Sony PVM-20M4U I have this Sony PVM-20M4U pro monitor which blew the horizontal output transistor Q501 (2SD1878). I've replaced it and it seems to be working ok...exept that the transistor is getting almost hot on the heatsink. I've checked the waveforms on the base and collector and they seem to look clost to what the service manual shows. My question is, do these transistor usually run that hot? Or is there supposedly something that's causing it to get that 'warm'? Bob
  • 4,234 Answers
These will run a bit hot, but make sure you have enough compound on it. If the old stuff was dry, use a solvent to remove it and replace the compound with plenty of new stuff.
Dan
Posted on Jun 06, 2008
Sony KP53S75
Hello
there is some shorted component/s in the horizontal output section of your project TV. check them. Horizontal output transistor and transormer should be checked.
Feb 20, 2012 | Sony Televison & Video
Hi,im a technician and i got a problem with a Sony Trinitron Colour television model Kv-T29mn3. I replaced an Str, capacitors & Horizontal Output Transistor. Voltage output its okay but it keeps on...
These sets had alot of problems with bad FBT flyback tranfomers,You might need to change FBT.
Heres another thing they also had Bad Picture Tubes that will blow hori output and you will not know its the Tube untill you replace the FBT.Use a high voltage probe to monitor Voltage coming from the anode button, if you dont have a HVP then disconnect the CRT board and monitor set.
Jun 26, 2011 | Sony KP-57HW40 57" Rear Projection...
When i turn on horizontal output tripping. B+ and low voltage ok
Hello
Check the LOT and Horizontal Output Transistor. If horizontal output transistor get shorted [collector to emitter or collector to base], this kind of fault will occur. Here there is nocollector to emitter short as B+ is ok. Check for collector to base leak. It is best to repalce the horizontal transistor with a new one, and switch on the Tv for a short while, say 10 seconds or so, and feel the heat of the replaced transistor. If it gets overheated, of LOT makes a whisiling of hissing sound, LOT is faulty, and shoul be replaced sith same type and number. OK.
Apr 17, 2011 | Sony PVM-14N6U TV
H out transistor defetive & number missing plz solve
Hello
The horizontal output transistor number for Sony KV-ES34M61
Horizontal output - [Q6807] == 2SC5480-01
Pin output - [Q6808] == 2SC5480-01 Again
Please replace bothe the transistor at the same time. Check horizontal output transformer [LOT of HOT], for any defects.. Ok
Jan 06, 2011 | Sony KV-ES34M61 34" TV
My 36xbr800 blinks six times then pauses then blinks six times, this is repeated......
Check the voltage input to horizontal output transformer [LOT]. Check the voltage at the collector point of the line drive transistor. If the line drive transformer primary gets open this type of fault mau occur. Also check the frequency ant the collector point of line drive transistor and the base point of line output transistor. It should be aroung 15625 Hz.
Check and replace the horizontal output transistor if needy. Replacing it is better. The horizontal output is not working or a short in secondary power supply of SMPS or lot secondary, is your problem
Oct 14, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My sony KV32 FX65B trinitron stopped working.. i took it to a technician and he said i needed to replace the FBT (fly back transformer) along with two transistors. I just replaced them and when i start...
When it is shifted to right vice versa, it indicates a distortion on the horizontal output. Try replacing all the capacitors around the horizontal output area with the same original value. Make sure the horizontal output transistors you replace hasn't started going gone bad already if you know how to check them. Them dimness in the picture is caused by the horizontal output not putting enough high voltage to the CRT. Look for leaking capacitors too. Also replace the resistors around the horizontal output, they may have burnt out or changed in value from overloading cause by the malfunction of the flyback, and the transistor.
Jun 27, 2009 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Flyback transformer and horizontal output transistor change out
There is a little loose sleeve at the transformer. It can be pulled out, but it is best to squeeze the sides through hole on each side of the terminal to remove the sleeve. The wire just comes out with a small pull afetr the sleeve is removed. Good luck.
Dec 20, 2008 | RCA Televison & Video
Sony videoscope xbr
the problem is most likely to be found on the HOrizontal Output Transistors note their numbers and replace them.this transistors are usually mounted on huge heatsinks.
Jul 05, 2008 | Mag Innovision InnoVision XJ 717 Monitor
1996 Sony 32" Trinitron - Suddenly lost picture and sound
The most common problem with TV was the failure of the Horizontal Output Transistor, this will also damage 2 transistors in the power supply and a resistor in the power supply also. (From memory): Horizontal Output location # Q501, 2 power supply transistors Locations Q601, Q602, and resistor Location R607. Also solder the Horizontal drive transformer, you can find it by following the circuit board from the base of the Horizontal output. Some models used an IC instead of the 2 transistors in the powersupply, it will have six legs and check like 2 transistors. Good Luck.
Jun 04, 2007 | Sony KV-32S26 32" TV
Horizontal output transistor keeps failing
The horizontal output transitor is always connected to the primary winding of the flyback transformer (via collector) and also to the horizontal deflection coil via an electrolytic capacitor. The most likely suspect for damaging the transistor is the fylback transformer. In some countries there are electronic stores that test flyback transformer by winding a few turns on the ferrite core and applying a test voltage. This test will only test the secondary. The primary winding is difficult to test for turn to turn short because the resistance is quite low and you do not know the 'good' resistance.
May 15, 2007 | ViewSonic E70f 17" CRT Monitor
Televison & Video Logo
282 people viewed this question
Top Televison & Video Experts
Electro Med Services...
