Question about Fedders A7DH45B2A Dehumidifier
Fan won't turn on
How do I replace the motor for the fan? And where can I purchase this part?
  • Anonymous Jul 15, 2008
    I need a fan motor - and want to know where I can purchase one for this unit. Any dealers in the midwest area.
Take cover off and make sure fan is not caught on coil.
Posted on Jun 08, 2008
The fan won't Start ,
Denis, the problem could be the result of a couple of basic things.
1, The air intake filter needs to be removed and cleaned.
2. The humidity extraction level may be set to high. Lower it to 35%.
On the mechanical side: The fan motor may have failed or the wiring to the fan motor may have come loose. In addition, there is a sensor that controls the fan's operation and that may have gone bad.
With all of the above, I'm betting on one or both of the first 2 things.
Hope this helps you troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 20, 2011 | Goldstar DH304 Dehumidifier
Unit trips breaker after running for short period of time. compressor is extremely hot and has odd smell.
From hat you have described, it sounds like the fan motor or the compressor is overheating and you should stop using the unit immediately. Especially, since it's tripping the circuit breaker. As far as how to repair it is concerned, you won't be able to tell if it's repairable until it's dismantled and all the systems are checked. Plus, Fedders as you knew them, when you purchased this unit, no longer exist. Some parts are still available, but they are in few supply. You may simply want to replace this unit.
Hope this helped you. Please let me know.
Jun 19, 2011 | Fedders R6DH45X Dehumidifier
Blower motor quit
u should have a number on the unit to call if not call the place it was purchased and see if they can get u in touch with someone who can help but that should definitely be a warranty part
Feb 23, 2010 | Haier HD656E Dehumidifier
The dehumidifier's fan does not turn and makes a humming noise
first,make sure the fan blade hasn't gotten stuck on the shroud and cannot turn,then shut off machine and by-hand rotate fan and see if it spins to a stop after several rotations,if it stops quickly there is a bearing problem with the motor,this is normal after many years of service,then replace the motor
Jan 26, 2010 | Dehumidifiers
AMCOR SD10 Dehumidifier, Need to replace the electric fan motor.
Take it out, and search the part number on line, they are bout $40 with s/h. however my current discovery:
It made no sense to me that despite no visual issues, the fan motor is bad. So, with further research it turns out that the true culprit is the small thermistor/thermal fuse between the orange wire (ground) and motor winding wire. The thermistor is taped underneath the silver aluminium and yellow tape on the fan motor. I heard about this bad (open/no continuity) thermistor makes almost >99% of the fan motor problem regardless of any brand name because this cheap c-fram fan motor is NOT made in USA. I opened the motor, there is a silver (aluminum wrap) around the windings for the motor that needs to be cut. Careful not to cut the motor windings. Inside there is a thermistor or type of temperature sensor connected between the orange wire and a motor winding wire. On my motor this was no longer working.
The part marked "JET 123 NM1 2A 130C" is a thermal fuse. The 130C is the temperature rating. When the motor get hot (130C / 265F) the fuse opens. The circuit is broken and the motor stops.
The motor is still good. The fuse is blown. It must be replaced to get the motor running again. You could bypass the fuse but then you invite a fire hazard.
A replacement fuse is available from Digi-Key. It is a Cantherm SDJ1 DF128S (128C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1133-ND
Part cost 98 cents
You might want to go with the next higher temp (141C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1134-ND
Dec 30, 2009 | Amcor Dehumidifiers
The fan seem to have quit working and the unit got loud. i oiled the fan but it doenst turn on but the compressor comes on but overheats quickly.
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Jul 31, 2009 | Dehumidifiers
Fedders 65 Pint Dehumidifier Fan Problem
I have the same problem. The fan motor bearings are bad on mine. You can get a new fan motor at Appliance Factory parts.com. Phone number 1-800-955-7075. $44.95 + shipping.
Gene
Feb 05, 2008 | Fedders A7DH65B2A Dehumidifier
Fan not working
You can purchase a new fan motor. But the same problem will probably happen again. I opened the motor, there is a silver (aluminum wrap) around the windings for the motor that needs to be cut. Careful not to cut the motor windings. Inside there is a yellow thermistor or type of temperature sensor connected between the red wire and a motor winding wire. On my motor this was no longer working (in effect it was an open circuit). Once replaced the motor worked fine. this is the second time in about two years that this problem happened. The first time Sears fixed for about $100 and three weeks. This time I saved the money and did the repair myself. I would guess you could buy a new thermistor for about $5.00 from a parts house like digiKey or National Electronics. You will need to know how to use a soldering iron to repair this.
Jan 18, 2008 | Kenmore 54701 Dehumidifier
Fan does not come on
I've seen abunch of these. The fan motor has a fuse wound into the windings. It cannot be replaced you need a new fan motor. The motors seem to run hot normally, leading to a short lifespan.
 I suggest buying a better brand unit.
Oct 23, 2007 | Comfort-Aire BHD-651 Dehumidifier
Fedders A7DH45B2A Dehumidifier Logo
43 people viewed this question
Top Fedders Dehumidifiers Experts
Bill Long
jasbo
jasbo
Albert
Level 1 Expert
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
