1992 Oldsmobile Cutlass Ciera Logo
Posted on Oct 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I find the parking brake wire to connect my stereo up properly...not to bypass anything? I just want to know what color and where to find the brake wire in a 92 Olds Cutlass Ciera S.
Auto Repair Help
Level 3:
  • Oldsmobile Master 1,420 Answers
  • Posted on Oct 23, 2010
Auto Repair Help
Oldsmobile Master
Level 3:
Answers
1420
Questions
0
Helped
667417
Points
4361
Welcome to FIxYa.com
do you really need the brake wire not a Hot 12 volt wire?
Regards, Lee Davidian
Thank you for using FixYa,com.
2001 GMC Yukon stereo wiring colors
PART COLOR LOCATION 12 VOLT CONSTANT RED (+) @ IGNITION SWITCH HARNESS STARTER YELLOW (+) @ IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 PINK (+) @ IGNITION SWITCH HARNESS IGNITION 2 WHITE (+), See NOTE #6 @ IGNITION SWITCH HARNESS IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) @ IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE LIGHT GREEN (-) @ IGNITION SWITCH HARNESS PARKING LIGHTS ( - ) WHITE (-) @ BCM, LIGHT BLUE plug, Pin A5, See NOTE #4 PARKING LIGHTS ( + ) BROWN (+) @ BCM, LIGHT BLUE Plug, Pin B6, See NOTE #4 POWER LOCK LIGHT BLUE (TYPE A) @ BCM, BROWN plug, Pin A4, See NOTE #4 POWER UNLOCK WHITE (TYPE A) @ BCM, BROWN Plug, Pin A3, See NOTE #4 DOOR TRIGGER See NOTE #2 @ BCM, See NOTE #4 DOMELIGHT SUPERVISION TAN (-) @ BCM, PURPLE Plug, Pin B4, See NOTE #4 TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN BLACK (-) @ STEERING COLUMN HARNESS TACH WHITE (AC) @ ECM, See NOTE *2 WAIT TO START LIGHT DARK BLUE (-), See NOTE #5 @ INSTRUMENT CLUSTER BRAKE WHITE (+) @ SWITCH ABOVE BRAKE PEDAL FACTORY ALARM DISARM LIGHT GREEN (-) @ BCM, PURPLE plug, Pin B3, See NOTE #4 ANTI-THEFT YELLOW (+), ORANGE/BLACK (-) and RED/WHITE (Not used) GM's PASSLOCK 2 System, these wires exit the Ignition Switch Tumbler together and are in the Main Ignition Switch Harness in the Column. EXTRA INFORMATION NOTE #1: This vehicle is equipped with the PASSLOCK 2 ANTI-THEFT SYSTEM and will require a 791 Bypass Module for Remote Starting, to order go to the SECURITY BYPASS MODULE Page on this website. NOTE #2: This vehicle has 2 door trigger wires, the DRIVERS DOOR is a TAN (-) PURPLE plug, B4 and ALL OTHER doors BLUE/WHITE (-) LIGHT BLUE plug, Pin B11 at the BCM use both Door Trigger wires and DIODE ISOLATE when connecting to an ALARM SYSTEM, to connect, See DIAGRAM. NOTE #3; The ECM (Engine Control Module) is located near the battery, down low, between the fender and the fan, under a BLACK plastic cover. On the 4.3L engine it is in a 20 pin connector labled RED. On the 4.8L, 5.3L and 6.0L engines it is located at Pin 10 in the RED connector NOTE #4: The BCM (Body Control Module) is located behind the drivers side of dash, with the plugs facing the rear of the vehicle. NOTE #5: when hooking up a remote starter, if you cannot get the (+) or (-) Wait to Start wire on the Remote Starter to work properly, you will then need to disconnect this wire and Program the Remote Starter for the 5, 10, 15 or 20 Second Wait to Start Timmer in the Installation manual. NOTE #6: IMPORTANT !!!!! this wire MUST BE CONNECTED as IGNITION #2 for REMOTE STARTING!!!!!!
tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1993 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1993
STEREO WIRING COLOR CHART:
Constant 12V+: White/Blue
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Distributor
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector)
Parking Lights: Red/Black - (+) Above Fus Panel (White Connector)
Head Lamp: Red/White - Steering Column
Hood Pin: n/a
Factory Disarm: Disarms with Unlock
Door Trigger: Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) Driver's Door at Door Lock Module
Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module
Horn: Blue/Red - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Orange/White
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
VSS Wire : Yellow/Blue - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1988 - 1991 Honda Civic...
