Question about Whirlpool Dryers
Whirlpool gas dryer LG5801XS
Looking for a wiring manual or diagram for repairs. Any suggestions?
    Genius:
  • 1,028 Answers
Look under console if has a bottom panel could be on back side of it
Posted on Jun 07, 2008
Need a wiring diagram for a whirlpool gas dryer model ggq8811lwo
If you open the control panel heading there should be a wiring diagram and a tech sheet inside. In some rare occasions these sheets may be inside the cavity of the dryer.
Jun 20, 2012 | Whirlpool Dryers
Whirlpool Gas Dryer I need the wiring diagram of Whirlpool WGD 5000
Here is a link to your diagram, Whirlpool prints both gas and electric models on the same page, since yours is gas use the bottom diagram.
Let me know if you have questions.
Tech_Sheet_01_20_2010/Wiring%20Sheet%20-%20W10185979.pdf
May 05, 2010 | Whirlpool Dryers
Dryer runs but no heat just quit working
check for the clicking noise upon starting
if not heard the spark ignitor is bad
Mar 11, 2010 | Whirlpool LGR3624JQ Gas Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
No heat in gas dryer
hey it dose not have a pilot your dryer has an ignitor.if you have a volt meter with the ignitor exposed you need to check voltage to the ignitor.if voltage replace ignitor,if no voltage re place thermal fuse you can see how the electricty travels by looking at thr wiring diagram
Dec 31, 2008 | Whirlpool LGR8648 Gas Dryer
Gas dryer not turning
I can explain how to do this but I would suggest going to the library and looking for a generic repair book with diagrams. It's hard to explain but very easy to do. Most Whirlpool, Kenmore and Roper dryers are basically the same as far as belts and moving parts. The only difference is the features. What you neet to know applies to both gas and electric dryers. You should also replace the idler pulley and both rear drum rollers while you are in there. One of these probably caused the belt to break. Your dryer will run so quietly after this you will hardly know it's running You will also need the diagram on the belt package to replace the belt as it is very tricky the first time especially if you haven't seen it in place. Replacing all the parts I mentioned will cost around $20 - $35 and take about an hour. While you have it apart clean out all lint and check vent hoses and outside damper. DO NOT USE FLEXIBLE PLASTIC DUCT PIPE!!!!!!! It is now against most building codes for darn good reason. It's a fire hazard!
May 15, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
165 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
