Question about JVC Televison & Video
When The HDMI cables are connected, I use Directv, I have just recently started to have the picture come on and then start flickering and various color bars pop up on screen, then the screen will go black showing the Hi Def as the connection location and then shows the time, goes black again and then the picture comes on, with theflickering and various colors again, continues this way until you turn the tv to another setting. It does not seem to be the Directv receiver I just replaced it.
  • bushe Jun 09, 2008
    I replaced the HDMI cables twice and the HD receiver once, with no change.
    Genius:
  • JVC Master
  • 1,635 Answers
It is possible that the HDMI cable is defective. Did you try another cable?
It is also possible that the HDMI port on the TV is failing.
This can be determined by the process of elimination.
Jerry G.
Posted on Jun 06, 2008
2 sec Blip to picture
Are you saying that this happens only when you are using the RF input? Is it not happening when you use the video input from the satellite receiver? Try a DVD player on the input of the video where you now have the Satellite receiver connected. Let me know exactly what you mean as i need a little more information so I can assist you.
Jul 14, 2007 | JVC HD-52G886 52" Rear Projection HDTV
I have a wd-62525 dlp i have pic and sound through ant. and hdmi but on component and video inputs i only get sound no pic
Hello
It seems to be some fault with its HDMI cable you connect to this device from the source. As you get sound by HDMI, and no picture at all, this indicates the fault with cable itself. There is a cution notice says that " To assure continued FCC compliance, the user must use a shielded video interface cable
with bonded ferrite cores at both ends, when using the PC or HDMI input."
Cheang the cable and check.
Oct 10, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I am having connection issues with an LG 55lh40 television, a HD DVR from Directv, a PS3 and a DVD/VCR combo. The TV seems to be working good, but does not seem to be picking up an HDMI cable of any kind....
No picture
when connecting HDMI:
Check HDMI cable over version 1.3.
The HDMI cables don’t support HDMI version 1.3, it cause flickers or no screen
display. In this case use the latest cables that support HDMI version 1.3.
Feb 14, 2010 | Televison & Video
The HDMI doesn't work properly
HI
The resolution is only set by the sending unit, in your case the cable box. You need to change this to at least 720P something the your TV can handle.
Now once you have down this, to try and solve your HDMI problem I suggest you do the following.
Switch-off your cable box and the TV set, unhook the HDMI cable.
Now reinsert it carefully to make sure it connects properly on both sides.
Now first switch on your TV and set the input to Video 6 ( your HDMI channel )
Now wait for 30 secs. Switching on your cable box.
Do not press anything and check if your picture now stays on without shut-down.
if the menu and other startup screens on the cable box is not flickering, but the normal picture you might have a HDMI conflict with your TV set.
O, you cannot change the input types.
Hope this helps!
Dec 28, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
I have a Mitsubishi WD-62525, and when the Directv installer came out, he said that he could not connect the box to my tv because he didn't know how to get my tv in HDMI mode. From what I am reading, it...
Your right connect the HDMI output from the directv receiver to an HDMI input on your tv. Change the tv input to the HDMI input and it should work. If your tv does not have HDMI input then it should have component input indentified as red blue green connectors on the back of tv. This is for video only. Connect the red and white for audio using the yellow/red/white cable that was included with receiver. The red blue green cable is also included with receiver as well as the HDMI cable. Did this installer educate you on how to use your directv equipment. If you are paying for HD access but your receiver is not connected the an HD input on your tv then you are not getting what you are paying for. This should of been resolved during the installation. The installer either is incompentant or just did not care. Call directv and demand them to make their receiver work with your tv if this means a field supervisor tech being sent out to correct this.
Mar 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Connection of HDMI and Directv box
Monlink is the Connection I used with my Directv. All you need to use is the HDMI cords. Are you trying to also connect to stereo system or something other than a straight HDMI connection from Directv Box to WD-62525
Feb 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
HDMI interface issues
If you swapped directv receivers and the problem followed to a different tv then there is something wrong with the directv receiver. Need to run satellite setup again on this receiver to fix. repeat satellite setup is accessible through the setup submenu by pressing menu from the directv remote. look under satellite submenu once in setup
Dec 23, 2008 | JVC HD-52Z575 52" Rear Projection...
HDMI connection
It is possible that the DVD player is not outputing through the HDMI connector, or the TV has a problem with the HDMI input on the input board. This would have to be properly checked.
Start by calling the tech support for the DVD player to know if there is a setting for this, or if the player is defective.
Then check to make sure that there are no settings in the menu for the TV and player that are keeping the HDMI turned off.
If all else fails, call the tech support for your TV set. The next step will be that you must get the set serviced.
Jerry G.
May 13, 2008 | Televison & Video
Televison & Video Logo
Top JVC Televison & Video Experts
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
