Question about Brother IntelliFax-2820 Laser Fax
Faxes won't print
The display says, Faxes in memory: 12, but won't print.
we have changed the cartidge, pressed print, etc.
Any ideas?
  • Anonymous Sep 29, 2008
    The fax will pick up and receive faxes, it just won't print them.
    Genius:
  • 2,120 Answers
Unplug the power cord for 10 seconds.
Open cartridge door, while open press "clear"
Posted on Oct 07, 2008
Fax memory full
To gain extra memory, you can turn off Fax Storage OR Print fax messages in memory (See Setting Fax Storage, page 48.) OR Expand the machines memory.
Retrieve or Erase a Fax
Press 9 6
then to
Retrieve all faxes Press 2, then enter the number of remote fax machine and then press # #. After
the beep, hang up and wait.
Erase all fax messages Press 3. If the data stored in the memory has not been printed before, it will be printed first and then erased.
Setting Fax Storage
If you set Fax Storage to ON, you will be able to retrieve fax messages from another location, using Fax Forwarding or Remote Retrieval functions. The screen will indicate when you have a fax stored
in memory.
1 Press Menu, 2, 5, 2.
2 Press left arrow or right arrow to select ON (or OFF), and press Set when the screen displays your selection.
3 Press Stop/Exit.
If there are faxes in memory when you turn the Fax Storage OFF, the screen prompts you to erase any faxes in memory.
If you press 1, all fax data is erased and Fax Storage is turned OFF. If the fax data in memory has not been printed before, it will be printed first, and then erased. If you press 2, data is not erased, and Fax Storage remains ON.
Feb 07, 2012 | Brother FAX-8360P Plain Paper Laser
Brother FAX-8070P memory shows full and does not send all pages at one time?
This message means the memory capacity of the unit has been exceeded. The amount of memory used depends on the amount or type of data on the documents being faxed or copied.
  1. If you get an "Out of Memory" message while scanning the first page of a fax, press Stop/Exit to cancel scanning.
  2. If you get an "Out of Memory" message while scanning a subsequent page, you can either press Fax Start to transmit the pages that were scanned so far or press Stop/Exit to cancel the operation.
When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify Fax Storage is set to Off by doing the following:
  1. Press the Menu/Set key.
  2. Press the arrow key until FAX appears on the LCD. Then, press Menu/Set.
  3. Press the arrow key until REMOTE FAX OPT appears and then press Menu/Set.
  4. Pressthe arrow key until FAX STORAGE and then press Menu/Set.
  5. Check the setting. The display will read ON or OFF. If the setting is ON, press the arrow key until the display reads OFF.
  6. Press Menu/Set.
  7. If you have faxes stored in the memory, you will receive a message that reads Erase all fax? 1. Yes 2. No. If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Note
    If you would like to reprint the saved faxes, press 2 (No), press Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
  2. Press the arrow key until FAX appears on the LCD and press Menu/Set.
  4. Press the arrow key until PRINT FAX or PRINT DOCUMENT appears and press Menu/Set.
  5. Press Fax Start.
  6. After printing is finished, press Stop/Exit.
Jun 06, 2011 | Brother FAX-8070P Plain Paper Laser
How do you retrieve the old faxes? The paper wasnt in the right feed and a bunch of faxes came in and it never got through. I need to retrieve it.
? Printing All Unprinted Documents in Memory
1 Press [Menu].
2 Use [{] or [}] to select , then press [Start/Copy].
3 Use [{] or [}] to select .
4 Press [Start/Copy].
The fax prints the documents one at a time, after each the reception number is displayed on
the LCD.
5 After printing, the LCD displays .
6 Press [*] to delete the previous printed documents.
If you want to keep the documents in memory, press [#].
Jan 31, 2011 | Canon FAX JX200 Fax / copier Plain Paper...
Faxes are going to memory, there are two faxes in memory, I am not able to print these
Make sure that auot print off is not displayed and if it is press the on/off button and it will go to on!Good Luck!
