Question about Refrigerators
Water inside chefmate refrigerator
I own a chefmate refrigerator 1.7cu ft. There is water on the inside. I came in today and noticed water on the inside. Thought it was from a spill but 4 hours later there is water again. Where is it coming from?
Moisture inside the 'fridge condenses on the coolest parts. Most are designed so that the moisture runs down into a channel and is directed out through a small tube somewhere at the back of the compartment, near the bottom.
I would guess that the tube is blocked near the top.
Try finding the tube and carefully inserting something flexible down it to clear the blockage. Don't use anything too rigid, or anything metallic, as these may damage the tube and cause more serious problems. I have done this before using a pipe cleaner.
Posted on Jun 06, 2008
Water leaking inside the vegetable drawer
What is your model number? Also what year, series etc.
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Ice maker, water panal on side by side refigerator not coming on when depresing handle
The water line could be frozen. Remove the water filter and see if it frozen. Also, see if the water dispenser works with the filter removed.
Sep 09, 2012 | Maytag MSD2572VEW (25 cu ft) Side by Side...
I have the Kenmore refridgerator with the freezer on the bottom, and lately it has been making a loud noise when it comes on. It has been doing this for a week or more, today I noticed that the temperature...
You need to check for the refrigerator level, drain pan, condenser fan, evaporator fan and inspect the compressor mounts for the cause of noise. Any popping or hissing sound is normal on frost free refrigerators.
Good luck
Jul 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
About a month ago we noticed that there was water on the food in our refrigerator and that ice was building up in the freezer. Today when i went to get ice cream out of the freezer I noticed it had...
I thoguht I had posted the solution. repeating now ask for estimates/ inference from thre persons and deccide for only low cost of repair. If your fridge is more than 5 years old do not proceed specially if the pumping of the compressor is down. Go for a good exchange with a the modern enerrgy effficient models as you can choose from good economic/ luxury ranges and give you about 5-7 years warranty.Invest Well. Good Luck
Jun 28, 2010 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Water build up at bottom of Kenmore Compact Fridge
Problem on your Refrigerator bypass plastic water sypply pipe.May be it was block dust,so you can clean it then water thorough the tank.
Mar 15, 2010 | Kenmore 4.9 cu. ft. Compact Refrigerator
Defrosts/refreezes
IF YOU TAKE THE BACK PANEL OFF INSIDE THE FREEZER YOU WILL FIND A PIECE OF METAL UNDER THE EVAPORATOR COILS IN MIDDLE OF THIS METAL PAN IS A HOLE THAT LEADS THE WATER TO THE BOTTOM OF THE REF FOR EVAPORATION THE HOLE IN THE PAN IS PROBABLY PLUGGED TAKE THE ICE OUT AND CLEAR THER HOLE
Aug 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
Mar 01, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
GE Refrigerator, Model TBX22ZA
One thing I might suggest is to check and see if the magnetic seal around the outside of the door is clean, tight, and fitted properly as this is one thing that can cause this condition.
Jun 11, 2007 | Kenmore 26.0 cu. ft. Side-By-Side...
the drain hole is blocked in the bottom of the fridge. if the water is not able to drain down the hole it will overflow into the fridge base. check any holes at the inside back of the fridge.
Refrigerators Logo
205 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
