Question about Kitchen Ranges
My mother has a hotpoint gas stove and when baking the oven has produced a lot of black carbon all over the oven...also the burners seem to be doing this also
  • 487 Answers
This is a problem.
You will have to check whether she uses Natural gas or propane.
The oven might and most likely will be set for the other.
if the problem just occured it means the the oxygen supplied is to little.
It can be that dirt buildup at the gas line prevents the oxygen to mix with the gas.
Please be careful and check it out directly and please do not use untill fixed. Carbon monoxide is quickly build up and you will notice only when too late
Posted on Jun 06, 2008
  • eric bosman
    eric bosman Jun 06, 2008
    Check all the valve and safety valves. Orfices might be dirty too
    Idea you can get HERE
    And HERE you can get your manual which will tell you how to clean this problem. If she however changed gas (either supplier or gas) and did not convert the stove than that is the problem
  • eric bosman
    HERE IS THE SECOND LINK
  • Kitchen Ranges Master
  • 13,433 Answers
This is caused by incomplete combustion of the gas.
    Master:
  • 638 Answers
The pores of the burner have been blocked by some food particles or the pores have not been cleaned since longtime,so try to remove the blockage thats creating fumes of the carbon and also try to maintain the time and temprature depending on the food u make or bake.this may help to prevent such problems in future. wish u success.
Hotpoint gas oven doesn't light
What is the complete model number of your unit?
Dec 09, 2012 | Kitchen Ranges
Hotpoint gas stove. burners work, oven and broiler do not.
Probably the safety valve. This unit broils and bakes off the same gas burner. A spark ignitor lights the pilot and this save gas because no standing pilot is needed. It takes a few minutes for the thermocouple bimetal combo to release the gas. When the temp gets to the desired rate then the bulb on the oven control closes off the flow of gas. To recap: The flow of gas comes from a regulator along a rail which supplys the gas to the top burners and the oven control. older models had pilot light tubing going down to the oven and to the top burners. This newer style uses a spark module to light off the top burners and the oven. So when yall turn the the oven on the spark ignitor lights the pilot first and then after the mercury bulf thermocouple heats up the bimetal inside the valve opens allowing gas to flow out to the pilot and ignite the gas burner. the temp rises and the mercury bulb oven control expands closing off the flow but not the gas safety valve. I would suspect the safety valve on this one.
May 09, 2011 | Hotpoint RGB528 Gas Kitchen Range
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Hotpoint stove with f3 code.
Replace the oven control module.It controls the bake and broil including clock and timer functions.
Jan 28, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
LP GAS ODOR WHEN USING OVEN
sounds like you need to take the drawer out and tiighten the orifice down. some say tighten it all the way down and back it off 2 turns. if you do that and still have a problem then you may have a problem with carbon build up in the bake burner, let me know if you need further assistance
Nov 30, 2008 | Hotpoint RGB745 Gas Kitchen Range
Sound produced by the stove
is it when you are baking? A bad bake igniter will cause a noise like that.
Nov 04, 2008 | Hotpoint RGB745 Gas Kitchen Range
Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
117 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
