Question about E-Machines 17F2 17" CRT Monitor
Cable signal i need to replace my cable signal, my ex cut it. where can i get one.
I can replace it
Posted on Nov 14, 2008
How many times can you split a cable signal before needing an amplifier?
Every time you split you cut your signal . Problem with cable is their signal phlsates at various rates. Known to burn out tv's. You would need an adjustable amplifier and signal filter or rectifier.
Sep 18, 2014 | Audio Players & Recorders
I need to know how to change out a turn signal switch on a 2001 kia sportage ex
DISCONNECT NEGATIVE BATTERY CABLE BEFORE STARTING. REMOVE THE PLASTIC COVERING FROM AROUND THE TURN SIGNAL SWITCH. LOOKING AT A NEW SWITCH WILL BE HELPFUL, TO SEE HOW TO REMOVE THE SWITCH.
Jan 27, 2011 | 2001 Kia Sportage
Sony kdl46w5150 with external antenna dropping signal on some channels
1. Check for any loose connections starting at your TV. (Coaxial cables unscrew themselves with vibration...) Check all outdoor connections for corrosion and cut off and replace any cable ends that show corrosion.
2. Check your alignment - (positioning or pointing)
http://www.wowvision.tv/OTAalignment.htm
3. Replace the balun a.k.a. 75 ohm matching transformer.
If these don't work, a larger antenna is needed...
with one exception:
That exception is if your signal is too high. If this is the case, change alignment to reduce signal a little.
Jun 11, 2010 | Sony Televison & Video
Cable picture is fuzzy
Call your cable company as there might be a problem with the drop line or aerial coming into your house. now another thing is if you have a signal splitter( ex: 2-way, 3-way, 4-way) before the cable box, that could be degrading the signal as each input may drop the signal significantly. remeber, don't use too many splitters as they will make the signal faded/fuzzy. also, make sure all the connectors are clean and are not badly bent or the ends frayed. If you can see wire insulation from the cable line then it's no good.
Apr 05, 2010 | Insignia 42" LCD Flat-Panel HDTV
Need help splicing into turn signals and headlights on my 97 jeep
You need to ground the negative from you mirror to a bolt or screw in the car. Then find out which is the positive in the turn signal for each side. You can do so with a test light, turn the signal on then probe the wires at the harness until the test light blinks. That's the cable, attach a cable to the signal cable how ever you choose just don't cut off the signal cable. Then run a cable to the mirror on that side. Do the same for the other side, the easiest way is to hook them up to your turn signals.
May 06, 2009 | 1997 Jeep Tj
CASIO EX-Z75 CAMERA CABLE
I called Parts Replacement at 1-800-223-2001 and they told me I would have to purchase the USB Cable for my casio exilim ex-z75 over the phone for $4 (part) + $4.95 (S&H) because it not sold ANYWHERE online. I was hoping to get a cheap cable for a few bucks, but this is better than nothing!
Mar 25, 2008 | Cameras
E-Machines 17F2 17" CRT Monitor Logo
27 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
