I cannot remove the General electric motor from my Goodman furnace
Goodman Furnace Model # GMPN080-4 REV B
Serial # 0111624331
The motor is faulty -it would not turn. It would only hum. Started to do this at the end of February. Did not need to use furnace. Now weather is quite warm and the motor is responsible for pushing cool air when the air conditioner is on. I removed the 3 outer bracket bolts that held the motor in place as it sat centered in the drum like metalwork. But I cannot get the motor and attached fan to pass back out the hole so i can replace the motor. Is the fan attachment on the motor shaft supposed to come off? And How? What to do? I could use some help,... please.
Furnace Plexed
  • 4 Answers
Oil the Day Lights out of it. Take Entire Squirl Cage out as one assembly so you can work with it. Use penatrating oil for days before trying to remove . You can accelerate the process with blow torch heat oil repeatedly. Loosen hex allen screw Hold shaft twist fan assembly to try to break free use a punch and hammer to push shaft out. Good luck
Posted on Jul 24, 2008
Goodman Model GMV950905DX-an electrical surge burned out the transformer which I replaced, also replaced the circuit board. The variable speed furnace will no longer kick into high speed and it will l
If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
Dec 16, 2014 | Goodman Manufacturing Goodman Gas Furnace...
Need the year of my furnance, have the model and serial number
manufacture can tell you year. what brand is it? goodman? my guess is 97 dec.
Feb 26, 2014 | Emerson Lennox Ducane Armstrong Furnace...
Blower motor makes noise, but does not work goodman
its either a bad motor or bad capacitor if you try to spin the wheel by hand and it starts then its the capacitor
Dec 26, 2012 | Goodman Heating & Cooling
I have a goodman electric furnace. Model no AR32-1, where can I get a manual. My furnace is making a grinding/squeak noise. Is it okay to run it until it's fixed?
I'm not sure you have a true Electric Furnace or a Heat Pump, since both are electric.
In any event, Goodman has Owners manuals that you can download in a pdf format. Just look for your model #.
Feb 04, 2011 | Goodman Heating & Cooling
I can't find any info on my Goodman furnace.It's a GMP and the model number on the front of it doesn't match any goodman model numbers G2FD036S17A......I'm lost
Take the top panel off and on the inside of the left side of furnace as you are facing it should have a nameplate rating.
The nameplate rating should have the model number and serial number of the actual unit that you have.
It will list BTUS/Electrical Amps.
Feb 15, 2010 | Heating & Cooling
Goodman GMP100-5 Rev Furnace Manual
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Jan 07, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
139 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
