Question about RIM BlackBerry 8100 HS-655 Bluetooth Headset HDW-12747-001 Wireless Headset
Blackberry 8800 headphones aren't working
I bought the Headset Jack Adapter to use my regular(3.5mm) headphones with but the sound is still playing throught the phone and not the headphones
  • chadgoldman Aug 16, 2008
    Is the same true for the 8100? I also have the adapter and it won'k work with headphones. Yet, the headphones that came with the 8100 work perfectly.
The 8800 does not support the stereo function on headphones.
Here is the ATT thread: http://forums.wireless.att.com/cng/board/message?board.id=rim&thread.id=22479
Posted on Jul 02, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • RIM Master
  • 1,001 Answers
Bought turtle beach z11 headset, cant get mic to work
The Z11 has a four-pole input/output plug to connect the mic and the earphone. The earphone needs to be connected to the earphone jack and the mic needs to be connected to the mic input jack on the back of the computer. In other words, you should have to 3.5 mm plugs. Plugging both into the same jack will disconnect one or the other. Check your adapter, It should have two separate 3.5mm plugs. If it does, be sure they are connected to the right jacks on the computer. The headphone jack will have a headphone symbol; the mic jack will have a microphone symbol. Go to System Preferences, Sound. Select the line in preference for input and the line out preference for headphones. Just may work.
Mar 14, 2014 | Apple iMac G5 Desktop
Headphone jack not working
check your jack wiring cable using ohm tester
Oct 19, 2013 | Nokia Radio Communications
Is the creative hs-400 compatible with regular mp3 players?
It should be compatible with any MP3 players.
The headset has a universal headphone jack that is compatible with most (if not all) devices.
Apr 16, 2011 | Creative Labs HS-400 Headset
One headphone is not working. no sound is coming.
pull the plgu of your headset partially from the jack play around it until the other headphone produces sound if this happens it mieans that the Audio port your using is either malfunctioning or you can try youy headset with an MP3 player or any audio device that uses a headset to find out if it is the headset that is damaged
Jun 05, 2010 | Bose QuietComfort 3 Acoustic Noise...
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
I just bought a Sennheisen SR130 wireless headset and I can't get it to work on my computer, and I was told specifically that they worked on computers. I want to get them on my computer and working, and...
Hello. plug them into a stereo jack on a regular stereo. if it works, then at least you know they are working. Then you can plug them into the headphone jack on your computer. If they still do not work but worked on your stereo, then you have to find out why you are not getting audio output to your headphone jack on your computer On your computer, go to control panel, then to sound, then adjust system sound. make sure none of the mutes are checked at the bottom of any of the volume levels. you can also plug in a regular pair of headphones to the jack in back of your pc to make sure that you are getting sound. if not, then you have to enable the sounds to your pc jack in the sounds menu. hope this helps.
Mar 07, 2009 | Computers & Internet
Can't connect c250 to Blackberry 8830
The Jabra c250 requires a 2.5mm headphone jack; the Blackberry opening is for a 3.5mm headset. You can buy an adapter at your local electronics store (like Radio Shack, The Source...).
Jan 26, 2009 | Jabra (JAB7323RBULK) Headset
Not getting equal sound in my headset
Faulty headphone jack in unit. Possibly worked loose while inserting headphones. If still under warranty...return or replace. Otherwise, find someone who can open the unit and make necessary adjustments.
Apr 04, 2008 | Audio Players & Recorders
RIM BlackBerry 8100 HS-655 Bluetooth Headset HDW-12747-001 Wireless Headset Logo
1,306 people viewed this question
Top RIM Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a RIM Radio Communication Expert? Answer questions, earn points and help others
