Question about Panasonic SC-HT75 System
Dvd problem cant get dvd out of unit. it says change. all lites are flashing
    President:
  • 2,712 Answers
Try a hard reset and see if that resolves the issue: Unplug the power from the AC source, and any other cables. Wait about 10 minutes and redo the cables and power. Switch on the player and see if this resolves the issue.
If it doesn't, you will most likely have to remove the cover to access the player and physically remove it. Dont attempt this if your unit is under warranty, as it will void the warranty. In this case, simply take it back to the point of purchase and they will assist you.
Posted on Jun 06, 2008
  • 3,037 Answers
How new is this unit, because I don't want you to do anything if it is still in warranty. A simple thing to try first before knowing if it is in warranty is just unplug it for a few minutes and plug it back in to see if that resets the system. If not, let me know and also let me know if it is in warranty still as I don't want to void the warranty if it is still good
  • Benjamin Patri
    Benjamin Patri Jun 10, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
    Sergeant:
    Champion:
  • 347 Answers
Hello colt86,
Does the DVD plate domes out? Is it stuckde?
Can lite-on-ltn4865 48x play dvd movies
If your Drive is a CD-Rome drive, surely it cant, for the drive cant read dvd disc. Replace the drive of yours with DVD-Rom or DVD-RW in order to play dvd disc, DVD-RW simply has the added capablity to burn on DVD discs
Jan 12, 2011 | Lite On (LTN486S) Internal 48x CD-ROM...
I have a problem w/ my Lite On SHW-160P6S DVD RW Dual Layer Burner which won't read any DVD or CD. Also, The door to the unit won't open unless you insert a pin in the little hole on the front of the unit...
You will have to open the unit. To be honest, it's a good idea to buy a new one as I had to change to belt and my drive started smoking when I turned my computer on.
Dec 15, 2010 | Lite On SHW-160P6S (SHM160P6S04) DVD RW...
Cant burn music
1. How old is the unit?
2. Is it connected properly?
3. Is there dust in the cabinet?
4. Is the CD disk compatible with the unit?
5. Have you tried reloading the drivers for this unit?
6. If your software compatible with the Operating system?
7. what Operating system are you using?
8. Did you upgrade to Windows 7?
Sep 17, 2010 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Cant burn dvds with my lite on 5232k
This unit was not ever made to burn DVD only read and play them.
HERE is the source
May 03, 2010 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Trying 2 burn cd and my computer is sayind cant
try reinstalling the burner then restart ur computer if the problem still ocurs then right click on my computer then manage then device manager then right click on ur system name (eg tom234) then scan for hardware changes and update ur drive, if the problem still ocurs then change the cable(sata or pata) then try.
Nov 04, 2009 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Hello hope someone can help.a virus completely uninstalled my DVD/CD drivers i cant play any type of disk cd or dvd and when i checked the drivers it was not there i have a advent ert2250 and the dvd/cd...
hi,
A Virus Would Corrupt or remove/Change drivers.
You need to remove The Virus.
You should then remove The DVD Drive Manually from The Machine.
Start the Computer without The Drive, then power Off the Computer.
re-install the Drive, boot up and Hopefully it should be detected in ( found new Hardware ) if not, go to add new hardware wizard, and see if it,s detected there. A Virus Can Actually lock-Off a Drive.
Mike @ Compurepair.
Oct 30, 2009 | Lite On (SSW833SX) DVD RW Dual Layer...
Dvd problem
try to reset the system disconnect the system from power and re connect it again.
Jun 06, 2008 | Panasonic SC-HT75 System
Burner problems
First check if device is recognised in bios, if it is then you need to fixwindows. If you cannot see cd unit in bios then check that slave/master / cable bridge settings at back of cd are fine.In this case the fastest way to test your unit is to connect it as single unit with a tested ide cable on the computer, just to test it. On the other channel you connect the hd. Eventually switch channels and cables between hd and cd.
Feb 19, 2008 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Won't power up
if you already tryed to unplug the unit then you did all you can unless you know how to trouble shoot the power supply with a multi-meter. It sounds like what you described to be one of the switched supplys to be defective., Sorry I could assist you more.
Jun 14, 2006 | Philips DVP642 DVD Player
Panasonic SC-HT75 System Logo
47 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
