Question about Sharp Televison & Video
I just purchased this LC-32SB24U television and two of the channels no longer have volume. Just channel 47 and 48. They worked at first ( approx. one week). Freida
  • 126 Answers
May be bad tuner not sure on this model if you can re -solder
ground points or not
Posted on Jun 07, 2008
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
Deleting unwanted channels
Click menu, setup channel, add or delete channel.
Aug 13, 2014 | Sharp LC-32SB24U 32-inch 720p LCD HDTV...
I need to do a channel scan on my tv to get the service working but i cannot find channel scan options on the menu. Where is the channel scan option on the sharp LC-32SB24?
During power up and first time use, there should have been an option for channel scanning as the initial setup wizard began.
Alternatively, there should be a way to navigate to the channel scanning menu by selecting, Menu>TV>Auto Channel Search. I couldn't get the exact info from the model you listed, but I gathered this info from a similar owner's manual (lc-32sb28ut) from the Sharp webpage: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Hope this helps.
Oct 17, 2010 | Sharp LC-32SB24U 32 in. LCD TV
My Sharp LC-32SB24U will not power on from the remote. It will work if you push the button on top. I have another sharp lcd in the house and I tried that remote also but it still will not turn on from the...
You have to unplug the television after turning it off. Take the batteries out of the remote control. Point the remote toward the remote sensor (bottom right hand corner of the television set). Press the power button on the remote control and hold it down for 30 full seconds. Next press and release every button on the remote control. Next plug the tv back in and power it on from the power button on the television itself. Replace the batteries. Adjust the volume using the remote control. If that works the problem is solved. If it doesn't work you may need a software update, a new remote control, or repair to the sensor on your television.
To see if your remote control is working look at it through the viewscreen of a digital camera. The digital camera must be turned on and ready to take a picture. Next press a channel button on the remote control. Do you see a bluish white light? If so the remote control is ok.
Jun 01, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Sharp 32 inch lcd tv won't reconginze channels when connected to antenna. Why? The screen now looks like a defragmenting on a computer screen.
You probably need to do a channel scan to find TV channels and progrma them to the TV memory. Using your remote control select Menu mutton and follow instructions for "auto channel scan"
Jan 17, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Have Sharp 13" tv about a year old. Only arrow on remote that works is volume up. Volume down and channel arrows do not. Power and punch in channel numbers do work
If you can get the remote apart try cleaning the contacts on the inside of the touchpad and on the circuit board with alcohol and cotton swabs.If this doesn't work you will need a new remote.I assume the buttons on the TV itself work.
Dec 01, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Sharp LC-32SB24U TV. Remote no longer functions.
Unplu the TV from the wall, wait for 30 sec. plug it back in.
Nov 07, 2009 | Sharp 32C-240 32" TV
TWO CHANNELS (CABLE) SOUND NOT WORKING
Try turning off the tv and unplugging it for one minute, if that doesnt resolve the issue, look into gettnig a converter box, or a signal booster to help. The tuner's in those SB model sharp televisions are not worth a penny and they need a very strong signal to be able to interpret all of your stations without problems. good luck 2 u
Jan 22, 2009 | Sharp LC-32SB24U 32 in. LCD TV
No display on Sharp LC 32sh20u
blue screen,no video but has sound
Dec 18, 2008 | Sharp LC-32SH20U 32 in. LCD HDTV
Televison & Video Logo
16 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
