Hi, Please follow below steps :
-. Jack up front wheel and remove the tires
-. Remove the Motor Mount next to the Power
Steering Pump and timing belt cover
-. Loosen the Alternator/Water Pump belt.
-. Loosen the Power Steering/AC/Tensioner belt by
loosening the Tensioner Bolt first.
-. Remove the power steering pump bracket.
Leave the pump attached to the bracket.
-. Remove the Water Pump Pulley.
-. Now it's time to remove the Crank Pulley.
-. Remove the Timing Cover bolts.
-. Remove and replace the crankshaft sensor
Park vehicle on level
ground.
2. Remove battery from vehicle.
3. Remove air cleaner outlet hose, engine
under cover ( right side ) and exhaust pipe # 2 .
4. Disconnect " B " terminal wire
and coupler from the Alternator ( Generator ) .
5. Remove Alternator ( Generator ) belt.
6. Remove power steering
pump. Do not disconnect hoses.
6. Remove Alternator ( Generator ) cover.
7. Remove Alternator ( Generator ) bracket
mounting bolts.
8. Remove Alternator ( Generator ).
Power Steering pump has three bolts- 2 behind the pulley
at 12 and 6 o'clock and one bolt on the back.
Once you get the power steering pump out of the way you can
remove the last bolt on the alternator
Ok...I did not remove
axle or disconnect hoses on power steering...I did unbolt power
steering pump and moved off to side.
after that I disconnected sensor on throttle
body and very carefully lifted alternator through the top where your air intake
assembly would have been at, right next to A.C. refrigerant lines.It
takes a minute , you HAVE TO BE CAREFUL NOT TO DAMAGE SENSOR!!
However it is a lot faster that taking off drive shaft and
exhaust pipe!
If you go to AutoZone .com they
have exploded diagrams of the parts you have to take off and they will show you
bolt locations, the power steering pump bolt at 6 o'clock drove me crazy.
P.S. Get a ratcheting 12 mil wrench, it's a life and knuckle saver!!
