Question about GE PDS22SIS Bottom Freezer Refrigerator
GE Profile PDS22SIS ice maker problem
Ice Maker not making ice. Took the filter out and replaced with the plug. Water dispenser working fine, and then when I close the freezer door I hear water going into the ice maker, ice freezes, than doesn't release it into the bucket? Help please
  • Anonymous Mar 27, 2014
    my ice maker was frozen up. i took care of that then water stopped working
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
On the ice maker press and hold the size selector. This will put the ice maker into a test mode and it should cycle through. If it doesn't work your problem is with your icemaker.
Sgt 48
Posted on Jun 06, 2008
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker makes ice, but not nearly as much as it used to. What do you suggest. Water flow out dispenser is fine. Filter has been replaced.
I would suggest making sure the coils under the refrig are clean of dust , lint , pet hair , etc . Also , letting the ice build up so it gets closer to the bottom of the ice maker (coldness of the ice will help keep the ice maker cold ) will result in ice maker cycling more often (making ice) .
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile TFT25 PR. Ice maker quit producing
Had the same problem. Replace the water filter and is should begin making ice again.
Mar 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE PROFILE PSS26msrd Ice maker not working water dispensor ok new water valve new filter fill tube seems clear Does anybody have any sugestions before i replace the ice maker unit?
water does become ice inside the pipe in side the freezer it happens to my frige at list once a year, put a hard wire or pencil up to make sure that is not the problem, before you spend any more money
Dec 06, 2008 | GE Profile PSW26P Stainless Steel Side by...
The machine water pressure is low cheak the inlet water pressure and cheak the machine water in let line any block
Jun 21, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Open Questions:
GE PDS22SIS Bottom Freezer Refrigerator Logo
275 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