Apr 16, 2010 | Canon FAX-JX200
Said that cartridge was empty after changing cartridge,got that cleared and now it will not receive a fax. What do I need to do
Your faxes are probably stored in memory. They automatically print when the a) cartridge is installed properly full, b) fax has paper, c) there is no paper jam.
There also may be a "Print Hold" function activated.
1. Press <print hold> [RCV DATA PRINT] will display.
2. Press "Right Arrow" on the <start/memory> button.
3. Enter 4-digit Print Hold code.
4. Press <start/memory>. Printing will begin. If the wrong code is entered [WRONG CODE] will display. Go back to step 3 and start again. Once you've entered the wrong code 3 times, you will return to your standby display.
Mar 25, 2010 | Sharp UX-B750 Inkjet Fax
Incoming faxes stuck in memory, how do I print them. Prior to this the faxes were coming through, but half printing then jamming, so press start and that peice of paper would come out then the next go in...
This answer maybe a little late for you but for anyone else tring to print fax stored in memory:
1. Press Menu - Fax Functions will display
2. Press 2 - Print report will display
3. Press Enter - Last Transact will display
4. Press 7 - Reprint Faxes will display printed the pages
5. Press Enter
This will print all faxes in memory. Press Stop when you have printed the pages you need.
You can print fax log (Press 2 after step 3) to see what is in memory
Oct 01, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Status NG BO
POWER OFF THE MACHINE PRESS 1 3 *(star) together. switch on machine while holding this three sw.
machine will rest.
May 05, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
Canon Laser Class 7000 - 'RECEIVED IN MEMORY' showing on display
Hello Tony,
You are right about that. The messages are indeed sitting in memory.Here's the procedure to print them out.
Step1: Press the memory reference button in the one touch speed dial panel
Step 2:Press the search keys(arrow keys under the one touch dialing panel)until the option "print document" is highlighted and then press SET.
Step 3:Press the search keys again to select the transaction ID of the document you wish to print and then press SET.
Step 4:Press # to print the whole document or * if you wish to print only the first page.
Jan 15, 2009 | Office Equipment & Supplies
How do I print off fax in memory Panasonic model no KX-FP215E?
when msg is displaying on screen fax in memory .install paper and press fax start key.all faxes in memory will bi print.by mian jee
Dec 02, 2008 | Panasonic KX-FPG378 Fax
Canon jx200 fax machine
The fax automatically turns off Auto Print and stores faxes in memory when either ink or paper is low. The memory will store up to 30 transmissions or 60 pages maximum, so it is important not to leave this too long if you have heavy transmission volume.
Faxes can be retrieved as follows.
If you want to choose only certain faxes to print:
1. Print a list of documents in memory for reference:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Doc Memory List, and again press Start/Copy.
2. Print a document from memory (using the list printed in #1):
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print Document, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to print, and press Start/Copy. The LCD will then toggle between "1st page only?" and "Yes=(*) No=(#)". Press * to print only the first page, or # to print all pages.
3. Delete selected document(s) from memory:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Doc, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to delete, and press Start/Copy. [Note - if the arrows do not result in another number displaying, there is only one document in memory.] The LCD will show "Yes=(*) No=(#)". Press * to delete the document. Continue to select documents until each document you want to delete has been handled.
If you want to print all unprinted documents in memory:
1. If you want to have a list of documents in memory for reference before performing this procedure, to be sure you have them all, follow step 1 from the above procedure for printing selected documents.]
2. Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print All New RX, and again press Start/Copy.
3. Delete all printed docs from memory:
Immediately after printing all documents, you will have the choice of deleting all documents. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory.
To delete all documents at a later time:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Printed RX, and again press Start/Copy. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory. To finish then, press Stop.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 06, 2008 | Canon FAX-JX200
Brother IntelliFax-2820 Laser Fax Logo
148 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
