SOURCE: my Rival food saver does not vacuum air out
We discovered we were not moving the bags in far enough to be grabbed properly. After pushing in the bag before closing the unit we found it started sealing properly. This was on an older system, so be sure the bags you're sealling are between the black rubber rectanglar sections before closing the door.
If this is for a canister, be sure the rubber around the lid is seated properly. The rubber can be removed, cleaned and wiped dry. Clean out the lid and dry it too. Reseat the rubber seal and try again... Hope this helps.
SOURCE: lumina vacuum food sealer will not seal
Rang the info. number. I did not do this before because it was after hours.
The solution was simple, apply pressure with finger to lid and press start button. Evidently the plastic lid distorts when closed and does not make electrical connection. Works OK now.
SOURCE: Vacuum Philips vision Plus Squeal from
Yes there are replacement seals available. check www.trademe.co.nz ...if you dont get some there contact me for further assistance.
Hope this solution has been helpful?
SOURCE: I own a hoover steam vac model # F5915900 inside
Here is the webpage for vac parts warehouse. This shows a diagram of your steam vac. You pick the part and buy it.
Hope this helps.
Handie Andie
