Question about Whirlpool RS675 Electric Kitchen Range
Find the IC
Hi, i need to know how can i find the IC that control the screen & all in that board, i think that´s the failure. The oven doesn´t work and the screen lights so low.
  • 868 Answers
THE LOW SCREEN IS TYPICAL BUT DOES NOT AFFECT THE OVEN (JUST YOUR EYES),.....REPLACE THE OVEN IGNITER...
PLEASE LEAVE A RATING !!
Posted on Jun 07, 2008
What do I need to do to fix a blank screen on a whirlpool built in oven?
Often the Whirlpool built in ovens have a control board failure which causes the screen to go blank. May be intermittent and may be accompanied by an E6 F2 failure code on the display (before it blanks out). We rebuild a lot of control boards for this problem. For example see:
http://www.fixyourboard.com/boards/8302967.html
Mar 18, 2015 | Whirlpool Ovens
Samsung Microwave-Oven Control Board IC corrupted. Hi, I have Samsung Micro Oven Model CE1031L/CE1031LATB whose IC is corrupted. When we called service centre,a guy came claming as samsung...
I dont understand the last part of your issue but if you get that part and put it in, you may have an issue because something caused that part to fail in the first place.
Jan 06, 2014 | Samsung ASSY DOOR;CE1031LAT/XTL, -...
----c fault on display
I am not trying to stop you from trying to repair your Oven; however, the cost to replace circuit boards including your time and effort exceed the cost of a new Microwave.
Lowes has some as low as $150.00 and dent or blemish for far less.
Dec 23, 2013 | Microwave Ovens
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
F1 error relay circuit failure
Hi This is the Alarm system watchdog circuit :
The system has detected a failure in the internal watchdog element , relay circuits and will atcivate a cancel feature. F1 will be displayed in the time digets and will beep until the cancel button or another funtion is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure the ERC is picking up a comand to supply heat without receiving an input from the membrain. The watchdog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control ERC board.
Dec 09, 2011 | Dacor MCS130 Millennia Electric Single...
Hi i have Frigidaire electric stove model# ples389ecd stove part works oven displays f 30 and half of key panel doesn't work. Replaced board, key panel , probe still have f 30 problem and key panel...
Hi u_odil,
The F30 on your display means that your oven thinks that your oven sensor is shorted. It's either a bad oven sensor or a bad display relay control board. You can't test the board but you can test the sensor. Open the door and remove the 3-4" long thin metal rod attached to the back wall. There are 2 screws holding the sensor on that you can remove and then pull the sensor forward until you can disconnect it. With a multimeter, check the resistance of the sensor at room temperature and it should be about 1080 ohms. If it's not, replace the sensor, otherwise you need to replace your relay board.
Hope this helps.
Thank you for using FixYa.
Sep 21, 2011 | Frigidaire PLEF398AC Electric Kitchen...
Oven not heating byt its making noise like the fan is working. Light is on
Your symptoms point to a failure in the electronic oven control board (that acts as the thermostat for the oven in this type of range). Unplug the range and remove the upper back panel to access this component. You will likely see to burn marks on the control board. The control board will need to be replaced in this situation.
Hope this helps.
Shane
Mar 10, 2011 | Ovens
Theres nothing on the screen but the audio works. when i turn it on there no picture showing. the screen is just black
The failure with plasmas when the TV turns on but doesn't show any video only audio, the failure is with a defective Ysustainer board. The hybrid IC that is located under the aluminum heatsink becomes defective due to the excessive heat when the TV is functioning.
I would suggest that if you're fixing the TV yourself to measure the voltages from the power supply to the Ysustainer board to isolate the failure, if all the voltages are present then check any fuse on the Ysustainer board first. If any fuse is blown, then the Ysustainer board will need to be replace. Most service techs will replace 3 boards when this failure occurs. The Ysustainer, Zsustainer and main digital controller boards.
Check this link to find parts to fix your plasma.
Let me know if you require further assistance.
Nov 21, 2010 | Funai F42PDME 42 in. Plasma Television
Bake and broil touch screen will not work, can't set oven temperature
Kenmore ovens seem to be notorious for control board failures,it seems that you may have one that needs to be replaced. Good luck !
Nov 25, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
E2 F6 ??? What the? Oven came with house, no manual.
Your oven temperature sensor has failed(e-2) as well as your electronic control board(f-6). The oven temp sensor, electronic control board and the touchpad must be replaced . Approximate cost of parts is $500.00. Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Jun 12, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RS675 Electric Kitchen Range Logo
82 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
