Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Not draining water and water does not shoot out of sprayer arm
Hi-
My dishwasher is not draining the water. The washer arm is not spraying the water on dishes. When I open it after it runs its steamy but the dishes are dry and the water just sits in the bottom of the dishwasher.
  • 1 more comment
  • Anonymous Jun 14, 2008
    EVERYTHING WORKS EXCEPT WATER DOES NOT DRAIN
    COMPLETELY. CANNOT REMOVE THE APPARATUS ON THE
    BOTTOM BECUASE OF SPECIAL HEADED SCREWS...
  • patricklaw Oct 02, 2008
    my dishwasher is maytag quiest series 100 model number MD8F550AWW. Thanks for your expert help!!
    Kelly
  • robert samples May 11, 2010
    give me your model number
    Sergeant:
    Champion:
  • 262 Answers
Try cleaning the drainat the sink alot of time gunk will build up in the connector to the sink very easy to look at as far as one4 sugg it sounds like the motor may be jammed or soething is in the pump you can get the special bit at lowes or your local hardware store i cant rember the size off hand i get them in alot of different sizes at a time so i have them on hand If any one knows the size please let them know thanks
bil
Posted on Jan 08, 2009
Frigidaire dishwasher is not spraying water from bottom
From what you have described, sounds like the sprayer arms are possibly loose or being held into place and can't rotate, by dishware.
Aug 07, 2012 | Electrolux Frigidaire Professional Series...
I had the same problem I own a Kenmore Elite dishwasher. Diverter motor needs to be replaced. The diverter motor is connected to a plate that controls the flow of water to each washer arm. When the plate moves it has holes that align to the proper tube that supplies water to a washer arm. When the diverter motor is broken it is unable to rotate and cannot direct flow of water. When this happens water will only be able to come out of one spray arm in my case the back sprayer or turbo wash. The diverter motor is located under the dish washer and the diverter plate is located under the bottom sprayer arm.
Dec 01, 2011 | Kenmore Dishwashers
Bottom Sprayer not spraying. does not look blocked
1)wash arm not spraying(or)rinse not spraying?
wash arm
1)remove the wash arm
2)switch on the machine all blockaged removed automatically.(remove the wash arm).
rinse arm
1)check any scaling in the boiler tank.
2)clean the boiler tank.
3)clean the rinse arm.
Jan 07, 2010 | Dishwashers
Motor makes noise shortly after starting, makes normal sound level during main body of wash, then makes noise again during what I'm guessing is the rinse cycle. Not sure if it is a pump or motor problem....
Make sure the sprayer arm is turning freely, check for something stuck in the base of the sprayer arm (food or utinsel) preventing it from turning.
Sep 22, 2009 | Dishwashers
Top sprayer not working
Check and clean the filter inside at the bottom of the dishwasher. Make sure the spray arm rotates freely and that the holes are not clogged. If the dishwasher has a collapsable tower to shoot water into the upper spray arm, make sure it is not stuck and that nothing is blocking it from rising.
Sep 21, 2009 | Dishwashers
My 6 yr old Kitchen Aid dishwasher is leaving food residue
After checking all sprayer arms for clearance, and checking heating element and discharge pump, the problem was solved by replacing the small sprayer arm at the top of the washer. This small arm had popped off some time ago - obviously the water pressure was excessive for the small and unimpressive fastener. Luckily we had saved this piece, which I refastened with a strong aluminum non-corroding small bolt. Presto - now the water distribution is back to design specs, with sufficient water coming out under pressure from the mid level arm. Lesson: always look for the simplest cause first with the simplest solution. TCA
Jun 20, 2009 | KitchenAid Dishwashers
Water won't spray
Sounds like whatever caused the clogged drain may also have clogged the sprayer arm.  If it is clogged it will not spin.  Remove the arm and if it is clogged see if you can clean it out.
May 29, 2009 | Asko D1776 Stainless Steel Built-in...
Dishwasher does not clean items on top shelf.
Check the upper spray arm holes for debris that may be plugging up the spray arm. If clean remove the lower spray arm and filter screen and clean out any debris in the sump.
Feb 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Nov 19, 2006 | Frigidaire 24 in. FDB126RB Built-in...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
231 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
