Question about Dishwashers
Motor sounds when the dishwasher is turned to the on position but the dishwasher won't turn on.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Sounds like the drain pump is on. Pour in some water, and see if it drains out. On the LG they have a float switch on the left side, it could be stuck up causing the drain to activate.
Other units have a float switch on the bottom floor and there could be water or the float could be warped.
Sgt 48
Posted on Jun 07, 2008
Dishwasher won t fill
I had a similar problem with a Kenmore; the problem turned out to be that the float was stuck. On the bottom of your dishwasher there should be something that looks vaguely like a plastic mushroom - that is the float. Just tap it gently and see if it goes down a bit. If it does, gently move it up and down a few times to make sure it's moving freely (make sure to leave it in the down position) and then try to launch a cycle. Good luck!
Mar 18, 2014 | Siemens Dishwashers
I start the dishwasher and it does nothing and lights do not turn on either
When your dishwasher won't start, it could be a problem with your electrical panel or the door might not be closing properly.
Check your household electrical panel for a tripped breaker or blown fuse. Also check to make sure the door latches closed properly.
For additional troubleshooting steps you can take and things you can do, read Dishwasher won't start for more suggestions. I hope this helps!
Aug 02, 2012 | Kenmore Dishwashers
F2 and a spanner appears after it is turned on to operate
Hi
F2 error is displayed when control won't sense motor to be rotating, usually occurs due to frozen/bad motor or stuck motor rotor or the RPS sensor or a bad stator assembly. If the motor rotor spins freely and both impellers are securely attached then the issue is with the RPS sensor. If the motor won't rotate then it is the motor rotor that has to be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
My kenmore elite dishwasher 665.17053400 motor sounds like its seized. The machine fills and drains ok but won't do a wash cycle. Moter makes a buzzing noize.
This might help you - this type pump assembly doesn't seem to be a serviceable unit - just replaceable.
http://www.youtube.com/watch?v=vNQvDqzMZV4
May 27, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore Elite 665.17053400. Powers up ok, fills up with water ok, but wash cycle won't start. I can hear the motor trying to turn but sounds like its seized up. If I cancel the wash, the machine drains...
This dishwasher has a very sophisticated wash system. In order to improve the wash efficiency it uses a chopper and a soil sensor. It is very likely the chopper assembly is clogged which is blocking the water from circulation and straining the wash motor.
See this diagram. Item 6 is the chopper. Worst case is the pump motor needs replacement. This is item 10.
Good luck
May 27, 2011 | Kenmore Dishwashers
Dishwasher fills but does not wash. Dishwasher will drain if program cancelled.
Do you hear a humming sound, like the motor trying to run, then stopping for a minute or two before trying again?
Usually, dishwashers run the motor one direction to wash, and the opposite direction to drain, but some use a valve to switch. If you see wires going to a bulky flapper looking part sticking off the side of the pump/motor, you might have a bad valve actuator.
Otherwise, you might have a motor refusing to turn in one direction. You can usually access the shaft from inside the tub by removing the washer arm to get access to the pump impeller. Do not remove the impeller unless necessary, but see if it will turn both directions. Broken glass or pieces of bones or other debris might be interfering with the rotation. If it turns freely both ways, but still won't wash, it is likely you have a bad starter coil on the motor, and will need to replace the motor/pump assembly. These usually have a longer warranty than the rest of the unit, so if yours is less than 5 years old or so, it would be worth checking with factory service.
May 18, 2011 | KitchenAid KUDK03ITBK Built-in Dishwasher
The detergent cup lid stopped closing on my old GE Model # GSD600G-0l dishwasher. Tried turning the dial clockwise to the Off position, but it won't work.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
May 10, 2011 | GE Dishwashers
Dishwasher will not empty after cycle and motor makes humming noise hotpoint dishwasher bf1260
The motor is frozen. Remove the bottom kick plate and with unit in off position take a screw driver or use your hands to turn the motor. You will feel the motor when it lets go. Close door and turn on dishwasher and you should be fine. Very common with the GE made dish washers.
Apr 27, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
