Question about Asrock K7VM2 Motherboard
Asrock K7VM2 Motherboard Memory Upgrade
I have a Asrock K7VM2 Motherboard installed in PC (AMD Athlon(tm) XP 2000+) and would like to upgrade the memory. I have been told that it is very important to get the correct compatible memory.
The Asrock website lists the compatible memory as: DDR x 2, DDR266/200 non-ECC, un-buffered memory. (http://www.asrock.com/mb/overview.asp?Model=K7VM2)
By DDR266 - Im assuming its referring to fact that the speed of compatible memory should be 266Mhz.
I just opened my PC for the first time and looked at the memory currently installed. It currently has one stick (one slot is still free) and the label on this memory reads - TakeMS 512MB DDR PC400.
I believe that this is 400MHz?
To my understanding my PC has been running pretty much fine since I had it built, several years ago. Im now wondering - Is the TakeMS 512MB DDR PC400 actually the wrong memory (speed) for the motherboard?
If it's been working this long, shall I just assume its fine? (I'm abit surprised that it works if the compatible memory stated by AsRock, should be 266Mhz). It is possible that the manufacturer has not listed all compatible memory?
In relation to upgrading - I want to buy another 512mb memory stick to upgrade my ram to 1 Gig total. Shall I get a 266Mhz (512mb) one or another 400MHz one to go with the existing TakeMS 512MB DDR PC400? Does it matter at all? Will it effect the performance either way? Thanks in advance.
  • MrMxxx Jun 06, 2008
    Thanks. I was just unsure, as I assumed that, normally a manufacturers web site (and orginal literature & box that came with the motherboard) would be correct - and they all state: DDR 266 MHz as the compatible one.
    I'm new to this and was just suprised that AsRock state this size - but infact the PC400 (DDR 400 MHz) actually works (and is therefore compatible) aswell.
    I just wanted to 100 percent make sure as everyone keeps stating the importance of getting the exact compatible and correct memory to avoid problems.
  • MrMxxx Jun 07, 2008
    Hi again,
    You kindly provided me with somegreat info regarding upgrading my memory for my Asrock K7VM2 Motherboard. Many thanks.
    Can I ask a further question, does it matter is the memory is single-sided (32Mx8) or double-sided (64Mx64)?
    My
    existing 512MB says 32Mx8 but Ive been unable to find this info out on
    memory Im looking to buy online. I doesnt seem to be listed.
    Do you think that this memory will be compatible:
    http://www.ebuyer.com/product/45120/show...
    Thanks again for you time.
  • 6,487 Answers
Some MOBO support different type of memory modules like ddr 400, 333,533 and other, if your computer is working fine with that PC400 it only means that your MOBO is compatible with it. Since you're planning to upgrade the memory just get another PC400 because the memory should be the same to work fine.
Posted on Jun 06, 2008
  • Mark Gil
    Mark Gil Jun 07, 2008
    No problem now just realx and get an upgrade on your computer's memory , enjoy a much faster PC from now on.
I want a dual core processor upgrade
You listed this under PC Laptop? It's a Desktop? Have you ever done a CPU upgrade? You are limited to what will work with your machine, Mobo and other components. Your Mobo is, of course, AMD compatible, so if you read the specs: http://support.acer.com/acerpanam/desktop/0000/Acer/AspireX1200/AspireX1200sp2.shtml The AMD Athlon X2 dual-core is best option. Memory is a easy option to increase speed a bit. Remember, with a 32bit OS the most memory it can use is 3.80 GB's More or Less. With a 64bit OS use more. I have done many CPU upgrades, you may not get the Speed/ processing increase you expect. After all, the components work in conjunction with one another. Do your research on Socket type, Pins, Power requirments, etc., etc.Check, Verify, then re-Check and re-Verify. Use this little freeware program to assist you, it list Spec info in detail, SPECCY at: http://www.filehippo.com/download_speccy/.
Jan 12, 2013 | Acer Aspire Computers & Internet
Windows xp as rock sm bus controller driver
Hello you can download the driver here at asrock:
http://www.asrock.com/mb/AMD/M3A785GXH128M/?cat=Download&os=XP
The files you might download needs to be unziped before installation.
Please install the AMD all in 1 driver ver:8.512 first before you install the others.
Good luck
Dec 30, 2012 | Asrock Computers & Internet
Can u upgrade the processorto anything high then a amd duron(tm) 1.29ghz
On this motherboard you can use:
AMD Athlon (Highest being the Athlon 1400C running at 1.4GHz)
AMD Duron (Highest being the Duron 1800 running at 1.8GHz)
AMD Athlon XP (Highest being the Athlon XP 3200+ running at 2.3GHz)
AMD Athlon MP (Highest being the Athlon MP 2800+ running at 2.1GHz)
AMD Sempron (Highest being the Sempron 3300+ running at 2.2GHz)
Feb 25, 2011 | EliteGroup K7SOM Motherboard
How to upgrade processor on ASUS A7A266 motherboard?
looking at this old motherboard the 2400 is unlikely to work, the motherboard has a cpu fsb support of 133mhz and supports the duron processors.
offhand, 2400 wont work.
Mar 18, 2009 | Computers & Internet
Wish to increase cpu spped and memory
Hi thefuncouple, here is the ASRock link for supported CPU's:
http://www.asrock.com/mb/cpu.asp?Model=K7VM2&s=462
The Athlon XP 2600+ CPU is the highest CPU this board can support. (It will be hard to find one).
Main web site for the K7VM2: http://www.asrock.com/mb/download.asp?Model=K7VM2
Honestly, ASRock does not have drivers for Vista. Some of the drivers listed for XP may work with Vista. Your best chance is to download & run Windows Vista Upgrade Advisor 1.0
(Before installing Vista in to your system).
http://www.microsoft.com/downloads/details.aspx?FamilyID=42b5ac83-c24f-4863-a389-3ffc194924f8&DisplayLang=en
Vista, any version needs at least 1GB of memory. Two GB is recommended. After running Upgrade Advisor you will know if your ASRock motherboard can handle Vista. You should be able to upgrade to Vista (Over-writing XP) but only if your system passes the Upgrade Advisor.
Your best bet would be to buy a new system with Vista on it. Your ASRock board is just too old for Vista. You'll save money upgrading to a more supportive PC.
Good luck thefuncouple!
Vista is not for everyone, many users end up going back to XP.
Thank you for using fixya.
Mike
Dec 11, 2008 | Asrock K7VM2 Motherboard
How to upgrade
Here is the list of compatible processors for your motherboard:
AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
AMD Athlon MP 2800+ (Barton)
AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
AMD Sempron 3000+ (Barton)
AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
Apr 03, 2008 | AMD Duron , 750 MHz Processor
Fastest CPU available for the K7N2G?
Look for socket A processors and ignore the XXXX+ and focus on the XXXXMHz rating (the MoBo's manufacturer's support site will give you the max processor your Board will handle). Since you mention that your MoBo is 4 to 5 years old, you'll probably better serve yourself to replace the MoBo and processor (you'll be able to upgrade to a much better/faster processor by upgrading both, and shouldn't cost that much more), and probably be happier with the result. You may want/need to upgrade your Power supply while you are at it too.
Mar 29, 2008 | MSI K7N2G-L Motherboard
K7VT2 with a AMD Duron 1.30 GHz CPU.
Depends on which AMD processor you would use. If Duron you could go to 1.8Ghz. If you use Athlon XP you could go to 3200+. Athlon MP 2.1Ghz and regular Athlon 1.4Ghz.
Nov 13, 2007 | Asrock K7VT2 Motherboard
Asrock K7VM2 Motherboard Logo
445 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
