Question about Sewing Machines
Juki MB-373 Button Attaching Machine
How do I adjust the machine to sew though much thicker fabric such as tacking in drapery pleats?
  • Anonymous Mar 24, 2014
    how to attached a single upturn hemmer on a juki machine
    Problem Solver:
  • 26 Answers
Use a thicker needle.
Release the looper screw and move it back and close to the needle, but without touching.
Tight the looper screw.
Adjust the needle through (left and right) wider.
Posted on Jun 09, 2008
Part list
Posted on Aug 10, 2010
Juki industrial sewing machine. Machine will start sewing but after three stitches it stops.
You may need to adjust your tension dial with your fabric you are using and kind of thread, also adjust to thickness of fabric. Always use good sharp needles with your sewing and keep machine clean and oiled.
Feb 02, 2015 | Juki Sewing Machines
Juki Bar Tack Machine Cutter not working
I can't help. But I would recommend calling your local Juki Dealer for the name of a good repairman. Juki's are expensive you don't want to be futzing about if you aren't an expert.
Nov 29, 2012 | Juki Sewing Machines
Every time I try to sew my bobbin is knotting up. What can make this happen?
yes, & the thread may not be the right kind for the fabric, also the tension would have to be adjusted to meet the needs of the thread & fabric
Mar 13, 2012 | New Home HF-3000 Computerized Sewing...
What is a walkimg foot machine
A walking foot is a foot with feed dogs, or a similar fabric moving mechanism. This is useful when there are many layers of fabric or slick fabric. Then the top layer of fabric can be made to travel at the same rate as the lowest layer (the feed dogs) or an slightly different rate. Then the fabric layers will stay even for the entire length of the seam.
A walking foot sewing machine has this feature built in. Thus you don't need to adjust extra hardware to keep your fabric aligned. (On some, specific feet are needed to use the feature. However, it is easier to adjust than the separate walking foot that I have for my older Singer sewing machine.)
I hope this helps.
Feb 21, 2012 | Juki MO-644D Mechanical Sewing Machine
Needle keeps breaking when sewing
Make sure the needle is in correctly. On most machines the flat part goes towards the back of the machine. Also make sure you are using the correct size needle for the type of thread and fabric you are using. Thicker fabrics such as denim and upholstery fabrics will require a thicker needle, like a 100 (16).
Sep 04, 2010 | Juki TL-98QE Mechanical Sewing Machine
Sewing with drapery material
Switch back to regular thread. Upholstery thread is used for seams that will get lots of stress (as in upholstery; although I use regular thread in upholstery and have no problems). For draperies, regular thread is fine.
Jul 24, 2007 | Husqvarna Viking 1
Sewing Machines Logo
417 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
