Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore 596.72913200 Refrigerator is Warm,freezer not freezing
P.S. I already replaced the defrost timer and the back wall of the freezer still has ice. What do you suggest. Thx! You've been very helpful .
  • luseeedwards Jun 09, 2008
    Thank you 22yooper for your insight.
    Can you tell me, once I take off the back panel wall of the freezer section how do I identify the Defrost Heater and the Defrost Thermostat? I searched on Sears PartsDirect to find a diagram with these two items but nothing came up.
    Thanks again
  • Anonymous Mar 25, 2014
    refrigerator and freezer were not cooling/freezing so we unplugged the refrigerator and defrosted, cleaned the coils and everything under and in back of refrigerator.left it unpluged for 48 hrs. pluged the appliance back in and now it runns continously. any suggestions
  • 828 Answers
The frost on the back wall of the freezer with a new timer installed indicates that the problem is beyond the timer in the defrost circuit. In this circuit you have a defrost heater and a defrost thermostat. One of those two is your problem.
If you have an ohm meter available and have the knowledge how to use it you can access the heaters by removing the back panel wall of the freezer section. Disconnect the heaters from the circuit and read the meter for continuity. If you read Ohms through the heater(s) your problem is in the thermostat.
Posted on Jun 08, 2008
  • James Helmer
    James Helmer Jun 09, 2008
    There are two types of heaters used. One is a glass tube with a heater coil inside. These are usually two in series. These heaters are connected together by one wire in between. On the other end of these two heaters is a wire on each end. Disconnect the wires from their supply point(not at the heater) and test with an OHM meter for continuity. You should have a resistance reading. If no reading change the heaters. They come as an assembly.
Refrigerator and freezer get cold but freezer does not freeze whirlpool 1997 model et22dkxfn00
Can you remove the rear panel in the back of your freezer and tell me what the frost pattern looks like? When a refrigerator loses Freon the frost pattern looks like this photo HERE If the rear wall of your freezer looks like this you still are having a defrost problem photo HERE
Here is what that will look like behind the rear panel of the freezer should the defrost heater and defrost thermostat need replaced HERE
You mentioned that you have already replaced the defrost timer so we should not be concerned about that. The defrost heater=> 2315530 Defrost Heater
The defrost thermostat=> 4387503 Defrost Thermostat
I will be here should you have questions or comments, Thanks Sea Breeze
Mar 04, 2013 | Whirlpool Refrigerators
2 year old Kenmore side by side refrigerator is too warm
the freezer feeds the refridgerator with cold air,when you open the freezer door,do you hear the fan blowing,if not you need to change the evap fan motor,next take out the second from bottom food bin and touch back wall,if you feel snow or ice you have a defrost problem, you'll have to take off back wall,advance the timer till it clicks into defrost and see if the heater comes on,if so you have a bad timer,if not read out the t-stat and the heater,if there are plug in wires on t-stat unplug them and bypass the t-stat by plugging t-stat wire to heater if heater comes on change t-stat,leave the heater on to help you defrost the ice off of evap coil and use hair dryer to melt ice,hope that helps
Nov 02, 2009 | Kenmore Refrigerators
Refrigerator won't defrost.
Replace the defrost thermostat and defrost heater in the freezer.
Aug 19, 2009 | Kenmore 71279 Bottom Freezer Refrigerator
Kenmore 5458 refrigerator too warm. Freezer
It is probely freezing up. The cool comes from the freezer to the ref. side and when it does not defrost it builds up frost or ice and then the air can not get through. Could be a timer or a defrost heater.
Aug 04, 2009 | Kenmore Refrigerators
Freezer is not cooling properly
Look inside the fresh food section behind and inside the control panel for a defrost timer and circuit board. Let me know when and what you find. Please unplug first, Thanks, Sea Breeze
E. Cold Control & Defrost Timer/Automatic Defrost
Control
These parts can produce a snapping or clicking sound
when turning the refrigerator on and off. The timer also
produces sounds similar to an electric clock.
Mar 27, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Kenmore fridge side by side keeps freezing up
defrost problem,check,freezer fan,remoce freezer back panel,check heater,find and check defrost timer,most are in the frig.if it is manual put it in defrost then check to see if the heater ib the freezer comes on,if it does then you have a bad defrost timer,if not,the freezer heater or terminater(attached to coils)is bad,chevk with your meter,let me know-mike
Feb 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Side by Side Kenmore Elite
hi thanks for the question well you have a no defrost problem with no power go to the cooling nit you will see a small disc with 2 wires going to it buy one first its called a defrost termination switch replace the switch thanks the appliance doc
Sep 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore regrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
    Mike
Aug 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Oct 13, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
287 people viewed this question
Top Kenmore Refrigerators Experts
Jim Goldsmith
Jim Goldsmith
Richard Roth
Richard Roth
deton8 von Splosion
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
