Yes..an allen wrench was supplied with this unit (I believe its just a standard 1/4 " allen) it goes underneath, in the center, and turn in both directions to free clogged unit(do not turn power on while doing this!)
I would also check your trap..could be installed to high, and letting water stand in diposer (or just clogged trap)
Yes that is right. keep turning the allen wrench untill it turns easily. then push the reset hard and try it. you dhould hear the unit run. if its running and you still have standing water, the the drain lines have plugged.
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
f
heatman101
