2003 Honda Pilot Logo
Posted on Jun 06, 2008
Rear wiper blade
How do you change/remove the rear wiper blade?
  • Anonymous Mar 12, 2014
    how do i change the rear wiper blade on a 2011 toyota highlander
Piloter
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 18, 2008
Piloter
Contributor
Level 1:
Answers
Questions
Helped
874
Points
I went to a Honda dealer and bought a replacement wiper blade (rubber part only) for about $6, and the guy in parts came outside and changed it for me. You slip off the rubber blade only from the wiper assembly and then slip in the new blade.
5 Related Answers
Anonymous
  • 334 Answers
  • Posted on Dec 03, 2008
SOURCE: remove rear wiper blade on saab 9-5 estate
Best way go to a parts store and ask for help and they would probably slip it on for you
God Bless you Greg
Anonymous
  • 6982 Answers
  • Posted on Feb 09, 2009
SOURCE: rear wiper blades
No...blade comes off end of arm... If in doubt, most "supermarket" style parts outlets will put it on for free.
c17hydro
Greg Bernett
  • 2993 Answers
  • Posted on Mar 11, 2009
SOURCE: How to remove and replace the wiper blades on a 2006 BMW 325i.
My suggestion....go to Schuck's/Kragen?Chief's?Auto Zone....they will install them for FREE.
Anonymous
  • 43 Answers
  • Posted on May 28, 2009
SOURCE: how to remove audi a6 wiper blades
The problem with this wiper blade set up is the slides get jammed up w/ crude.  You should lubricate the slides and they should slide off.  Then carfully lift the arm and remove the blade.  Warning you should never leave the arm in the upright position.  Windshields get cracked this way.  Also note the pivit points the blades attach too.  These will normally sieze up and cause clearing issues even with new blades.  Lubricate these pivit points and use a pair of channel locks to move it back and forth until it will go 360 degrees with your fingers.  Install is in reverse order of removal.
Anonymous
  • Posted on Mar 06, 2010
SOURCE: How do you replace the rear windshield wiper
like most hatchbacks, you hafta replace the whole rear wiper arm assembly. Go to a Toyota dealers' parts counter.
Testimonial: "Thanks I was afraid of that"
1helpful
How do I remove the rear wiper assembly from the rear wiper motor
flip the nut cover back up the arm and undo the nut shown
the arm base is normally on a splined taper so you may need a flat blade under the arm base on a piece of something so as not to damage the paint and lever it off the spline
7helpful
2011 equinox rear wiper replacement
I just replaced mine. Lift the rear wiper up as far as it will go. which is not very far. Place your fingers on each end of the wiper and pull down. The blade is held in place by a clip. Gentle pressure will downward toward the window will cause it to disconnect. An extra pair of hands to hold the plastic cover up helps. Note the orientation of the blade when you disconnect it. The replacement blade may have a clip on it which may need to be removed. Place the replacement blade in the same orientation as the one that was removed and clip back in place.
How to remove the windshield wiper arm on a 2003 pontiac vibe
  1. Release the old blade. Lift the wiper arm off the window.
  2. Remove the wiper. Once rotated, the wiper will release from the wiper arm with a gentle click.
  3. Position the new blade. Place the small bar attachment on the new wiper blade into the hook on the wiper arm.
  4. Lock the blade into place. ...
  5. Done!
www.ezwipers.com > wipers > Pontiac > Vibe > 2003 > change > rear
How to change the rear wiper on a 2003 Pontiac Vibe
CHANGING REAR WIPER ON 2008 OUTLANDER
These are available at the dealership. There is one way though. You can get a 21" RAIN X wiper and i just cut it down to size. The grooves on a RAIN X will fit up to your rear wiper. As far as replacing it although it looks more difficult at first glance it it every bit as simple as the front wiper blades. It's a simple pop off. You can also just change rubber wiper and leave the actual blade alone. the rear is a mini blade style (this refers to the size of the rubber insert in the blade, not the actual whole blade being small.) You can replace the rubber using an Amcor blade or any "mini" blade. Puchase the biggest one they have, take out the rubber wiper and just cut to size. You can change the rubber many times off of one blade thus saving you a bunch of money.
I can't remove old rear wiper on my 2005 Outback
PRESS ON THE TAB AND PUSH THE BLADE ASSEMBLY OUT OF THE HOOK AT THE END TO REMOVE IT.IF STILL HAVE PROBLEMS REMOVING REAR WIPER BLADE.AUTO ZONE OR ADVANCE WILL DO IT FOR YOU FREE WHEN YOU BUY A NEW SET BLADES FROM THEM IF YOU DONT BUY NEW BLADES THEY WILL STILL HELP YOU REPLACE THEM.
1helpful
C hange rear blade 2008 gmc
At the mounting area of the blade to the rotating wiper arm is a tab that has to be pushed in and held to remove the wiper blade. The tab will be on the wiper blade's center housing ansd is very small to see
2answers
How do you remove rear wiper on 1997 range rover 4.6 HSE
if you have an autozone or any parts store near you and you get the blade from them they will help you install it give these websites a try www.alldatadiy.com and www.autozone.com wish you the best Michigan Man
2answers
How to replace the wiper insert at the back of
  1. REMOVE RR WIPER BLADE
    1. Raise the rear wiper blade to the position as shown in the illustration where the meshing of the claw disengages with a clicking sound. NOTE: Be careful not to break the claw.
    2. Pull straight the rear wiper blade to vehicle's left from the wiper arm. NOTE: Do not fold the rear wiper arm with the rear wiper blade removed from it.1722d05.gif
  1. REMOVE REAR WIPER RUBBER
    1. Place the rear wiper with the rear end of the rubber protruded from the blade stopper as shown in the illustration. NOTE: Do not pull out the wiper rubber forcibly, as the backing plates will become deformed or the blade claws will become damaged. HINT: The rubber can be easily pulled out by pushing the middle area of the blade.
  1. INSTALL REAR WIPER RUBBER
    1. Install the 2 wiper rubber backing plates to the rear wiper rubber. NOTE: Be careful to observe and keep direction of curvature for correct replacement.
b. Insert the rear wiper rubber from the claw of the middle of the rear wiper blade into the rear end position.
c. After passing the rear wiper rubber through the rear end side claw, protrude it from the rear end stopper and pass it through the front tip side claw.
2helpful
2answers
Replace rear wiper on 2005 Murano
You probably already figured this out, but you have to remove the wiper arm completely in order to replace the wiper blade.
The blades are an unusual size (somewhere around 14 1/2") and I believe they are only available from a Nissan dealership. They include printed instructions in the box but just in case, this is from the official Nissan service manual:
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
