Question about GE DVL223EBWW Electric Dryer
GE DVL223EBWW Hello, Dryer is working and heats up. It is making a thumping noise. Removed the top of dryer and watched it operate. As tub cycles around, it looks like it is bouncing off it's rails or seems to be loose on whatever guides it to turn. Any suggestions on what to look for and the level of repair? Pat
  • 8220 Answers
To access these dryers you open the door and look up at the 12 oclock position and their will either be 2 or 4 screws holding down the top. These must be removed and then you can get the top to come up(or off on newer models). Once you have the top up you can get to the screws which hold the front on (2). Then you simply remove the front and get it out of your way. On these dryers there is a friendly rear hatch to help you replace the idler. As far as the thump tha could be from anything. Once you get the dryer apart you should be able to locate and remedy the problem.
Posted on Dec 22, 2008
  • 207 Answers
SOURCE: ge profile dryer dpgt750gc1pl
Is your dryer gas or electric? I think based on your model number, it possibly looks like your dryer is gas. Regardless, you need to look at what the service mode troubleshooter tells you. To access it:
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
Let me know what it tells you and I can help you further from there.
Posted on Apr 16, 2009
  • 384 Answers
SOURCE: ge dryer dvl223ebww hear buzzing sound when trying
motor capacitor bad
Posted on May 06, 2009
  • 547 Answers
SOURCE: GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
Posted on May 17, 2009
  • 193 Answers
SOURCE: G.E. Gas dryer starting making thump noise when drying,
The drive belt has lost some of its rubber ribs, you need to replace the belt
Posted on Sep 30, 2009
Kenmore electric dryer got really hot and stopped working?
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
Sep 19, 2011 | GE DVL223EBWW Electric Dryer
Dryer makes banging sound as drum rotates
The drum rollers are worn out and wobble when should be more of a thump/thump sound, unless really are almost gone...UNPLUG dryer and raise top...Since no model. i'm going with standard kenmore/whirlpool dryer type. The top has two screws by lint filter..Remove these and raise top...The front can be removed by removing two screws inside each front corner. The door switch must be disconnected at wiring..Remove front and set aside...The drum can be removed after the belt comes off...look down in right rear corner under will see the belt pulley and you want to see how it goes around pulley to help reinstall..remove belt, there will be tension and make sure you draw yourself a diagram of path of belt to ease install of once belt is removed, you can pull out drum...there are two drum rollers. They are bad if you roll them and they wobble and make noise. They should be almost quiet when you roll them if they are good..the belt roller can be bad and squeek...check this as well...replace parts and reinstall
Jan 31, 2011 | Dryers
My dvl223ebww makes a scratching noise whenever I use it. Any idea what the problem might be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 06, 2010 | GE DVL223EBWW Electric Dryer
The top of the dryer gets hot when temp control is not set on off
One of your heating elements has broken and welded itself to the heater housing. When the timer is activated L-2 powers the remnant through the timer to the neutral. You need to unplug the dryer and fix the heater element. 9b8cf19.jpgbc36f64.jpg97143cb.jpg
Jul 26, 2010 | GE DVL223EBWW Electric Dryer
I have a ge dryer model dvl223eb6ww. It has gotten very noisy and sounds like somwthings rubbing or its struggling . any ideas?
Check the belt tensioners pulley for the bearing in the idler pulley does freeze upo causing a thumping sound when they go bad
Jun 15, 2010 | GE DVL223EBWW Electric Dryer
either your heating element,cycling heat switch,hi-limit switch,or thermistor are defective also check power input for 240 volts,if one leg 120 volts is missing it won't correctly
Oct 31, 2009 | GE DVL223EBWW Electric Dryer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Tub making noise. How do I get to the pulley/ belt to oil the thing?
is this a gas unit or electric?...the pulley is normally accessed through the front. if you go here and click on the repair man on the left side they will have the information you need on accessing and replacing the parts needed please rank
Jun 14, 2009 | GE DVL223EBWW Electric Dryer
GE DVL223EBWW Electric Dryer Logo
49 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
