Microphones
Problem for Microphones
Generic problem for all Microphones
Hannah montanna mic dosent work
By cissychick on Jun 06, 2008
we got the mic and put batteries init and it dosent work any suggestions???
Solution #1
posted on Jun 06, 2008
Not Rated)
jerryg50
Rank: Wiz
Rating: 84%, 883 votes
The output level of the mic may be -50 dB or what is known as mic level. You will need to use the mic input on your console, or amplifier (whatever you are feeding the mic to).
Some mics are at line level because they have a built in pre-amp. Then you must use the line level input on your equipment that the mic is feeding.
If the mic is defective, there are 4 basic elements in a powered mic.
1) The mic diaphram unit, or pickup
2) The processor amplifier module
3) The power switch
4) The rear connector
Some mics have a matching transformer on the output section before the connector.
If you have a DVM and a knowledge of basic electronics, you can check for voltages and resistances to make sure all the connections are okay, and that there is power to the amplifier module. To check the diaphram and the signal path you will need an oscillocsope.
Normaly, a consumer quality mic is not supported for service. If you have a professional Sure, or Sony, or equivelent mic, it would be recomended to send it for factory service if it is not working. Even though they are simple in theory, they can be sort of complicated to service.
Jerry G.
Was this helpful?
Yes
No
Popular Solutions for Microphones
Questions and Unsolved Problems for Microphones
Answer
I have connected the microphone to my PC. but there is no sound. Do i Need a battary? If so how do I... (More)
Answer
siempre la puntuacion es 100.lo que me parece es un daño en el equipo. por fabor ayudame.... (More)
Answer
Hi! There is a very loud, distorted sound when I'm trying to use it. However, once in awhile it... (More)
Answer
shure 520D 1991..what element would be the best replacement in order to reduce feedback?
Answer
What do I need to provide phantom power to Shure Beta 87A microphone? All I have is a fender... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microphones:
Top Microphone Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Microphone Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