1988
1989
1990
1991
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Accessory: Blue/White - Ignition Switch Harness
Trunk Pin: Green/Black - (-) Harness from Dash Indicator
Parking Lights: Red/Black - (+) Fuse Panel
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Red - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
VSS Wire : Yellow/Red - Driver's Side Dash Footwell, 13-pin connector.
NOTES: 4000PPM
1helpful
What are the wire colors of the neutral safety switch on a 2000 Caravan 3.0 liter with a 4-speed automatic transmission.
Brown wire with yellow tracer shows to be wire color. You can always jump the starter to get it to crank, but, that doesn't mean it will start. In the past I have been lucky, different vehicle, I put the key in on position, jumped the starter relay, the vehicle started, I managed to get it home.
When testing, make sure tranny is in park or neutral and functional parking brake is set. There are safety issues, safety is your responsibility. You don't want the vehicle to move when your working on it.
You realize if you bypass anything, it may start in any gear, if it does it will run over you or one of the kids, anything that gets in the way. Again, safety for everybody is your responsibility.
tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1984 - 1987 Honda Civic...
1984
1985
1986
1987
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
1984, 1985:70-1388
1986, 1987:70-1720
Tach: Blue - Coil
Trunk Pin: Green/Black - (-) Hatch Pin Switch
Parking Lights: Red/Black - (+) Light Switch
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Black - (-) Pin Switch
Door Lock: Green/White - (-) Driver's Kick Panel
Door Unlock: Green/Orange - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1983 Honda Civic This...
1983
Illumination: n/a
Dimmer: n/a
Front Speakers: 5 1/4" Side Panels
Left Front (+) Blue
Rear Speakers 6 1/2" Rear Doors
Left Rear (-) Gray/Black
NOTES: - none -
Metra Brand Wiring Harness: 70-1388
Tach: Blue - Coil
Hood Pin: n/a
Factory Disarm: n/a
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
How do i install a remote start?
  1. buy an extra key from howard keys
  2. get key cut at home depot
  3. follow instructions in vehicle manual for programming key
  4. find ignition wires, and properly identify as ignition, accessory, and start.
  5. connect appropriate wires with secure method
  6. find & connect proper ground, typically in kick panel.
  7. connect brake, tach, hood pin, and parking brake wires.
  8. create bypass relay with proper gauge and loops of wire around key, and cylinder.
  9. program per manual
  10. or get a professional to do it.
1999 navigator
i know this worked with my 99 navigator 32 valve used a viper car starter.
Lincoln
Navigator
1997-2003
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
RED/LT. BLUE
IGNITION SWITCH HARNESS **
Ignition #1:
D BLUE/GREEN
Ignition #2:
GRAY/YELLOW
Ignition #3:
RED/BLACK
IGNITION SWITCH HARNESS***
Accessory:
BLACK/LT. GREEN
Brake Light:
L GREEN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
WHITE/PINK
AT POWERTRAIN CONTROL MODULE *
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH
Headlights:
RED/YELLOW (+)
AT HEADLIGHT SWITCH
OEM Alarm Disarm:
D GREEN/PURPLE (-)
DRIVER KICK PANEL
OEM Alarm Arm:
N/A
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* Powertrain Control Module (PCM) Located On Passenger Side Of Engine Compartment On Passenger Wheelwell. This Wire Can Also Be Found At the Firewall Harness On the Driver's Side of Vehicle. ** This Vehicle Is Equipped With Ford's PATS Anti-Theft System. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. *** Must power ign3 using a relay. Tap relay coil to ign3 connection of remote start along with bypass module. No diode isolation is required.
tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1980 - 1982 Honda Civic...
1980
1981
1982
Constant Power: White/Blue
Switched Power: Yellow/Red
Ground: To Chassis Metal
Illumination: N/A
Dimmer: N/A
Antenna: Drivers Side Pillar
Left Front (+): Red/Green
Left Front (-): Brown
Right Front (+): Blue/Green
Right Front (-): Gray
Left Rear (+): Red/Yellow
Left Rear (-): Brown
Right Rear (+): Blue/Yellow
Right Rear (-): Gray/White
NOTES: - none -
Tach: Blue - Coil
Hood Pin: n/a
Factory Disarm: n/a
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
