Question about Westinghouse LTV-32w3 HD Television
Aspect Ratio Won't Adjust Properly
Suddenly our picture is too big for the screen and the crawlers don't show up. There are only two options in the aspect ration setting - standard and fill - and neither one of them make the picture small enough to view the crawlers (this is especially annoying during NASCAR races when we can't see the stats). It has not always been this way, so we know there has got to be another setting we can adjust. Any help would be appreciated!
If you have a aspect/zoom button on your cable remote this may help,good luck
Posted on Jun 15, 2008
Picture on screen is too big head of people are cut off it does not show complete picture
Use your cable or satellite tv remote to adjust the aspect ratio. If you have cable there is a button on the remote called hd zoom and it has this symbol: #. On the satellite tv remotes it usually says format or aspect. You might even have to go into the cable box/satellite tv receiver menus to adjust the aspect ratio/picture format. Once you have done so you can fine tune the picture even further with the television remote's wide/format/aspect/zoom button. Also check and make sure your television is on the right input and that your cable box/satellite tv receiver is set at the right resolution for the television 1080p/1080i/720p.
Jul 12, 2011 | RCA HD52W59 HDTV Projection Television
I have a 42LG30 and the screen size is two big and I cant seem to find out how to manually resize it. The piture on the screen is two wide on the sides and the picture has a streched look as well
Ok just to clarify, your saying you use to be able to manually adjust the aspect ratio and now the option isn't available anywhere? and the setting doesn't exist in the manual? Are you sure it was a tv setting and not a setting for a device that was being output to the tv?
Thanks,
Lee
Jan 13, 2010 | LG 42LG30 42 in. LCD HDTV
Insignia 32" NS 32 q09
Since you don't mention how you're receiving the signal, I'm assuming you use a cable box or computer. Adjust the output settings (e.g. 720p, 1080p) on the box and then adjust your TV settings. If it's a computer, you'll need to adjust the video card settings to a compatible aspect ratio (e.g. 1366x768) for the desktop to display properly on the TV. Details can be found in the owner's manual.
Jan 04, 2010 | Insignia 37" LCD Flat-Panel HDTV
Picture size doesn't fit the screen I tried to adjust the aspect ratio but the option is locked on the menu. What to do? (Olevia TV model lt42hvi
You cannot change aspect ratio when recieving HD signal. Try changing the cable box or satellite box format or aspect ratio.
Dec 30, 2009 | Televison & Video
Why did my picture become big so I can not see the sideline information
Press the RATIO button repeatedly to select the desired picture format. You can also adjust Aspect Ratio in the OPTION menu.
  1. Set By Program. Selects the proper picture proportion to match the source’s image. (4:3 → 4:3, 16:9 → 16:9)
  2. 4:3. Choose 4:3 when you want to view a picture with an original 4:3 aspect ratio, with gray bars appearing at both the left and right sides.
  3. 16:9. Choose 16:9 when you want to adjust the picture horizontally, in a linear proportion to fill the entire screen.
  4. Horizon. Choose Horizon when you want to adjust the picture in a non-linear proportion, that is, more enlarged at both sides, to create a panorama view.
  5. Zoom 1. Choose Zoom 1 when you want to view the picture without any alteration. However, the top and bottom portions of the picture will be cropped.
  6. Zoom 2. Choose Zoom 2 when you want the picture to be altered, both horizontally extended and vertically cropped. The picture taking a halfway trade off between alteration and screen coverage.
  7. Cinema Zoom. Choose Cinema Zoom when you want to enlarge the picture in correct proportion. Note: When enlarging or reducing the picture, the image may become distorted. You can adjust the enlarge proportion of Cinema Zoom using D / E button. The adjustment range is 1~16.
Oct 18, 2009 | LG 42LC2D 42 in. LCD HDTV
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
I cannot change the aspect ratio on the TV. When I go to the menu, Aspect Ratio is in red and I cannot select it. On certain channels the screen is too big and I can't see the edges of the broadcatsed...
This is a quote of what Sanyo told me: "The aspect ratio can only be changed when the unit is in the video mode." So I tried switching modes with the input button and it worked but went to like a letter box/wide screen type of picture, which doesn't help me. We have dishnetwork and on the Panasonic plasma we can adjust the ratio with their remote so I have two options there but not with my Sanyo unfortunately. Hope this helps
Jul 22, 2009 | Sanyo DS24425 24" TV
Icons and screen not sized properly-too big and out of proportion
Right click on your desktop
Click Properties
Click on the Settings Tab
It will say resolution with a sliding bar, you can move that around untill you find the right aspect ratio. Try 1024x768..
Hope that helps let me know :)
Jan 05, 2009 | Acer AL1916W 19" LCD Monitor
Televison & Video Logo
232 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
