Question about Savin Office Equipment & Supplies
Savin 2545/2245 pcl copier has tech prob
My savin's screen is showing "technical problem" and siting "SC 544". i don't have the manual to look this up myself and I need this fixed asap (can't do any business without it!)
SOURCE: How to change and program fax numbers into Savin 3515MF copier
"user tools"
"system Settings"
"key operator tools"
"address book Management"
"Program/ Change" or "Delete"
.......and proceed to make the changes as you wish
All of the manuals can be downloaded here, but they can be difficult to follow.
http://www.ricoh-usa.com/downloads/manuals/bw/aficio1515/
Posted on Mar 02, 2009
  • 990 Answers
SOURCE: Functional problem with the copier (Savin 2545) Service Code SC 546
Hello sir; Your machine need to reset, the procedure as follow;
1, press "clear mode", "107", then hold down "clear/stop" key, until screen change message to sp mode.
2, turn power off and back on ,machine will in working condition.
Posted on May 29, 2009
Matt_Sr
  • 31 Answers
SOURCE: I have a Savin 9922DP red wrench and code SC 546
Parts availability ended for this machine Jan of 07, now is a good time just to chuck it.
Posted on Jun 19, 2009
  • 541 Answers
SOURCE: We have a Savin 9945DPE that needed a new hard
do not use the dhcp for the ip for the printer. set it to static. make sure the first pc you set the driver from is set to local printer as the default. make these changes and let me know.
Posted on Jan 02, 2010
  • 2072 Answers
SOURCE: When copier is putting on , it displays " error
that is a fuser overheat code. You can try pressing clear all, then enter 107 and hold the stop button until you see the SP mode come on the machine, then as it is in that mode, shut the machine off and back on.
If that doesnt work. I would suggest replacing the fuser unit.
You would need thermistors, rolls, overheat thermostadts.
Individually they would cost more than replacing the fuser.
Posted on Aug 12, 2010
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
I have copier it given me this code SC 544 & SC 542 & SC 500 can you assist me please .
overload of the main motor or fusing unit (SC 500)
Look at your fusing unit, (rollers, thermistor, lamp, gears...)
and don't forget to reset SC code in SP mode.
Good luck
Jul 03, 2011 | Ricoh Aficio MP 161 Black and White Copier
My SAVIN 2575 is giving error code sc820, any idea what the problem is ?
Unfortunately, I've never seen this error, so I can't give you much help beyond what the code means and the possible solutions that the service manual provides...
SC820:
Self diagnostic error: CPU - Unexpected external error or interrupt occurred.
• Controller board defective
• Software defective
The manual indicates this is a "C" type code, so this should not be displayed on the OP panel, only logged in the SC history in the machine.
Jun 23, 2011 | Savin 2575 Black and White Copier
My Savin SDC 103 has an SC-172 call service error. The copier was given to me, it only has 7800 copies on it. The error showed up after they moved it.
That code is related to the scanner unit.
Probably after they move the machine the lamp went out of position.
I advise you to see the all scanner; Lamp, Mirrors, White plate...
May 23, 2011 | Savin Office Equipment & Supplies
Jun 02, 2009 | Ricoh Aficio 450 Copier
May 29, 2009 | Ricoh Aficio 450 Copier
Sc 326 -322
What is your make and model of the copier....If it a Ricoh or Savin or Aficio... You Have First and Second Laser Sinc Issues. and probably will continue to have these arrors. I may be able to help if I know your Make and Model. I am a Trained Ricoh Tech
Apr 04, 2009 | Office Equipment & Supplies
Ricoh Aficio 1224c error code SC 544
Well, I have no idea why changing your password would affect it this way. the code you're experiencing is a fuser warm up error, due to blown fuse, thermostsat, possible power supply prob...regardless, it can only be reset by a service tech in service mode once the problem is fixed. Sorry.
Mar 05, 2009 | Ricoh Office Equipment & Supplies
Savin SLP 38C
Problem returns after turning power off/on??
You have a problem with the Magenta Development unit. May just need to be re-seated -more likely it needs replacing.
Refer to your manual on how to remove/re-seat
Feb 18, 2009 | Office Equipment & Supplies
Top Savin Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
