Question about Compaq Evo N610C Notebook
How to repair or Install OS without a working internal CD/DVD drive?
Have 2 notebooks that have lost the functionality in their CD-DVD drives.
How to set up for external USB drives?
  • 191 Answers
You just have to get USB cd-dvd drive and can connect to any usb port on your systems
pls provide info regarding ur system
Posted on Jun 07, 2008
I have an Dell Inspiron 1100 Notebook. It dosen't have an internal CD/DVD-Rom Drive. I would like to re-install the OS using and external USB cd/dvd Drive. Can this be done, and if so how do I go about...
You can install the operating system using an external CD/DVD drive. for dell systems, make sure you have the external drive connected then when you turn on the computer press F12 to access the one time boot menu. on the boot menu choose the option for CD/DVD drive. after pressing enter it will prompt you to press any key. once you get to the welcome page just follow the onscreen instructions to install a fresh copy of windows
Mar 27, 2011 | Computers & Internet
I want to reformat my Acer Aspire One without removing the OS (Windows XP), meaning to say, I just want to wipe out all the documents, unnecessary files, and programs. I don't have a recovery CD, plus,...
HI,
Dont warry friend you can format your drives.Just you goto my computer and then format drives but dont format booted drive.
Otherwise u install another os and then go to old os and format that os.If u dont know how to install 2 os again call me i wil tel u.
If u satticfied please vote me brother.
Dec 17, 2010 | Acer Aspire One PC Notebook
Will not start up, has a flashing folder with a question mark
This means that your internal hard drive is not currently bootable. That can happen for a variety of reasons, which are:
  1. The disk has crashed and is no longer usable.
  2. The Mac OS X System Folder has become damaged due to permission problems, a botched software upgrade, or some other software-caused problem.
  3. The hard drive controller on your Mac's logicboard has failed.
Without knowing the model of your Mac, I can only guess what is going on here. To know for sure, you need to locate your original Apple software restore CD/DVD -or- a retail Mac OS X install DVD.
Do the following:
  1. Power on the Mac, insert the bootable CD/DVD.
  2. Hold down the power button until the mac turns off.
  3. Hold down the "C" key on the keyboard and press the power button to turn the unit on.
  4. It will take a while, but your Mac should start booting a copy of Mac OS X off of the CD/DVD.
  5. Once booted into the Installer, locate the menubar at the top of the screen. Click on the "Apple" icon (top left of screen) and click "About this Mac". Click the "More Info..." button.
  6. You should now see the Apple System Profiler.
  7. On the left panel, locate "ATA" or "Serial-ATA". You should have one of them contained within your Mac. When you click on the correct one, you should see the list of hard drive controllers (two), one with your CD/DVD rom listed, and the other with your hard drive listed underneath. If you don't see two controllers, one or both of your hard drive controllers have failed and you need to send the Mac to Apple for hardware repair.
  8. If you DO see your hard drive listed, then you hardware is at least working. That rules out a failed hard drive controller and mostly likely your hard drive is physically intact. The software on it might still be wrecked, but the hardware appears to work.
  9. Close "System Profiler" and get back to the MacOS X Installer. Click on the "Tools" or "Utilities" on the top of the menu bar. Locate "Disk Utility" and launch it.
  10. Within Disk Utility, locate your hard drive on the left side of the screen, click on it once to highlight it and then click the button "Verify Disk". This will do an exhaustive search against your drive to see if there are any problems with the Mac OS X installation. If there is still a copy of Mac OS X left to salvage, this will tell what the problem is.
  11. If "Verify Disk" finds an instance of Mac OS X with problems, you can try running "Repair Disk" and then "Repair Disk Permissions" to clean up any problems with the copy of Mac OS X. Keep in mind, when you have filesystem problems, sometimes fixing the problems can make permanent changes to your filesystem that have unintended consequences.
At this point, if your hardware is intact and you have a filesystem problem, the safest thing to do is to go find a firewire drive big enough to install a copy of Mac OS X on it (anything larger than 10GB should be fine), install Mac OS X to the firewire drive and then try to mount your internal hard drive while running from Mac OS X on the firewire drive. This assumes that you have files on the internal drive that you don't want to lose. If this is not the case, you can safely reinstall Mac OS X on your internal drive and start over again.
May 30, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
XP is corrupt and needs re-install. DVD drive is dead. Can I boot from a USB stick and are there specific settings (I tried using default settings for WinsetupfromUSB - boots to my Dell D530 - nothing on...
it would be easier to use an external dvd/cd drive if in case your internal dvd drive is defective. thereon, you can start re-installing the XP OS using the external dvd/cd drive. hope this will help your problem. thanks
Feb 08, 2010 | Toshiba Satellite A75-S229 Notebook
LG DVD/CD RW working with DVD but not with CD
your dvd rom's lense were damaged so if it is in warrenty period then go to servce centre for repair otherwise go to local repair for changing of dvd lense......
Feb 06, 2010 | LG (GDR8164B) Internal DVD Drive
Usb dvd writer can install xp?
Yes you can use a usb external cd/dvd-rom to any operating system as long as the bios allows you to, most bios's have the capability.
When the external usb drive has been connected power up the mechine, in post it should tell what to press to enter your boot menu without entering your bios and choose usb drive to boot.
Jan 22, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Trying to boot from external dvd drive
u must either have one of the foll...to boot and install OS...also the seq in BIOS must be availabe and enabled
1 Floppy
2 CD Rom Drive - internal
3 CD Rim Drive - External connected thru USB
4 You can also try to connect a USB pen drive having the OS install program and try - I have not tried that so not sure if this option works...sorry
5 If u can open the machine then u can connect another internal HD(this can contain ur OS install files) to the cable (connector points in the flat cable) that connect your internal HD to the Motherboard.
if i can think of anything else i will post
all the best
Dec 31, 2009 | Dell PowerEdge 2600 Server
My Cd/dvd drive has quit working.
If you are willing to buy a new DVD/CD drive, you can find it easily, only thing is you need someone to get it installed in your laptop.
One question is, whats the exact problem you are facing, please let us know the details, its quite possible that it would be resolved without even buying a new one.
1. Laptop model/CD Model make ?
2. OS/
3. How much old it is?
4. Stopped working after something like shock or just stopped ?
Thanks.
Mar 16, 2009 | Toshiba Satellite R15-S822 Tablet PC
Ways to load OS
External Floppy disk drive or External CD/DVD drive. Might be easier to just replace the internal drive.
Feb 17, 2009 | Dell Inspiron 4000 Notebook
Internal laptop CD/DVD combo drive problem
1. uninstall dvd/cd using device manager reboot and winxp will reinstall driver 2. go to my computer / dvd drive / right click / properties / hardware - roll back or update & properties - enable digital cd audio / recording - enable cd recording 3. do system restore start / all programs / accessories / system tools / system restore 4. do full system recovery - us windows xp OS
Nov 23, 2006 | Acer (91.AB264.016) Internal 24x CD-ROM...
Compaq Evo N610C Notebook Logo
60 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
