Cannon MF8180C--is it possible to convert a fax saved in the Cannon into a PDF file without out having to print it and scan it?
Should be a encoder ya drag or right clik on the fax send to pdf adobe ok
Posted on Jun 08, 2008
I can"t scan to PDF
Hi
Use the Scan to PDF software to direct convert your scan page to PDF, download the software to click hear
and simple to install to this software, after installing you get the shortcut in your desktop double click that one and open your scaner is automatic install there put the document in scanner and click scan after scanning click save to PDF and give the save file name and save.
Nice one may it is resolve you problem.
Cheer
Jun 23, 2011 | HP Scanjet G2710 Flatbed Scanner
Sometimes when I print .pdf file the computer request me put the file name instead of printing
this happens when you have selected a PDF printer instead of the real Physical Printer for printing
a PDF printer is a software which converts any thing sent out like a document or file for printing into a PDF file tis is useful for saving data from files or majorly from websites and emails as a softcopy on your system.
next time on, when printing check to see that the selected printer on default is a Physical Printer (like HP or Cannon etc.) connected to your computer and you'll have your hard copies
hope could be of help, cheers
Mar 28, 2011 | Computers & Internet
New all in one printer/scanner. when I scan I get:- Adobe reader could not open 'scan_Doc0001.pdf'
Might need a bit more information about this: But I'm presuming you scan your document and save it as a pdf document using the built in HP software?
Couple of things to try:
1 - have you got the latest version of Adobe Reader? It may be that you are using an older version - the pdf document specification has been updated over the years and it may be that you're saving the pdf using a newer version of the pdf format than adobe reader is able to read.
2 - Adobe reader isn't the only pdf viewer, there are numerous other pdf document viewers (some free some not) You could try another pdf viewer, like Foxit Reader (free to use) and see if that can open it?
3 - When you save the scan, make sure that in the Save Dialog box it is really saving it as pdf. Common mistake is that people often just save a file with .pdf and expect the program to know that you want to save as pdf. When you scan there are several other file formats that you can use (Tiff, Jpeg etc) Is is possible you're saving the file as Tiff or Jpeg but with a .pdf file extension? If you're not sure, re-scan the document and resave it, but don't use a file extension, let the scanning program do that, see what it saves it as?
4 - check where you're saving the pdf on your computer? Is the place you're trying to open it from, the same as the place you've saved it?
Feb 28, 2011 | HP Office Equipment & Supplies
Hi, I cannot print a pdf file or that kind of attachment. Only Word can print. Adobe error shows up and want to shut down the program for protection. I never had the problem before. Just started.
Is it a file that you created in pdf format, or is it one that you have had emailed or attempting to open from another source? Some pdf files have protection put on them by the file originator to avoid the file being changed/printed. Here are some tips to try to get them to print for you.
  1. Open your computer's Internet browser.
  2. 2
    Type www.a-pdf.com/security/a-pdf-rr.exe in the browser's URL box to access the PDF restriction converter "A-PDF Restrictions Remover."
  3. 3
    Press the "Enter" or "Return" key. Your Internet browser will access the site's PDF converter file. A dialog box will appear on your screen--"Opening a-pdf-rr.exe."
  4. 4
    Click "Open" or "Run" to download and set up the program directly. Click "Save" or "Save As" to save the program's setup file on your computer for running later--use this option if you using a slow connection like dial-up. The program will download and set up on your computer if you selected the "Open" or "Run" option.
    If saving the file to your computer, navigate to the directory where you want to save the file to. Select the "Desktop" if you have a hard time locating downloaded files on your system.
    You do not have to access the A-PDF Restrictions Remover website again once the file starts downloading or saving to your computer.
  5. 5
    Double click on the "a-pdf-rr.exe" icon to open the program, if you selected the "Save" or "Save As" option.
  6. 6
    Click "Run" when prompted with the "Open File -- Security Warning."
  7. 7
    Click "Next." Click on the circle by the wording "I accept the agreement." Click "Next."
  8. 8
    Select the directory where you want to save the "A-PDF Restrictions Remover" file. The default is your "C:\Program Files\A-PDF Restrictions Remover" folder. Click "Next."
  9. 9
    Click "Next," "Install" and then "Finish." A-PDF Restrictions Remover will start automatically.
  10. 10
    Navigate to the directory where the protected PDF file is located.
  11. 11
    Right-click on the PDF file name. Select "Remove Restrict & Save As."
  12. 12
    Select a location to save the converted PDF file to. Click "Save." If you want to change the PDF file's name, enter a new name in the box next to the wording "File name." The protected PDF is now converted to a unprotected one.
  13. 13
    Double-click on the converted file to open it.
  14. 14
    Select "File," "Print" and then "OK" to print the unprotected, converted PDF file.
  15. Printing a Protected PDF By Taking a "Screen Shot"
  16. 1
    Open the protected PDF file2
  17. Press the "Alt" and "PrtScrn" keys together. The PrtScrn key is located on the upper right-hand side of your keyboard, if using a desktop computer keyboard. If using a laptop, the PrtScrn key is located above the "F10" function key.
  18. 3
    Open your computer's word processing program by clicking on the program's icon on your system's "Desktop" or from the "All Programs" menu.
  19. 4
    Press "CTRL" and "V" keys together to paste the screenshot into a blank document.
    If using a Mac, click "Edit," "Paste" from the main toolbar at the top of your word processing program.
  20. 5
    Click "File," "Print" and then "OK" to print the PDF screenshot. If the protected PDF file contains more than one page, press the "PgDn" key and repeat steps 2 through 5.
Oct 29, 2010 | Canon FAXPHONE L80 Laser
Kindly give the address of canon fax and scan machine service center at Raipur in Chattisgarh
mcdevito75 Here, You can simply type in Cannon.com and that should help out. It should guide you to the Cannon site.
Jun 23, 2010 | Canon MF8180C Color Laser MFC Printer
Unable to save scanned document in html format
You can print save as a HTML File, most printers defaults print save as PDF files, Since PDF files are none editable you will not be able to convert this into a HTML file.
Regards
Jul 23, 2009 | HP PSC 2110 All-In-One InkJet Printer
How can i convert the scan file to pdf file ?
try to use PrimoPDF ( freeware) to convert your scanned file into pdf file.
- download primopdf and install it, this will be installed as printer ( check printer and faxes it should be there after installing)
- print your scanned file using PrimoPDF and it will ask you to create and save the file in PDF.
- its free.
Jun 18, 2009 | Sun Java Programming Language (cdj-275)
How can I get a operating manual for my Cannon SuperG3 copier model #H12295
your can't print it or copy.
please use the print screen option in key board and then copy to a word file. it ' s the only way to do it
Jul 22, 2008 | Canon MF8180C Color Laser MFC Printer
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
