Question about Sony PlayStation 2 (PS2) Console
Will play CD's but not DVD's or Games
We have an older, PS2 (no slim, no internet connection, just HDD bay in back and 2 USB ports in front) bought originally in Germany. It worked fine until it started mucking up DVD's and now will give a Disc Error message (No Data) when we use the Browser option. It wont read DVD's or PS2 Games at all but oddly enough will read CD's just fine. What can we do to solve this? We'Ve had the PS2 completely apart, cleaned it, checked the laser - can't see a problem there.
  • rossey Jun 07, 2008
    giving disk error and will play dvd's but not ps2 games it will hve a snowflake at the bottom right corner of a blank screen
  • jshbschk661 Feb 21, 2009
    I just bought a BRAND NEW LASER for my PS2 and Im having the same problem. Its a KHS-400C Model and its currently only reading PS1 games and CD's but not PS2 games or DVD's. What is the problem? I've tried realigning the laser but it didnt work. I havent removed the anti static point from the new laser could that be the problem?
  • 868 Answers
You have to take the box apart and clean the lens.Ok !
  1. The white plastic gear that moves the laser must make contact with the "motor". A bad contact here can cause disk read errors. Sometimes it looks Ok, but you may need to remove the lens and bend the white gear for good contact.
  2. The two rails on which the lens move must be very slippery - which can be lubricated with cooking or motor oil. Usually the holes where the rail is (on the right side of the lens) are dirty or you have to bore then out slightly, making the holes bigger.
  3. The lens uses little torx screw (black) that move the lens up and down on the rail. Usually the lens is too high and requires adjustment.
  4. Take the lens off these 2 rails and take the black plastic cover off. Turn the lense upside-down and you'll find there are 2 screws (silver, phillips or torx) that you have to remove to take the upper little lens off.
  5. Then you'll see a larger lens that is usually very dirty (this lens is a mirror to light). If that's dirty, it will give a disk read error. You'll have to take the little electric board off that you see on the other side of the big lens-mirror. It's probably dirty too, so clean it. Alcohol should work OK for this task.
  6. The lens bottom has 2 + 2 screws. You move the upper "little" lens up-down-left-right (this may require a special screwdriver)
  7. The motor "rail" that moves the lens must be very clean and oiled and the 2 rails too.
Posted on Jun 07, 2008
How to play play ps2 games on your ps3
You can only play PS2 games on your PS3 if it is backwords compatible, and the easy way to find out is to see how many USB Ports are in front of the console. If you have 2 USB Ports, no go. If you have 4 USB Ports in front, it is backwords compatiable. Another easy way to find out is if you own a fat PS3 with 4USB Ports you are good to go, just pop the CD in and it will play. If you own a slim PS3, you are out of luck, when Sony intoduced the slim ps3, to save money, they removed the backwords compatible chip from the hardware inside.
Aug 20, 2011 | Sony PlayStation 3 (120 GB) Black Console
Tip
PS3 models, and what they can do
The 20 Gig
Pros
Full PS2 Compatibility
HDMI Port
Pretty good Cooling System
4 USB Ports
£220
Cons
Super Small HDD
No Wireless Card
Discontinued (They don't make them any more)
The 40 Gig
Pros
£250
HDMI Port
Built in Wireless
Medium HDD
Amazing, New Cooling System
Cons
2 USB Ports
Cannot play PS2 Games
The 60 Gig
Pros
SD Card Slots
4 USB Ports
Built In Wireless
Big HDD
HDMI Port
£280
Cons
The *OLD* 80 Gig
Pros
Massive HDD
4 USB Ports
Limited PS2 Compatibility
SD Card Slots
HDMI Port
£280
Cons
The *NEW* 80 Gig
Pros
Massive HDD
£250
HDMI Port
Built in Wireless
Cons
NO PS2 Compatibility
The 160 Gig
Pros
Mammoth HDD
HDMI Port
Built in Wireless
Cons
£350
on Jan 18, 2010 | Video Game Consoles & Games
How to put games on usb in ps2 to play ps2 without cd games usb only..?
