Question about Palm Tungsten E2 Handheld
Tungsten E2 will not power on
My Tungstern E2 will not power on. I tried charging, soft reset, hard reset
and still nothing. I had a full charge when I turn it off, then later that day I went to pwer it on and it was completly dead. When I hooked the charger to it normally I would hear a beep, but I hear nothong at all. I called Plam support and the only thing they would was to send it in for service along with $149.00, I paid $249.00 for it in April 2006 and don't feel it's right to pay another $149.00. Help!!! Help!!! what can I do?
  • 38 Answers
The Tungsten is an excellent PDA
You do have to be careful with how you handle it if you've dropped it too many times or set it down too hard or whatever something inside will get cracked or disconnected.
So you may want to open it up (personally I use a really small screwdriver but there is a kit for 9.95 on PDAsmart.com that comes with a Shim like tool that is really useful for splitting the Tungsten open because its not easy getting it open and closed)any way open the back up and make sure everything is connected and clean especially the connectors to the screen, battery and USB/charging plugs. You may also need to try charging it overnight. If you haven't run the PDA in a while its going to read a full charge regardless of how much of a charge its actually holding. Also, there are alot of other places to get A PDA repaired do a little research and find a place near you that will repair a PDA. An official Palm repair is almost always going to cost you more than anywhere else.
Posted on Jun 20, 2008
My palm tungsten e2 does not power on at all? what is the solution. i tried soft reset. it did not work out.
It could be the battery. may be the charger is stuck ,did you Connect the E2 to the charger then soft reset ?this should reset the charging circuit on the Palm.after that Let it connected to the power adapter for a good 2 hours. After that, disconnect the Palm and see if it will turn on. If not, then you need to get a replacement battery for your Palm.hpe this helps.pls do let me know thanks
Jan 12, 2010 | Palm Tungsten E2 Handheld
My Palm Tungsten E2 does not turn on.
Have you tried doing a soft reset? To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld.
Jan 09, 2008 | Palm Tungsten E2 Handheld
Touch screen does not accept input
Check if the device is charged to full.
Recalibrate the screen. Remove the Screen protector and calibrate the screen.
Perform the Soft Reset on the device.
Perform the Hard Reset on the Device.
Sep 20, 2009 | Palm Tungsten E2 (Multilingual) Handheld
My tungsten E won't turn on. If I do a soft reset it turns on then off immediately. I just charged it yesterday!
After back up your date you may perform hard reset, if issue still persists you can be sure that battery is no longer giving good performance. So you may consider replacing the battery.
If you need further assistance please post.
Good Luck
Jul 03, 2009 | Palm Tungsten E2 Handheld
Tungsten E2 wont power on
Turn it on pressing the reset at the same time or take out battery and unplug/plug the battery. Your battery may have died. If this is helpful, post as such. If it is a fixya, post as such. I had an E2, can tell you alot about it. TY
Jan 23, 2009 | Palm Tungsten E2 Handheld
Palm will not turn on
have you tried a hard reset?
Todo a hard reset, First press and hold the power button, while holding the power button use the tip of the stylus to gently press and release the reset button. wait for the logo to appear then release the power button.
when you see the message that warns you about erasing all of the info on your hand held press up on the 5way navigator to finish the reset
Dec 21, 2008 | Palm Tungsten E2 Handheld
Both PalmOne E2 Units No Power
Your problem is more common than you think. Especially being a potential battery issue. Can you say a bad case from factory. Go to EBAY and order 2 more batteries. You are lucky they plug in.
Oct 19, 2008 | Palm Tungsten E2 Handheld
My e2 frozen on the palm powered logo
Okay here it goes, your going to want to leave it on for however many hours it takes to completely drain the battery then you're going to want to recharge it back to normal charge, and try restarting it again. This will delete completely anything that is keeping it from restarting properly. If you did open up the machine without following "antistatic procedure" you may have fried a component on the board and then your in trouble
you'll need to salvage a board from another tungsten and put it back in your PDA and hope you put it back together right
May 28, 2008 | Palm Tungsten E2 Handheld
Won't turn on I press the power button
Press the reset button on the back of the unit with the stylus tip.
Apr 23, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2 won't work after power cord is removed.
The traditional steps for resetting charging problems are:
1) press reset /while/ the power cord is plugged in
2) unplugging the battery for about 30 seconds, then plugging it back in
You have done #2, but I do not know if you have done #1. Try it, then try to recharge again. If that fails then you probably need a new battery. I have found them on eBay before.
Feb 22, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Palm Tungsten E2 Handheld Logo
248 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
