SOURCE: looking for an explanation for diagnostic code PO374 2004FLHT
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
CKP= Crank Position sensor.
Check connections, etc.
SOURCE: My check engine light goes on sometimes and then
on your dash is the button to check your milage. push it in and hold it down until your codes come up. some of the numbers it will go through will only be ecm numbers
Testimonial: "exactly what I needed. Thanks,"
SOURCE: engine light on start up
if you are no longer setting a current code then I would not worry ! Your system will send the fault to historic after 50 run cycles and you will no longer have the engine light coming on the second time
SOURCE: I'm throwing two codes in diagnostics. In"s" the
The PN is a part number of a part that needs to be replaced. The 68920-07 is a turn signal moduale and the 67557-08 has been superseded by 67557-08A and that is the speedo unit. Contact your harley dealer for information as to getting it in to them for the repair. It may be covered under a recall or warrenty. I hope this answers your question.
SOURCE: after motocycle is started the engine light goes
Could be low oil level as the oil heats up the pressure level drops and turns on the light. It may be just needing a little to bring it back to full. Check the oil level if it is low add some oil and start the bike and try again.
