Back to:
Tags:
Nakamichi CD-35z CD Changer
Q: Nakamichi cut out at 2/3rds volume problem...
By Reynolds - usenet poster
I have a question
I recently upgraded the car component around my audio system, and
consequently had to replace a few things they, being speakers.
the unit is a Nakamichi indash CD unit running only 4 relatively small
speakers, problem is it cuts out at about 2/3rds of the maximum volume,
which in an Alfa with a 3" exhaust is not adequate really.
Nakamichi CD35Z - 4 x 43W [4 Ohm]
2 x VDO HSP 1321's - MAX 110W, NOM 30wW
2 x Eurovox 6420 - - [I think 20W nom. ]
possible problem:  is as Italian cars frequently have no 'accessory' power
setting and CD units need two supply's, one always on, and one that works
only when the engine is on. I had to wire up the Unit's standby system power
supply to the old systems power source and connect the units internal AMP to
the rear window power supply. although if i operate the windows during play
nothing happens.
any suggestions?
/carmoda
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 11, 2005
Not Rated (0)
Powe33
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Regardless of any problems you're having, I'd recommend wiring the permanent
supply straight to the fused side of the main fuse box (or even straight to
the battery if you're feeling adventurous), and the switched line to the
switched side of the ignition.  It sounds like it's all been bodged a bit,
which isn't going to help one bit when you come to upgrade with some amps
ands subs   :-)
Steve.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Q: Nakamichi cut out at 2/3rds volume problem...:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Ranny
Rating: 0%, 0 votes
Sounds like your power supply isn't strong enough. Wire it up properly !
Thank You!
Can you Help with these Car CD Changers problems?
Car CD Changers
No sound and error on board Dx (spinning digits of FM)...
Car CD Changers
kenwood kdc-122 playing cd in car. radio, cd player, quit...
I have a viper with a Nak in it. Its been sitting for some...
Hi. would like to know if the stereo on the radio can be...
Does any one know the wiring for the MF31 changer or the...
Loading problems.
Repair Service
Find Car CD Changer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
