Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
No audio brand new toshiba 42xv540u
Just set up my new lcd tv, excellent picture via expressvu dish but no sound.  I've tried the optical port as well as the analog rca connectors and am using the hdmi connector in port 1.  Nothing.  With nothing connected to the tv and the volume cranked up to 90 I don't even hear any hissing noises from the internal speakers?
  • jimster2 Jun 10, 2008
    As it turns out by using hdmi 1 I required the red and white audio leads to connect to the mini plug input for the Pc.  I missed this in the manual
  • 868 Answers
Speakers are muted.
Posted on Jun 10, 2008
I have a LG LCD TV 26LX2R and I recently bought a Sony Blu-Ray BCP-S580. If i connect them via Composite or Component cables i get ok video and audio. But when i connect them via HDMI i get excellent image...
I can't speak on whether or not the apple tv has such a setting but the Bluray players does. You go into the bluray player's settings and change the audio output.Your choices should be 2 ch possibly hdmi, bitstream, pcm, and auto. Try hdmi, 2 ch, and pcm because if you have it on auto you might not get sound via an hdmi cable and it's probably not bitstream but try bitstream if none of the others work.
Sep 20, 2011 | LG 26LX2R 26 in. HD-Ready LCD TV
My 22 lcd gives good picture but no sound.I've tried connecting an externel head phone but i don't hear any sound.
you're best bet is, depending on your TV's input/output, is to run your video components directly to TV via HDMI, component, etc., of course component requires additional sound cables, then run your sound out from TV via, best, digital optical, to reciever. You use the TV's menu to choose what you watch and, only have the one audio out. Scan your recievers menu to make sure you've got the right channel to listen to.
Jun 28, 2011 | Audio Players & Recorders
I have bought a new Blu-Ray player, a BDP-S570, which I am trying to connect to my LG TV. The TV is a 50PX4D and has one HDMI port that I have previously used to connect a Sky HD box to with excellent...
There are no compatibility issues. In your BluRays HDMI audio settings set the audio out to PCM instead of bit stream.The TV cannot decode digital bit stream audio.
May 16, 2011 | Sony BDP-S350 Blu-Ray Player
LD4088 LCD will not play sound via HDMI cables. Component cables are fine. Hear a faint "click" from speaker when switching to HDMI input. Have tried all three HDMI connectors and have tried...
This is how AUDIO works in HDMI setup, you can select the source to send the digital audio along with the digital video through HDMI, the receiving end HDMI sound setup must be set to receive the digital audio through HDMI. Otherwise the audio may be sent and received through analog audio ports (Red (Right channel) and White (Left channel) RCA jacks) in stead. Most of the new TV and DVD player use auto detection.
So please check the HDMI audio setup to see how the audio signals are set to be processed.
Please leave rating if it helps.
Jan 14, 2011 | Apex Digital LD4088 LCD TV
Toshiba CN36X81 television.. NO Sound... Great Picture. Using the TV2 output of a DISH Network HD receiver... TV2 output is std def, coax output. Using a different TV I get picture and sound... but not...
IF coming in via, the "Dish" networked receiver, please check that this volume is turned way up, on the TV. and then control the the Volume, with the Dish Remote, often this is a problem, as one is turned down, and the other cannot turn that up, simply try syncing the Volume controls, UP on TV, control the Audio with dish remote. thats all i can think of. Check by feeding a signal IN from an AV, source, ie: Yellow, Video, & Red& White, Audio. Turn TV UP and check, IF it responds to this all is well. If NOT then you do indeed have a fault, with the TV.
Mar 27, 2010 | Toshiba CN36X81 TV
I have my xbox 360 connected via hdmi to my yamaha rx-v363 receiver, and the receiver connected to my sony bravia lcd tv via hdmi as well. The xbox picture comes through to the tv fine, but the sound will...
Connect Xbox via HDMI to DTV/IN, Connect HDMI from out to Sony Bavia's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby 5.1 etc .. cheers
Sep 04, 2009 | Yamaha RX-V363 Receiver
Surround sound signal not transferring.
need to go into audio menu and select digital audio as the output signal, its probably set to mts stereo.
Aug 29, 2009 | Insignia 42" LCD Flat-Panel HDTV
HOW TO CONNECT SAMSUNG 40 LCD TV TO SAMSUNG SURROUND TZ215 THRUGH SKY + HD BOX.
you will need the following = HDMI LEAD
Optical Audio Lead
Red and White phono Lead
Sky HD Box > connect to Tv via HDMI Lead.
Sky HD box > Connect the optical Audio, and the Phono Leads To your Surrounds sound.
The reason I am wanting you to connect the phono's as well as the optical audio out. Not all programs are transmitted with Dolby D so you will need these for normal sound to come through your surround sound.
One last thing I would like you to check is the sound settings on your Hd box.
OLD PROGRAM GUIDE:
On your sky remote. Press SERVICES, 4, 2, then ensure that Dolby D is displayed if not highlight and using the blue button change this to Dolby D. then arrow down to save.
NEW PROGRAM GUIDE:
On your sky remote. Press SERVICES, 0, Arrow along to SOUND then arrow down and change this to DOLBY D Then press the GREEN button.
Hope this Helps you out. IF so please leave a thumbs up
Little Dish Fitter
Aug 26, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Denon AVR 588 7.1-- Sound setup questions
This reciever does not decode the audio through HDMI, the HDMI ports are simply a pass-through. To get audio you need to connect an optical audio cable from the PS3 to the reciever also. I figured this out after 2 hours of trying to get audio from the HDMI cable. Here is a link that shows the different audio formats supported through HDMI by the different Denon models. It looks like the AVR-788 is the lowest model that supports audio through HDMI. Hope that helps.
Apr 03, 2008 | Denon AVR588 Receiver
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
1,146 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
