Question about Canon PowerShot SX100 IS Digital Camera
Stuck battery door on dsc p93a
I dropped my dsc p93a camera and now the battery cover is stuck half open
I can not get it to open or close
  • 45 Answers
There is usually a lock on the inside of the door. Sometimes you can move that while the door is open, else play with the release switch. Once you get it in the open position it should close
Posted on Jun 06, 2008
My Sony-cyber-shot DSC-P93A won't turn on when I turn the dial to camera just has a red light on the side
have you replaced the batteries,or the power pack (some models) disconnect the power for a few minutes, check that the lens is in its closed position. flush with the casing. install batteries etc, also you can try the power adapter to see if it will work on this, this is an extra in some models and may not be with the box.
Jan 22, 2017 | Cameras
Sir/Mam, I had purchase Sony
Has it been dropped? I had a cabera that was dropped and the lense would not go all the way back in which caused the lense covers to not close.
Oct 22, 2013 | Sony Cyber-Shot DSC-W570 Digital Camera
Dropped camera and now the lens is stuck out,when i turn it on the screen says turn power on and off again.i do that,but it keeps saying it still and camera makes a weird noise when i turn it on,and lens...
Bummer huh? I dropped mine a while back and damaged my battery cover!
I would try...taking out the batteries and reinstalling them! This may reset your camera?
Otherwise, I would do a web search and type in:
Sony Cyber-shot Camera DSC-W50 troubleshooting
Hope this helps you get your camera working again!
Kind Regards!
Sep 15, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
I dropped my Sony DSC-W1/W12 camera. The battery door broke and will no longer close. The camera works fine with a little duct tape. Do they make a new battery cover to replace? Thank you all Marcia
Yes, you can get new battery holder that comes with cover, part number is as follows:
175648311.... HOLDER, BATTERY (WITH TERMINAL Silver)
DSC-W1 Camera will take apart to replace battery compartment.
Hope these info will help you.
Sep 27, 2010 | Sony Cyber-Shot DSC-W1 Digital Camera
The door is stuck open, how do I close it
the two little clips that hold it closed are more than likely broken off or damaged. you need to replace the battery door.
Apr 01, 2010 | Sony Cyber-Shot DSC-W1 Digital Camera
The Battery Door on my Sony Cybershot DSC-S40 won't open.
No easy solution except:
1. Remove all 3 screws from body.
2. Carefully wedge off the back half of body.
3. The back half is connected to the front half by a small cable. Don't break this!
4. The door has a hinge pin. Wedge up and remove this pin.
5. With small screwdriver, wedge off the door from top. Should pop out.
6. Apply small amount of oil on sliding areas.
7. Reinsert door. If still stuck, see step 5.
8. Reassemble camera back and screw down.
9. The reason for sticking is unknown, but door can still be removed by popping off as in step 5.
Nov 08, 2008 | Cameras
Lens stuck halfway open
Fully charge the battery or connect the camera to the power supply (if you have an ac adaptor).
If it still does not work, it means that the lens is broken.
Reason can be that the camera was in your pocket pr carrying bag and the camera inadvertantly open and the lens mechanism was damaged. In this case, it needs repair.
Apr 21, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
In addtion, I found the last two posts on this forum very helpful:
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Sony DSC-S500
you are right it has defective mechanism,  a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Oct 11, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Canon PowerShot SX100 IS Digital Camera Logo
290 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
