Question about Whirlpool Kitchen Ranges
The control panel on my gas range does not work the light clock works the stove works but the bake and broil does not i cant get the oven to start and it is not self cleaning but it has a lock button it says to hold start for 5 seconds but that did not work
  • 868 Answers
IF ,WHEN YOU SELECT BAKE ,DOES THE BAKE COIL GLOW RED??????? IF YES IS CORRECT, THAN REPLACE THE BAKE COIL(IGNITER).SAME FOLLOWS FOR BROIL. PLEASE RATE THIS!!!
Posted on Jun 07, 2008
3 Suggested Answers
  • 184 Answers
SOURCE: Freestanding Electric Maytag Stove /Oven (with 4 burners self clean w/clock)
I WOULD LOOK AT THE DOOR LOCK ASSEMBLY AS THE DEFECT. THERE IS USUALLY A SWITCH THAT TELLS THE CONTROL IF THE DOOR IS LOCKED OR NOT. IF THE SWITCH HAS SHORTED CLOSED, THE CONTROL THINKS THE DOOR IS LOCKED AND WON'T DO ANYTHING BUT CLEAN.
MOST OF THE ASSEMBLIES ARE UNDER THE RANGE TOP.
YOU MAY HAVE TO REMOVE TWO SCREWS FROM THE UNDERSIDE OF THE TOP AT EACH OF THE FRONT CORNERS. OPEN THE OVEN DOOR TO GAIN ACCESS.
IT WILL BE LOCATED IN THE CENTER. THE DOOR HOOK THAT STICKS OUT TO ENGAGE THE DOOR IS PART OF THE DOOR LOCK ASSEMBLY.
Posted on Apr 04, 2008
  • 106 Answers
SOURCE: range control panel does not work , cant set
You may have locked the touch pannel by acident. The child safty lock button looks like a pad lock or may say lock. hold it down for 4 sec to unlock.
Posted on Nov 11, 2009
My gas oven, Super Capacity 465 the oven nor broiler light. The stove top works fine.
Hello there
Please read the entire solution i have provided below ok
It won't bake or broil If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note... If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these, call a qualified appliance repair technician.
Sep 28, 2010 | Whirlpool GS460 Gas Kitchen Range
I have a G E Spectra gas stove and oven the gas oven doesn't work
does it not bake or broil? if this is the case, it could be the control panel. however if one or the other of the bake and broil functions work then it would most likely be an ignitor. check to see if your broil and bake ignitors glow. to access the bake ignitor you must remove the bottom panel from the oven but you can probaly see it gowing without removing the panel. the broil ignitor should be in plain sight.
May 28, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
After baking and trying to set time bake a week ago, the range won't turn on at all. Nothing happens when we press bake, broil, convect bake, etc. The clock, lights, fan, timer and cook top still work.
the oven controller in the main service/selection panel has either a bad solder joint on the circuits or the start realy for the oven on the same circuit board is bad and you have to replace the whole panel you cannot just buy the relay
Jan 20, 2010 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Bake or broil elements won't work.
First,go to the electric circuit panel. Turn the range breaker OFF then back ON. If that does not correct the problem you will have to replace the electronic control(clock) for the oven.
Aug 18, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Bake and Broiler do not work
it sounds like you have a bad eoc which is electronic oven control that is the only thing it could be if your top burners are open
Dec 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Baking oven
if you got no display form clock assy ck the power lines leading to that control, unplug and relpug unit might have just glitched out, no clock no bake on this model all oven function run throughthis clock/control
Feb 28, 2008 | Tappan TGF363 Gas Kitchen Range
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Kitchen Ranges Logo
261 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