Search online for hacks and apps,,also they have a app you can buy or download,,called usb advance,,that makes it where you can do stuff like that,,also find you the ps2 hdd online ,,then buy the thing called hdd laoder,,witch is the best solution for that,,u can then download ps2 games then straight to hdd,,and play them,,download u torrent,,or bit torrent,,thats where u can get hacks,,and any ps2 game for free,,,thanks hope was helpful.
Nov 18, 2010 | Sony PlayStation 2 (PS2) Console
How can i download games for playstation 2 through internet free.and burn to cd
well a slim ps2 may not be able to be modded as well as a phat ps2 which can take a hardrive which allows you to store files like ps2 games to play on a softmodded or hardmodded ps2!
Softmods:A softmod consists of modding a device but only its software[data, drivers] and thus its "soft"ware is changed allowing you to play ps2 game files or burned dvd ps2 games. One draw back is the slim ps2s could be softmodded, but you cant install a hardrive so its much harder to mod and almost pointless. You can play burned ps2 games but then a Hardmod is needed to help get past security chips!
You can use a method of putting tape and objects in the way of sensors in the ps2 so the ps2 slim will think the dvd tray is closed when its not and you perform a disc swap. look up ps2 disc swap techniqes.
With a phat ps2 you can simply put the modded files on the hardrive and then install them threw the ps2! look online for websites who can teach you how to get and do this stuff.
HardMod: A Hardmod consists of actually adding a physical chip to the device! this is by far the most task worthy. to be frank i cant install a chip on any device and even with the charts. but people are out there who will actually be able to install a mod chip on your ps2. you can find chips but you need someone to install it. i say find someone on the internet or ads who has the chips and the talent to install it.. costs about 150.00 less or more!
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
Cant Play Pirated games on my PS2 SLim
get ur ps2 modded then u can play pirated/burned games.
Apr 19, 2009 | Sony PlayStation 2 Slimline Console
My son played his Rock Band 2 on my brother's PS2 and it played fine. He then bought his own PS2 and could never get it to play. He has a Tiger Woods game that works fine on both games. Both machines are...
Is tiger woods a blue disc or silver?
The silver discs are DVD and the Blue ones are CD (same with the black PSOne discs). If Tiger woods is a CD then your DVD laser could be out.
You can try to clean the lasers lens and see if that helps, but if you have jsut got that machine you should take that back.
Apr 02, 2009 | Sony PlayStation 2 (PS2) Console
How hdd connect with slim ps2
You cannot connect a usb hardrive or anything for that matter unless you "soft mod" the ps2 you need a pro action repaly and the usb stick that comes with it and you need to put certain installtion files on the stick with your computer.
Google: "Mod slim ps2 to play backups"
Feb 02, 2009 | Video Game Consoles & Games
Can ps2 slim play ps1 cd?
harpy_125..yes they do .but you do need an old version memory card to memorise your games. does it play music cds . if so it should read the games as these are only cd and not dvd..
Feb 09, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Slim won't read dvd games
Blocking the sensors did you in I'm afraid. What has happened is the *DVD* read mechanism has gotten goofed because of this, but the *CD* read mechanism is still ok. Maximo and a few other PS2 games were actually on CD, not DVD. If you look on the back cover, you will see the Compact Disc logo (in the lower right area on the box for Maximo). These games have a blue bottom disc instead of the silver bottom. You can attempt to re-align the laser which is a fairly lengthy process and there are numerous guides out there to do this. Here is one: http://arstechnica.com/articles/paedia/hardware/ps2.ars Note that this guide is for the larger model but the concept of lens adjustment is still the same and a quick google search will provide more in-depth detail. Since you have already opened your system, this may be an option for you. If the PS2 was purchased new as you said, it might not be the worst idea to exchange it for a new model as the lens going out this soon might be an indication that the unit wouldn't have lasted that long to begin with. Also just a friendly reminder that opening your PS2 voids your warranty and double check the return policies of where you bought the system.
Aug 14, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
128 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
