Question about SanDisk Sansa c200 MP3 Player
Wont work alright when i turn it on the sandisk thing pops out but then it turns off please help me
  • 8,596 Answers
Sounds like a firmware upgrade is needed. If an Mp3 player freezes one time only, you can simply reset it. But if it is continually freezing on you, then you either need a firmware upgrade or you are having an actual hardware issue.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 07, 2008
Sansa e250 wont do any thing
you need to find a website that
that has a solution
Jul 12, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e280 wont turn on
What i do is drop it not hard but a light drop and it should turn on than
Aug 25, 2008 | SanDisk Sansa E280 MP3 Player
Wont work..
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Should you have any problems after you update the firmware let me know and I will be more than happy to help you...
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Mar 29, 2008 | SanDisk Sansa E280 MP3 Player
My sansa sandisk e200 wont turn on
well mine does that too!!!!!!!!! help some one plz
Jan 23, 2008 | Philips SA5125/37 MP3 Player
Sansa 8GB .. help
charge the battery for about an hour then turn it back on and see if the problem is still happening
im just suggesting im not makin a promise on this if it dont work sorry
Dec 28, 2007 | SanDisk Sansa e250 MP3 Player
Frozen MP3
For Sansa or Sandisk problems, contact http://www.sansacommunity.com/ This site is dedicated to Sandisk products and can help you. Good Luck
May 12, 2007 | SanDisk Sansa c140 MP3 Player
Sandisk mp3 player won't work
well, try to remove the battery for like 5 to 10 seconds and then insert it back in!!!! i had the same problem and i tried this and it really worked fo real ma nizzle
Apr 09, 2007 | SanDisk Sansa e250 MP3 Player
Please Help: Im Desperate!
hmm... try hooking it up to the pc, go to my computer find the mp3 click explore go to music and select it all and delete it then try again it might help
Mar 20, 2007 | SanDisk Sansa c140 MP3 Player
Mp3 player 512mb wont open all the way
try re-intsalling the progam disk that came with it, than format the whole mp3 player & it should work
Jan 02, 2007 | SanDisk SDMX1 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
