Router environment to support Windows and Mac
I have a PC and a laptop running Windows XP Professional. I also have a G3 iMac running OS9/X. I have high speed cable modem service currently connected to the PC. I'd like a secure wireless environment that will support all the above. I'm pretty savy and confident I can hook everything up; I just don't know what all I need. What do you recommend?
Thanks in advance
  • 6,487 Answers
You just need to access the router setup page and configure the wireless security for it, I suggest you use wpa as the security mode which is a much higher security mode that will amke your network secure, then after that connect to your secured wireless network.
Posted on Jun 07, 2008
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at http://asu.info.apple.com. Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
Oct 27, 2010 | Epson Stylus RX580 InkJet Photo Printer
When i open the google site i can not read all words in my ibook g3. i can see only question marks. how to solve the problem? please help me.
The problem most likely is that you have quite an old browser, so we just need to get you a better one that can run on your operating system.
If you are on OSX, then you should try Opera from here
If you are on OS9, then you need the awesome iCab which you can download from here
Regards.
Aug 08, 2010 | Apple iBook G3 Clamshell (M2453B) Mac...
I want to use old software and requires 0s 9 can i install that if mine has 0sx on now
It just depends. If, when the HD was formatted, it had the OS9 drivers installed then the answer is yes.
If on the other hand, the HD was wiped and reformatted without the OS9 drivers (it's an option in the formatting panel) then you won't be able to install OS9 without wiping the HD and reformatting.
Try to install OS9 - if it goes in you are OK, if not, then you will have to reformat and start again. - (losing any OS X software that might have been added extra)
Mar 27, 2010 | Apple iBook G3 Clamshell (M2453B) Mac...
Apple Mac PowerBook G3 M5343
since apple drives are formatted in HSF+, a file system that windows cannon read, the chances of it even being bossible to run anything on it from a PC is very very slim.
Jan 18, 2010 | Apple PowerBook G3 Mac Notebook
I have a ibook g3 clamshell laptop. I am trying
The G3 iMac clamshell speaks 802.11b wireless signal only. If your router is an 802.11n router, this symptom is known to occur, especially if you have any level of encryption (WEP, WPA, WPA2) on your router signal. Try temporarily turning the encryption off on your router and disabling N mode (set to G mode only) and see if this solves your problem. If so, obviously you don't want to leave your router unencrypted, but you may have to leave it set to G mode as long as you want your clamshell to be able to access it.
Nov 17, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Will Virtual PC for mac v7 work with an new iMac (Mac OS X, Version 10.5.7)?
Basically, if your new iMac has the new Intel processor (or any Intel based processor Macs) your Virtual PC v7 will not work on it. It is designed for iMacs/Macs that are not Intel Based machines (that run on the Motorola processors like the G3, G4 lines, etc).
All Intel based iMacs/Macs are capable of running Windows using a Dual boot startup that is available at the Mac Store or online. Check the Apple website for instructions, they are always updating the software. :)
Jul 19, 2009 | Microsoft Virtual PC 7 with Windows XP...
Can i play Civ II on my brand new mac?? or do i need an older mac
Civ II is a fairly old game. It seems that your PC runs Windows XP or earlier. It is likely that the site you read was correct, and your computer is too new to run it. However, you may be able to get another newer version of Civ for Mac, but check the system req's for any game you try to install. I don't know for sure if this is the case, but I hope this helps you somewhat.
Jun 01, 2009 | Macsoft Civilization 2 Gold for Mac
Imac g5 model:a1058
iMac G5's cannot run windows alone, but older software can be purchased like Virtual PC to run windows on that unit.
Aug 05, 2008 | Apple iMac G5 Desktop
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
