which stopped the set from turning off and the red pwr light blinking. Now I just need help to understand what controls the green alignment. This problem started after the set would turn off & the blinking red pwr light. I was watching it tonight and it is only in the center of the screen that the green is stretched to the upper and lower limits of the screen. Would you know what if any adjustments can be made to align the green? I assume the green's alignment is controlled by the circuitry on the board, not by the remote (only red & blue). Can you help?
  • Toshiba Master
  • 8,617 Answers
The green is half controlled by half of each of the convergence Ics meaning green horizontal is controled along with the red and green vertcal is controlled along with the blue Ics. So if you have replaced both Convergencs ICs the problem is most likely a resistor that is in the green circuit. You will need a schematic to locate which resistors are in the green vertical and horizontal convergence circuit
Posted on Jun 07, 2008
Philips 60pp92902/17f television convergence issue
actually your vertical display ic is need to replace them
Jun 20, 2008 | Philips 60PP9202 60" Rear Projection...
Picture and writing in 3d
replaced both convergence ics.the red green and blue colors are not converging.these ics are two big black ics.
Jul 28, 2009 | Sony KP-53V75 53" Rear Projection...
Line red,yellow,green are all over picture and images
No you will need to replace the Convergence Ics and possibly some of the 12 feed resistors. You can get the repair kit for your model at the following link which contains both cinvergence ICs and all 12 resistors plus free instructions with pictures so you can do the repair.
May 25, 2009 | Philips 60PP9202 60" Rear Projection...
JVC AV56-WP74 Convergence problem
Hello saduchan,
I think that your ICs are ok, What you need to perform is what is called dynamic convergence, This involves using the internal convergence controls to align the outer edges of the screen. I am assuming that the center of the screen is ok? it's just the edges which are misaligned, right? Now for the bad news, this task is not easy in fact the job takes a pro about 6 to 12 hours to do it right. I think you should have a qualified TV technician attempt the static convergence setup followed by the dynamic convergence setup.
I hope this helps,
Thank you,
Dec 29, 2008 | JVC AV-56WP74 56" Rear Projection...
It sounds as if your convergence ICs have failed again,However if you didnt replace the convergence resistors with the ICs that is most likely the cause of early IC failure. There is a quick test to determine if the ICs have failed. Remove the front speaker panel and access panel up front, and you will see the convergence panel with the two black heatsinks. Directly in front of those heatsinks are three wire clips that are for the convergence yokes, Unplug those three wire plugs and try turning on your set. If it comes on the ICs have failed, and the ICs and resistors should be replaced as a kit. You can get the repair kit for the JVC rear projections at the following link with free instructions. Heres the link.
Let me know if you need more information.
Jul 23, 2008 | JVC AV-56WP74 56" Rear Projection...
If the red isnt responding via the remote you will need to replace the STK392-110 Ics as the service menu adjustment will not correct it 100% due to the IC being faulty and the red and half the green is controlled by one IC and the blue and other half of green is controlled by the second IC so without changing both ICs the set will progressively get worse. Both ICs are stk392-110. You can get replacements at the following link along with instalation instructions
Jul 13, 2008 | Toshiba 55H70 55" Rear Projection...
Hitachi 42" TV
This is a problem with the convergence circuit. If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These ICs are large and black, attached to a heat sink and are marked STKxxx.
Keep us posted on your progress.
Jun 19, 2008 | Hitachi 43FDX01B TV
Red Convergence problem
replace the convergence ICs. I can post a link where you can get the ICs with free instructions on how to change the ICs yourself. Its an easy repair takes less than an hour from beginning to end.
Apr 01, 2008 | Apex Digital GB5108 51" Rear Projection...
Blue red and green lines thorugh 1997 Sony 50" rear projection
Confirmed Hitachi subs all STK392-110,120 and 150 to
STK394-160 ....I use Hitachi part number CZ 01341 = no re-calls
Feb 19, 2008 | Sony KP-46WT500 46" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
101 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
