Question about Gateway FPD2275W LCD Monitor
Monitor I purchased a new HP PC with a digital Samsung monitor. IThere is power to the monitor and it worked for a few days but now the power light is flashing. When you hit SOURCE it flashes analog/digital. There isn't an analog option on this PC. How do I get the monitor to operate properly?
    Scholar:
  • 47 Answers
Double check the monitor cable, both going to the monitor, and going to the computer. Ensure it's securely connected. If this doesn't change anything, try rebooting your computer. When the power light flashes, it's in sleep mode and doesn't detect either an analog or digital signal - so either your computer has gone into sleep mode (you can awaken it by hitting any key or moving the mouse) or the cable isn't attached securely. Since your computer is brand new, it's unlikely that anything has broken down already. Another thing to check is to make sure that the resolution in your Display Settings is the correct resolution for the monitor - although it's hard to do this if you can't see what you're doing.
Best of luck, hope this helps!
Posted on Jun 10, 2008
No vga input on working monitor
Turned on computer (Pavilion a1657c), HD light operates, Monitor has little window saying:
HDMI Input: No Input Signal
VGA Input: No Input Signal
Recommended Settings: 1920x1080 - 60hz
Changed from the monitor that came with it (HP f2105 digital ouyput) to my Samsung analog and same message comes on dark screen.
Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Computer Support
Mar 21, 2014 | HP Media Center m7657c home PC - RC640AAR...
No input signal recommended settings hp vs15 monitor 1024x768 60h
old monitor 1280 x 1024
power light on?
OSD work?
if it said on the screen no input sig, then that is 100% true
the PC is not sending output.
check the video cable connections both ends
then if bad, boot PC to safe mode. does that work.
then maybe you set the PC graphic resolution too high for the monitor. use safe mode to set new , legal resolution
1280 x 1024 is max, do not exceed, the horz, vert, reso to the left here. if you do the monitor , will display, out of range. errors.
im confused, you show HP monitor then Sam.
why ?
my guess is HP question posted in SAM section.
so here is my HP answer
1280 x 768 @ 75Hz
if your PC or other device exceeds any of those. this old monitor
will go blank.
HOR, vert and refresh rates max.
to solve this riddle, set the PC to
1280 x 768
then connect monitor and bingo.
but there is a chicken and egg deal here.
if the display car is over this, as most new systems are.
then use safe mode to set the resolution to 1280 x 768
and reboot to normal mode.
boot and it F8 , safemode.
Sep 25, 2013 | Samsung SyncMaster 960BF (White) 19" LCD...
My Samsung SyncMaster 205 bw monitor was working a few days ago. And the suddenly some black and white slanted stripes appeared on my monitor. I shut off my PC and rebooted it and nothing came up. My blue...
Sounds like your monitor has croaked. Borrow a monitor from a neighbor, friend or family member just to see if it works. If it works, your monitor is bad. If the borrowed monitor has the same issues then your Video Card in the computer is bad and needs to be replaced.
May 01, 2012 | Samsung Computers & Internet
Purchased new hp elite d5200t desktop. monitor
you have no video from the pc try changing your video card or try getting driver for the monitor
Jan 13, 2010 | Samsung SyncMaster 152N 15" LCD Monitor
Samsung 226BW won't turn on until a few minutes.
This is an indication that the power board in the monitor is bad.
Mar 02, 2017 | Samsung 226BW Monitor
Samsung 226bw weird display problems
At first you should clarify if your GPU or LCD is broken.
Do You have any chance to try another monitor with your Graphicadapter or to try your monitor on a different PC?
Moreover you should try it with a new cable.
The symptom of weird symbols sounds most likely like a overheated or wrong-plugged Graphicadapter
Nov 20, 2008 | Samsung 226BW Monitor
Sudden power shut down/will not power up
Try these steps :
1. Disconnect the AC Adapter.
2. Remove the Battery.
Note : Please see that there are no external devices or cables connected to the Notebook.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
If the Notebook doesnot start fine, we may have to need a Desktop monitor to check whether the issue is with the LCD, Graphic Card or the Motherboard itself.
Connect a Desktop Monitor to the VGA Port of the Notebook and press FN + F4 key to get the display on the Desktop monitor after the power button is pressed.
If you get the display on the Desktop monitor, the issue is with the LCD of the Notebook.
If there is no display either on the LCD or the Desktop monitor connected, the issue can be either with the Graphic Card or with the Motherboard itself.
Confirm if the Notebook is in warranty or not.
There are some known issues with few HP Pavilioin Notebooks installed with AMD Processors.
Try the link below and contact HP Chat Support if the Notebook is purchased in US to get it repaired for free :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01087277&dlc=en
Check the Product Number if it is listed among the once listed in the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=c01300427#c01300427_
You can get the Notebook repaired for free if it listed among these numbers and is purchased from US.
Hope this helps...
Aug 13, 2008 | HP Pavilion dv6000z Notebook
Once Standby mode shut down Monitor will not operate for a few days
Problem is maybe caused by electrolytic capacitors in PSU you can inspect them visualy if their top is blown then they are defective you can easily replace them.
Good luck.
Nov 14, 2006 | Samsung SyncMaster 173P 17" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
148 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
