Question about Philips Magnavox 51MP392H Rear Projection Television
Bad convergence board?
But all the lights come on with the one board unplugged from the rest. I found a site that sells my convergence board, but I'd hate to spend that much money if it's not going to work.
  • Philips Master
  • 3,459 Answers
Check the site www.magnavoxhelp.com. They have kits to fix this common problem.
Posted on Jun 24, 2008
I have a AV-56WP74. Recently it stopped working. If the unit is powered on, the speakers just thumped like a heartbeat. Then the power light just blinked. I found some solutions on this site. I found a 2.2...
replace the ICs
here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Sep 07, 2010 | JVC AV-56WP74 56" Rear Projection...
Mitsubishi VS-50805 HD 1080 Series
check the convergence ic's unplug the main convergence board plug then try the set again if the set comes on get a convergence kit here
http://www.tvrepairkits.com/xcart/home.php?partner=larry
May 16, 2010 | Televison & Video
Boe in blue dynamic convergence curcuitry. Swapped deflection yoke on two tubes but problem still remains. Unplugged convergence plug on yoke and bow disappeared but unable to adjust dynamic convergence....
what's the number of the board where you unplugged the conv yoke, should start with 930_ that is the board you need. Try the partstore.com with the part number or type in the brand and model when you have the number on the board, and they display price and availability.
Jan 15, 2010 | Mitsubishi VS-45609 TV
JVC AV56wp74 convergence. Resistor before ICs?
It's recommended to replace all the defective parts first because if you only replace the defective resistor, it might burnt again if the convergence IC is shorted internally. I would also suggest to measure the other low value resistors with multimeter.
Oct 30, 2009 | JVC AV-56WP74 56" Rear Projection...
Rca p46813bl convergence problem bowed in the
OK., I know this set very well. It almost never has a convergence problem.
With the set unplugged, remove the back cover--there is a small circuit board mounted ABOVE the main boards--it is about 10 inches wide and 4 inches tall---On the far right side of it are several DIODES---two are much larger then the rest--what usually happens is one of the large diodes is shorted--5 dollar part---the board only has a few plugs and 4 screws that hold it in---easy to remove--check all the diodes(the two large ones first)
If either of the large diodes read like a fuse you FOUND YOUR TROUBLE.
LET me know if you need ANY help or Advice--I am here to help people---I have seen several sets identical to yours with the problem you describe.
Regards, SD TECH
Oct 06, 2009 | RCA P46924 46" Rear Projection Television
Red light blinks no picture or sound
took the board to friend who works on TV's.he tested the board and replaced the 2 black IC's #STK 392-040 .I re-installed the board and TV so far is working fine. hope this helps !
Jun 18, 2009 | Akai PT4298HD Rear Projection Television
Convergence Board (I hope)
check this out I have the same problem check your solder spot make sure the solder points are not touching one another, that could be one of the reason is doing this or just to make sure you can desolder the stk chips clean the holes where the pins go trough the board and power the tv with board and if the tv start fine if could be bad stk chips be very careful when desoldering or soldering good luck about another is not worth it they cost too much around 350-450
Oct 06, 2008 | JVC AV-48WP74 48" Rear Projection...
View timer flashing t.v will not turn on
I fixed mine with help of this site. I needed the 2 convergence amps and 1 resistor on that board was bad also. I done what Premtech said and that was to unplug the power to the convergence amps an turn TV on well it stayed on looked like **** but that led me to change the amps. Search google for a pic of these STK392-040. Then you can look at back of your tv they hook to the convergence board. Unplug the biggest connector on it see if it turns on. If it does you need both amps, and need a dvom to check the low ohm resistors on the board. Or take it to someone that can solder it all up and check the board. Also saw where the flybacks can have cold solder spot.
Jul 26, 2008 | Sharp 55R-WP4H 55" Rear Projection...
Samsung hcm4215w Convergence board problem
Use PANASONIC STK's.They are expensive,but they hold up!Safe,durable repairs require OEM or BETTER quality replacement parts.
Sep 27, 2007 | Samsung HCM4215W 42" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
